[mapserver-commits] r11457 - trunk/docs/en/mapscript/php
Mon Apr 4 14:07:13 EDT 2011
Author: aboudreault
Date: 2011-04-04 11:07:13 -0700 (Mon, 04 Apr 2011)
New Revision: 11457
   trunk/docs/en/mapscript/php/index.txt
Added php/mapscript documentation for the new clusterObj
Modified: trunk/docs/en/mapscript/php/index.txt
--- trunk/docs/en/mapscript/php/index.txt	2011-04-04 17:50:20 UTC (rev 11456)
+++ trunk/docs/en/mapscript/php/index.txt	2011-04-04 18:07:13 UTC (rev 11457)
@@ -118,7 +118,7 @@
 Connection Types
     MS_INLINE, MS_SHAPEFILE, MS_TILED_SHAPEFILE, MS_SDE, MS_OGR,
     MS_TILED_OGR, MS_POSTGIS, MS_WMS, MS_ORACLESPATIAL, MS_WFS,
-    MS_GRATICULE, MS_MYGIS, MS_RASTER, MS_PLUGIN
+    MS_GRATICULE, MS_RASTER, MS_PLUGIN, MS_UNION
 Error codes
     MS_NOERR, MS_IOERR, MS_MEMERR, MS_TYPEERR, MS_SYMERR,
@@ -2541,6 +2541,40 @@
     Free the object properties and break the internal references.
     Note that you have to unset the php variable to free totally the resources.
+clusterObj
+Constructor
+Instance of clusterObj is always embedded inside the `layerObj`_.
+Members
+Type                Name
+double          maxdistance
+double          buffer
+string          region
+Methods
+int setGroup(string expression)
+    Set layer group :ref:`expression <expressions>`.
+string getGroupString()
+    Returns the :ref:`expression <expressions>` for this cluster group or NULL on error.
+int setFilter(string expression)
+    Set layer filter :ref:`expression <expressions>`.
+string getFilterString()
+    Returns the :ref:`expression <expressions>` for this cluster filter or NULL on error.
  Memory Management
