[mapserver-commits] r10549 - branches/branch-5-6/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Sep 30 09:55:47 EDT 2010
Author: assefa
Date: 2010-09-30 13:55:47 +0000 (Thu, 30 Sep 2010)
New Revision: 10549
branches/branch-5-6/mapserver/HISTORY.TXT
branches/branch-5-6/mapserver/mapogcfilter.c
Fix ProperyIsLike not used efficiently with Oracle (#3557)
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT 2010-09-30 13:14:58 UTC (rev 10548)
+++ branches/branch-5-6/mapserver/HISTORY.TXT 2010-09-30 13:55:47 UTC (rev 10549)
@@ -14,6 +14,8 @@
Current Version
+- Fix ProperyIsLike not used efficiently with Oracle (#3557)
- Fixed msOGRGetSymbolId according to the changes in gdal 1.8 (#3556)
- Fixed crash when drawing a map using UNIQUE fid in the layer data (#3271)
Modified: branches/branch-5-6/mapserver/mapogcfilter.c
--- branches/branch-5-6/mapserver/mapogcfilter.c 2010-09-30 13:14:58 UTC (rev 10548)
+++ branches/branch-5-6/mapserver/mapogcfilter.c 2010-09-30 13:55:47 UTC (rev 10549)
@@ -2368,11 +2368,11 @@
if (nCount > 1)
return 0;
- /*make sure that if there is properyisequal, it is the only one*/
- if (psFilterNode->psLeftNode == NULL && psFilterNode->psRightNode == NULL)
+ /*make sure that it is the main and only node*/
+ if (strcasecmp(psFilterNode->pszValue, "PropertyIsLike") == 0)
return 1;
- return 0;
+ return 0;
int FLTIsPropertyIsLikeFilter(FilterEncodingNode *psFilterNode)
More information about the mapserver-commits
