[mapserver-commits] r11460 - trunk/mapserver/mapscript/php
Tue Apr 5 08:44:11 EDT 2011
Author: aboudreault
Date: 2011-04-05 05:44:11 -0700 (Tue, 05 Apr 2011)
New Revision: 11460
Added:
   trunk/mapserver/mapscript/php/cluster.c
added missing php/cluster.c file
Added: trunk/mapserver/mapscript/php/cluster.c
--- trunk/mapserver/mapscript/php/cluster.c	                        (rev 0)
+++ trunk/mapserver/mapscript/php/cluster.c	2011-04-05 12:44:11 UTC (rev 11460)
@@ -0,0 +1,336 @@
+ * $Id: php_mapscript.c 9765 2010-01-28 15:32:10Z aboudreault $
+ * Project:  MapServer
+ * Purpose:  PHP/MapScript extension for MapServer.  External interface
+ *           functions
+ * Author:   Daniel Morissette, DM Solutions Group (dmorissette at dmsolutions.ca)
+ *           Alan Boudreault, Mapgears
+ * Copyright (c) 2000-2010, Daniel Morissette, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included in
+ * all copies of this Software or works derived from this Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+#include "php_mapscript.h"
+zend_class_entry *mapscript_ce_cluster;
+ZEND_BEGIN_ARG_INFO_EX(cluster___get_args, 0, 0, 1)
+  ZEND_ARG_INFO(0, property)
+ZEND_END_ARG_INFO()
+ZEND_BEGIN_ARG_INFO_EX(cluster___set_args, 0, 0, 2)
+  ZEND_ARG_INFO(0, value)
+ZEND_BEGIN_ARG_INFO_EX(cluster_updateFromString_args, 0, 0, 1)
+  ZEND_ARG_INFO(0, snippet)
+ZEND_BEGIN_ARG_INFO_EX(cluster_setGroup_args, 0, 0, 1)
+  ZEND_ARG_INFO(0, group)
+ZEND_BEGIN_ARG_INFO_EX(cluster_setFilter_args, 0, 0, 1)
+  ZEND_ARG_INFO(0, filter)
+/* {{{ proto outputformat __construct()
+   clusterObj CANNOT be instanciated, this will throw an exception on use */
+PHP_METHOD(clusterObj, __construct)
+    mapscript_throw_exception("clusterObj cannot be constructed" TSRMLS_CC);
+PHP_METHOD(clusterObj, __get)
+    char *property;
+    long property_len;
+    zval *zobj = getThis();
+    php_cluster_object *php_cluster;
+    PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
+    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "s",
+                              &property, &property_len) == FAILURE) {
+        PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
+        return;
+    php_cluster = (php_cluster_object *) zend_object_store_get_object(zobj TSRMLS_CC);
+    IF_GET_DOUBLE("maxdistance", php_cluster->cluster->maxdistance)
+    else IF_GET_DOUBLE("buffer", php_cluster->cluster->buffer)
+    else IF_GET_STRING("region", php_cluster->cluster->region)
+    else
+        mapscript_throw_exception("Property '%s' does not exist in this object." TSRMLS_CC, property);
+PHP_METHOD(clusterObj, __set)
+    char *property;
+    zval *value;
+    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "sz",
+                              &property, &property_len, &value) == FAILURE) {
+        return;
+    IF_SET_DOUBLE("maxdistance", php_cluster->cluster->maxdistance, value)
+    else IF_SET_DOUBLE("buffer", php_cluster->cluster->buffer, value)
+    else IF_SET_STRING("region", php_cluster->cluster->region, value)
+    else
+/* {{{ proto int updateFromString(string snippet)
+   Update a cluster from a string snippet.  Returns MS_SUCCESS/MS_FAILURE */
+PHP_METHOD(clusterObj, updateFromString)
+    char *snippet;
+    long snippet_len;
+    int status = MS_FAILURE;
+                              &snippet, &snippet_len) == FAILURE) {
+        return;
+    status = clusterObj_updateFromString(php_cluster->cluster, snippet);
+    if (status != MS_SUCCESS)
+        mapscript_throw_mapserver_exception("" TSRMLS_CC);
+        return;
+    RETURN_LONG(status);
+/* {{{ proto int setGroup(string group)
+   Set the group expression string.  Returns MS_SUCCESS/MS_FAILURE */
+PHP_METHOD(clusterObj, setGroup)
+    char *group = NULL;
+    long group_len;
+                              &group, &group_len) == FAILURE) {
+        return;
+    if ((status = clusterObj_setGroup(php_cluster->cluster, group)) != MS_SUCCESS)
+        return;
+/* {{{ proto string cluster.getGroupString()
+   Return the cluster's group expression. Returns NULL on error. */
+PHP_METHOD(clusterObj, getGroupString)
+    char *value = NULL;
+    if (zend_parse_parameters_none() == FAILURE) {
+        return;
+    value = clusterObj_getGroupString(php_cluster->cluster);
+    if (value == NULL)
+        RETURN_NULL();
+    RETVAL_STRING(value, 1);
+    free(value);
+/* {{{ proto int setFilter(string filter)
+   Set the filter expression string.  Returns MS_SUCCESS/MS_FAILURE */
+PHP_METHOD(clusterObj, setFilter)
+    char *filter = NULL;
+    long filter_len;
+                              &filter, &filter_len) == FAILURE) {
+        return;
+    if ((status = clusterObj_setFilter(php_cluster->cluster, filter)) != MS_SUCCESS)
+        return;
+/* {{{ proto string cluster.getFilterString()
+   Return the cluster's filter expression. Returns NULL on error. */
+PHP_METHOD(clusterObj, getFilterString)
+        return;
+    value = clusterObj_getFilterString(php_cluster->cluster);
+        RETURN_NULL();
+    free(value);
+zend_function_entry cluster_functions[] = {
+    PHP_ME(clusterObj, __construct, NULL, ZEND_ACC_PUBLIC|ZEND_ACC_CTOR)
+    PHP_ME(clusterObj, __get, cluster___get_args, ZEND_ACC_PUBLIC)
+    PHP_ME(clusterObj, __set, cluster___set_args, ZEND_ACC_PUBLIC)
+    PHP_ME(clusterObj, updateFromString, cluster_updateFromString_args, ZEND_ACC_PUBLIC)
+    PHP_ME(clusterObj, setGroup, cluster_setGroup_args, ZEND_ACC_PUBLIC)
+    PHP_ME(clusterObj, getGroupString, NULL, ZEND_ACC_PUBLIC)
+    PHP_ME(clusterObj, setFilter, cluster_setFilter_args, ZEND_ACC_PUBLIC)
+    PHP_ME(clusterObj, getFilterString, NULL, ZEND_ACC_PUBLIC)
+    {NULL, NULL, NULL}
+void mapscript_create_cluster(clusterObj *cluster, parent_object parent, zval *return_value TSRMLS_DC)
+    php_cluster_object * php_cluster;
+    object_init_ex(return_value, mapscript_ce_cluster);
+    php_cluster = (php_cluster_object *)zend_object_store_get_object(return_value TSRMLS_CC);
+    php_cluster->cluster = cluster;
+    if (parent.val)
+        php_cluster->is_ref = 1;
+    php_cluster->parent = parent;
+    MAPSCRIPT_ADDREF(parent.val);
+static void mapscript_cluster_object_destroy(void *object TSRMLS_DC)
+    php_cluster_object *php_cluster = (php_cluster_object *)object;
+    MAPSCRIPT_FREE_OBJECT(php_cluster);
+    MAPSCRIPT_FREE_PARENT(php_cluster->parent);
+    /* We don't need to free the clusterObj */
+    efree(object);
+static zend_object_value mapscript_cluster_object_new(zend_class_entry *ce TSRMLS_DC)
+    zend_object_value retval;
+    MAPSCRIPT_ALLOC_OBJECT(php_cluster, php_cluster_object);
+    retval = mapscript_object_new(&php_cluster->std, ce,
+                                  &mapscript_cluster_object_destroy TSRMLS_CC);
+    php_cluster->is_ref = 0;
+    MAPSCRIPT_INIT_PARENT(php_cluster->parent)
+    return retval;
+PHP_MINIT_FUNCTION(cluster)
+    zend_class_entry ce;
+    MAPSCRIPT_REGISTER_CLASS("clusterObj",
+                             cluster_functions,
+                             mapscript_ce_cluster,
+                             mapscript_cluster_object_new);
+    mapscript_ce_cluster->ce_flags |= ZEND_ACC_FINAL_CLASS;
+    return SUCCESS;
