[mapserver-commits] r11461 - in trunk/mapserver: . xmlmapfile
xmlmapfile/tests
svn at osgeo.org
svn at osgeo.org
Tue Apr 5 09:01:09 EDT 2011
Author: aboudreault
Date: 2011-04-05 06:01:09 -0700 (Tue, 05 Apr 2011)
New Revision: 11461
trunk/mapserver/HISTORY.TXT
trunk/mapserver/xmlmapfile/mapfile.xsd
trunk/mapserver/xmlmapfile/mapfile.xsl
trunk/mapserver/xmlmapfile/tests/layerset.xml
trunk/mapserver/xmlmapfile/tests/mapfile-test.xml
Updated xml mapfile schema and xsl with the new lexer properties (#3735)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-04-05 12:44:11 UTC (rev 11460)
+++ trunk/mapserver/HISTORY.TXT 2011-04-05 13:01:09 UTC (rev 11461)
@@ -15,6 +15,8 @@
Current Version (SVN trunk):
+- Updated xml mapfile schema and xsl with the new lexer properties (#3735)
- Updated PHP/MapScript for MS RFC 69: clustering. (#3700)
- Move allocation of cgiRequestObj paramNames/Values to msAllocCgiObj() (#1888)
Modified: trunk/mapserver/xmlmapfile/mapfile.xsd
--- trunk/mapserver/xmlmapfile/mapfile.xsd 2011-04-05 12:44:11 UTC (rev 11460)
+++ trunk/mapserver/xmlmapfile/mapfile.xsd 2011-04-05 13:01:09 UTC (rev 11461)
@@ -264,7 +264,7 @@
<xs:union memberTypes="ms:angleType ms:attributeType">
<xs:simpleType>
<xs:restriction base="xs:string">
- <xs:pattern value="[aA][uU][tT][oO]|[fF][oO][lL][lL][oO][wW]"/>
+ <xs:pattern value="[aA][uU][tT][oO]|[fF][oO][lL][lL][oO][wW]|[aA][uU][tT][oO]2"/>
<!-- attribute -->
</xs:restriction>
</xs:simpleType>
@@ -272,15 +272,13 @@
</xs:simpleType>
</xs:element>
<xs:element name="antialias" type="ms:booleanEnum" minOccurs="0"/>
- <xs:element name="backgroundColor" type="ms:rgbColorType" minOccurs="0"/>
- <xs:element name="backgroundShadowColor" type="ms:rgbColorType" minOccurs="0"/>
- <xs:element name="backgroundShadowSize" type="ms:sizeType" minOccurs="0"/>
<xs:element name="buffer" type="xs:integer" minOccurs="0"/>
<xs:choice minOccurs="0">
<xs:element name="color" type="ms:rgbColorType"/>
<xs:element name="colorAttribute" type="ms:attributeType"/>
</xs:choice>
<xs:element name="encoding" minOccurs="0"/>
+ <xs:element name="maxoverlapangle" minOccurs="0"/>
<xs:element name="font" type="xs:string" minOccurs="0"/>
<xs:element name="force" type="ms:booleanEnum" default="FALSE" minOccurs="0"/>
<xs:element name="maxLength" type="xs:integer" default="0" minOccurs="0"/>
@@ -452,6 +450,7 @@
<xs:enumeration value="ROUND"/>
<xs:enumeration value="SQUARE"/>
<xs:enumeration value="TRIANGLE"/>
+ <xs:enumeration value="SVG"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
@@ -572,12 +571,23 @@
</xs:sequence>
<xs:attribute name="status" type="ms:stateEnum" default="OFF"/>
</xs:complexType>
+ <!-- CLUSTER Definition -->
+ <xs:complexType name="Cluster">
+ <xs:sequence>
+ <xs:element name="buffer" type="xs:positiveInteger" minOccurs="0"/>
+ <xs:element name="filter" type="ms:expressionType" minOccurs="0"/>
+ <xs:element name="group" type="ms:expressionType" minOccurs="0"/>
+ <xs:element name="maxdistance" type="xs:positiveInteger" minOccurs="0"/>
+ <xs:element name="region" type="xs:string" minOccurs="0"/>
+ </xs:sequence>
+ </xs:complexType>
<!-- LAYER Definition -->
<xs:complexType name="Layer">
<xs:sequence>
<xs:element name="Class" type="ms:Class" minOccurs="0" maxOccurs="unbounded"/>
<xs:element name="classGroup" type="xs:string" minOccurs="0"/>
<xs:element name="classItem" type="xs:string" minOccurs="0"/>
+ <xs:element name="Cluster" type="ms:Cluster" minOccurs="0"/>
<xs:element name="connection" type="xs:string" minOccurs="0"/>
<xs:element name="connectionType" minOccurs="0">
<xs:simpleType>
@@ -589,6 +599,7 @@
<xs:enumeration value="ORACLESPATIAL"/>
<xs:enumeration value="WMS"/>
<xs:enumeration value="PLUGIN"/>
+ <xs:enumeration value="UNION"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
Modified: trunk/mapserver/xmlmapfile/mapfile.xsl
--- trunk/mapserver/xmlmapfile/mapfile.xsl 2011-04-05 12:44:11 UTC (rev 11460)
+++ trunk/mapserver/xmlmapfile/mapfile.xsl 2011-04-05 13:01:09 UTC (rev 11461)
@@ -148,7 +148,7 @@
<xsl:apply-templates select="ms:Map"/>
</xsl:template>
-<xsl:template match="ms:color | ms:backgroundColor | ms:outlineColor | ms:backgroundShadowColor | ms:shadowColor | ms:imageColor | ms:offsite">
+<xsl:template match="ms:color | ms:backgroundColor | ms:outlineColor | ms:shadowColor | ms:imageColor | ms:offsite">
<xsl:param name="indent"/>
<xsl:choose>
<xsl:when test="starts-with(name(), 'ms:')">
@@ -175,7 +175,7 @@
</xsl:call-template>
</xsl:template>
-<xsl:template match="ms:size | ms:offset | ms:keySize | ms:keySpacing | ms:backgroundShadowSize | ms:shadowSize">
+<xsl:template match="ms:size | ms:offset | ms:keySize | ms:keySpacing | ms:shadowSize">
<xsl:choose>
@@ -589,19 +589,14 @@
<xsl:with-param name="indent" select="$indent"/>
<xsl:with-param name="node" select="'ms:antialias'"/>
- <xsl:apply-templates select="ms:backgroundColor">
- <xsl:with-param name="indent" select="$indent"/>
- </xsl:apply-templates>
- <xsl:apply-templates select="ms:backgroundShadowColor">
- <xsl:apply-templates select="ms:backgroundShadowSize">
<xsl:call-template name="print">
<xsl:with-param name="node" select="'ms:buffer'"/>
+ <xsl:call-template name="print">
+ <xsl:with-param name="indent" select="$indent"/>
+ <xsl:with-param name="node" select="'ms:maxoverlapangle'"/>
+ </xsl:call-template>
<xsl:apply-templates select="ms:color">
@@ -1288,6 +1283,9 @@
<xsl:with-param name="node" select="'ms:postLabelCache'"/>
+ <xsl:apply-templates select="ms:Cluster">
+ <xsl:with-param name="indent" select="$indent + 1"/>
+ </xsl:apply-templates>
<xsl:for-each select="ms:processing">
@@ -1356,6 +1354,39 @@
<xsl:with-param name="indent" select="$indent - 1"/>
</xsl:template>
+ <xsl:template match="ms:Cluster">
+ <xsl:param name="indent"/>
+ <xsl:with-param name="text" select="'CLUSTER'"/>
+ <xsl:with-param name="indent" select="$indent - 1"/>
+ <xsl:with-param name="node" select="'ms:maxdistance'"/>
+ <xsl:with-param name="node" select="'ms:buffer'"/>
+ <xsl:with-param name="node" select="'ms:region'"/>
+ <xsl:with-param name="quote" select="1"/>
+ <xsl:call-template name="printExpression">
+ <xsl:with-param name="node" select="'ms:group'"/>
+ <xsl:with-param name="node" select="'ms:filter'"/>
+ <xsl:with-param name="text" select="'END
+ </xsl:template>
<xsl:template match="ms:SymbolSet">
<xsl:param name="indent" select="0"/>
Modified: trunk/mapserver/xmlmapfile/tests/layerset.xml
--- trunk/mapserver/xmlmapfile/tests/layerset.xml 2011-04-05 12:44:11 UTC (rev 11460)
+++ trunk/mapserver/xmlmapfile/tests/layerset.xml 2011-04-05 13:01:09 UTC (rev 11461)
@@ -10,11 +10,8 @@
<keyImage>/home/myusername/layer1.png</keyImage>
<Label type="TRUETYPE">
<align>LEFT</align>
- <angle>12</angle>
+ <angle>AUTO2</angle>
<antialias>TRUE</antialias>
- <backgroundColor red="244" green="43" blue="22"/>
- <backgroundShadowColor red="244" green="43" blue="22"/>
- <backgroundShadowSize x="2" y="2"/>
<buffer>2</buffer>
<colorAttribute>[myColor]</colorAttribute>
<encoding>ISO 8859-1</encoding>
@@ -65,6 +62,13 @@
</Class>
<classGroup>group1</classGroup>
<classItem>population</classItem>
+ <Cluster>
+ <buffer>2</buffer>
+ <filter type="MSEXPR">(type=’road’ and size < 2)</filter>
+ <group type="REGEX">/ddea/i</group>
+ <maxdistance>20</maxdistance>
+ <region>region1</region>
+ </Cluster>
<connection>user=nobody password=****** dbname=dbname host=localhost port=5432</connection>
<connectionType>SDE</connectionType>
<data>../data</data>
Modified: trunk/mapserver/xmlmapfile/tests/mapfile-test.xml
--- trunk/mapserver/xmlmapfile/tests/mapfile-test.xml 2011-04-05 12:44:11 UTC (rev 11460)
+++ trunk/mapserver/xmlmapfile/tests/mapfile-test.xml 2011-04-05 13:01:09 UTC (rev 11461)
@@ -66,7 +66,7 @@
<driver>AGG/PNG</driver>
<extension>png</extension>
<formatOption>TILED=YES</formatOption>
- <imageMode>RGB</imageMode>
+ <imageMode>RGBA</imageMode>
<mimeType>image/png</mimeType>
<transparent>ON</transparent>
</OutputFormat>
More information about the mapserver-commits
