[mapserver-commits] r10548 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Sep 30 09:14:58 EDT 2010
Author: dmorissette
Date: 2010-09-30 13:14:58 +0000 (Thu, 30 Sep 2010)
New Revision: 10548
trunk/mapserver/README.CONFIGURE
trunk/mapserver/configure
trunk/mapserver/configure.in
Added GDAL dependency check for --with-wmsclient (#3555)
Modified: trunk/mapserver/README.CONFIGURE
--- trunk/mapserver/README.CONFIGURE 2010-09-30 12:50:51 UTC (rev 10547)
+++ trunk/mapserver/README.CONFIGURE 2010-09-30 13:14:58 UTC (rev 10548)
@@ -114,8 +114,8 @@
--without-wms Disable OGC WMS Compatibility (enabled by default).
--with-wfs Enable OGC WFS Server Support (OGR+PROJ4 required).
--with-wcs Enable OGC WCS Server Support (GDAL+PROJ4 required).
- --with-wmsclient Enable OGC WMS Client Connections (PROJ4 and libcurl
- required).
+ --with-wmsclient Enable OGC WMS Client Connections (PROJ4, libcurl and
+ GDAL required).
--with-wfsclient Enable OGC WFS Client Connections (PROJ4, libcurl and
OGR required).
--with-sos Enable OGC SOS Server Support (libxml2 and PROJ4 and
@@ -520,14 +520,14 @@
- required).
+ GDAL required).
- This option enables MapServer's 'CONNECTIONTYPE WMS' to include layers
from remote WMS servers in MapServer applications.
- It requires PROJ4, libcurl (see --with-curl-config option below) and OGR.
- GDAL is optional but highly recommended in order to support
- reprojection of layers obtained from remote WMS servers.
+ It requires PROJ4, libcurl (see --with-curl-config option below) and GDAL.
+ GDAL is required in order to support reprojection of layers obtained from
+ remote WMS servers.
- See the MapServer WMS Client HOWTO for more details at
http://mapserver.gis.umn.edu/docs/howto/wms_client
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure 2010-09-30 12:50:51 UTC (rev 10547)
+++ trunk/mapserver/configure 2010-09-30 13:14:58 UTC (rev 10548)
@@ -918,8 +918,8 @@
- required).
+ GDAL required).
OGR required).
@@ -11934,10 +11934,10 @@
echo "$as_me:$LINENO: result: OGC WMS Client Layers disabled by --without-wmsclient." >&5
echo "${ECHO_T} OGC WMS Client Layers disabled by --without-wmsclient." >&6
-elif test -z "$PROJ_ENABLED" ; then
+elif test -z "$PROJ_ENABLED" -o -z "$GDAL_ENABLED"; then
- echo "$as_me:$LINENO: result: OGC WMS Client Connections not enabled (PROJ.4 and libcurl required)." >&5
-echo "${ECHO_T} OGC WMS Client Connections not enabled (PROJ.4 and libcurl required)." >&6
+ echo "$as_me:$LINENO: result: OGC WMS Client Connections not enabled (PROJ.4, libcurl and GDAL required)." >&5
+echo "${ECHO_T} OGC WMS Client Connections not enabled (PROJ.4, libcurl and GDAL required)." >&6
elif test "$with_wmsclient" = "yes" ; then
@@ -12156,9 +12156,9 @@
echo "${ECHO_T} If unavailable disable using --without-xml2-config," >&6
echo "$as_me:$LINENO: result: but WCS 1.1 support will be disabled." >&5
echo "${ECHO_T} but WCS 1.1 support will be disabled." >&6
- elif test "x$WFS_SVR_ENABLED" != "x" ; then
+ elif test "x$WFS_SVR_ENABLED" != "x" ; then
with_xml2_config=yes
- echo "$as_me:$LINENO: result: libxml2 requested for WCS Server." >&5
+ echo "$as_me:$LINENO: result: libxml2 requested for WFS Server." >&5
echo "${ECHO_T}libxml2 requested for WFS Server." >&6
echo "$as_me:$LINENO: result: If unavailable disable using --without-xml2-config," >&5
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in 2010-09-30 12:50:51 UTC (rev 10547)
+++ trunk/mapserver/configure.in 2010-09-30 13:14:58 UTC (rev 10548)
@@ -1770,16 +1770,16 @@
AC_CHECKING(whether we should include WMS Client Connections support)
AC_ARG_WITH(wmsclient,
-[ --with-wmsclient Enable OGC WMS Client Connections (PROJ4 and libcurl
- required).],,)
+[ --with-wmsclient Enable OGC WMS Client Connections (PROJ4, libcurl and
+ GDAL required).],,)
if test "$with_wmsclient" = "no" ; then
AC_MSG_RESULT([ OGC WMS Client Layers disabled by --without-wmsclient.])
- AC_MSG_RESULT([ OGC WMS Client Connections not enabled (PROJ.4 and libcurl required).])
+ AC_MSG_RESULT([ OGC WMS Client Connections not enabled (PROJ.4, libcurl and GDAL required).])
More information about the mapserver-commits
