[mapserver-commits] r11456 - in trunk/mapserver: . mapscript/php
svn at osgeo.org
svn at osgeo.org
Mon Apr 4 13:50:20 EDT 2011
Author: aboudreault
Date: 2011-04-04 10:50:20 -0700 (Mon, 04 Apr 2011)
New Revision: 11456
trunk/mapserver/mapscript/php/layer.c
trunk/mapserver/mapscript/php/mapscript_i.c
trunk/mapserver/mapscript/php/php_mapscript.h
trunk/mapserver/mapscript/php/php_mapscript_util.c
trunk/mapserver/mapserver.h
clusterObj is always embeded in laye rObj.
Modified: trunk/mapserver/mapscript/php/layer.c
--- trunk/mapserver/mapscript/php/layer.c 2011-04-04 16:42:42 UTC (rev 11455)
+++ trunk/mapserver/mapscript/php/layer.c 2011-04-04 17:50:20 UTC (rev 11456)
@@ -288,6 +288,7 @@
else IF_GET_OBJECT("offsite", mapscript_ce_color, php_layer->offsite, &php_layer->layer->offsite)
else IF_GET_OBJECT("grid", mapscript_ce_grid, php_layer->grid, (graticuleObj *)(php_layer->layer->layerinfo))
else IF_GET_OBJECT("metadata", mapscript_ce_hashtable, php_layer->metadata, &php_layer->layer->metadata)
+ else IF_GET_OBJECT("cluster", mapscript_ce_cluster, php_layer->cluster, &php_layer->layer->cluster)
else IF_GET_OBJECT("projection", mapscript_ce_projection, php_layer->projection, &php_layer->layer->projection)
else
@@ -353,7 +354,7 @@
(STRING_EQUAL("grid", property)) ||
(STRING_EQUAL("metadata", property)) ||
(STRING_EQUAL("projection", property)) ||
- (STRING_EQUAL("projection", property)) )
+ (STRING_EQUAL("cluster", property)) )
mapscript_throw_exception("Property '%s' is an object and can only be modified through its accessors." TSRMLS_CC, property);
@@ -1903,6 +1904,7 @@
if (php_layer->grid && Z_TYPE_P(php_layer->grid) == IS_OBJECT)
MAPSCRIPT_DELREF(php_layer->grid);
MAPSCRIPT_DELREF(php_layer->metadata);
+ MAPSCRIPT_DELREF(php_layer->cluster);
MAPSCRIPT_DELREF(php_layer->projection);
@@ -1990,6 +1992,7 @@
if (php_layer->layer && !php_layer->is_ref) {
@@ -2013,6 +2016,7 @@
php_layer->offsite = NULL;
php_layer->grid = NULL;
php_layer->metadata = NULL;
+ php_layer->cluster = NULL;
php_layer->projection = NULL;
return retval;
Modified: trunk/mapserver/mapscript/php/mapscript_i.c
--- trunk/mapserver/mapscript/php/mapscript_i.c 2011-04-04 16:42:42 UTC (rev 11455)
+++ trunk/mapserver/mapscript/php/mapscript_i.c 2011-04-04 17:50:20 UTC (rev 11456)
@@ -1544,17 +1544,6 @@
* class extensions clusterObj
-clusterObj *clusterObj_new() {
- clusterObj *c = (clusterObj *) msSmallMalloc(sizeof(clusterObj));
- initCluster(c);
- return c;
-void clusterObj_destroy(clusterObj *self)
- freeCluster(self);
int clusterObj_updateFromString(clusterObj *self, char *snippet) {
return msUpdateClusterFromString(self, snippet);
Modified: trunk/mapserver/mapscript/php/php_mapscript.h
--- trunk/mapserver/mapscript/php/php_mapscript.h 2011-04-04 16:42:42 UTC (rev 11455)
+++ trunk/mapserver/mapscript/php/php_mapscript.h 2011-04-04 17:50:20 UTC (rev 11456)
@@ -304,6 +304,7 @@
zval *grid;
zval *metadata;
zval *projection;
+ zval *cluster;
int is_ref;
layerObj *layer;
} php_layer_object;
@@ -773,8 +774,6 @@
resultObj *resultObj_new();
-clusterObj* clusterObj_new();
-void clusterObj_destroy(clusterObj *self);
int clusterObj_updateFromString(clusterObj *self, char *snippet);
int clusterObj_setGroup(clusterObj *self, char *string);
char *clusterObj_getGroupString(clusterObj *self);
Modified: trunk/mapserver/mapscript/php/php_mapscript_util.c
--- trunk/mapserver/mapscript/php/php_mapscript_util.c 2011-04-04 16:42:42 UTC (rev 11455)
+++ trunk/mapserver/mapscript/php/php_mapscript_util.c 2011-04-04 17:50:20 UTC (rev 11456)
@@ -148,6 +148,8 @@
mapscript_create_shape((shapeObj*)internal_object, p, layer, *php_object_storage TSRMLS_CC);
else if (ce == mapscript_ce_layer)
mapscript_create_layer((layerObj*)internal_object, p, *php_object_storage TSRMLS_CC);
+ else if (ce == mapscript_ce_cluster)
+ mapscript_create_cluster((clusterObj*)internal_object, p, *php_object_storage TSRMLS_CC);
MAPSCRIPT_ADDREF(*php_object_storage);
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2011-04-04 16:42:42 UTC (rev 11455)
+++ trunk/mapserver/mapserver.h 2011-04-04 17:50:20 UTC (rev 11456)
@@ -1761,8 +1761,6 @@
MS_DLL_EXPORT int msUpdateScalebarFromString(scalebarObj *scalebar, char *string, int url_string);
MS_DLL_EXPORT int msUpdateQueryMapFromString(queryMapObj *querymap, char *string, int url_string);
MS_DLL_EXPORT int msUpdateLabelFromString(labelObj *label, char *string);
-MS_DLL_EXPORT void initCluster(clusterObj *cluster);
-MS_DLL_EXPORT void freeCluster(clusterObj *cluster);
MS_DLL_EXPORT int msUpdateClusterFromString(clusterObj *cluster, char *string);
MS_DLL_EXPORT int msUpdateReferenceMapFromString(referenceMapObj *ref, char *string, int url_string);
MS_DLL_EXPORT int msUpdateLegendFromString(legendObj *legend, char *string, int url_string);
More information about the mapserver-commits
