[mapserver-commits] r11466 - trunk/docs/en/mapscript/php
svn at osgeo.org
svn at osgeo.org
Tue Apr 5 11:27:16 EDT 2011
Author: aboudreault
Date: 2011-04-05 08:27:16 -0700 (Tue, 05 Apr 2011)
New Revision: 11466
trunk/docs/en/mapscript/php/index.txt
Updated documentation of PHP/MapScript with the new object properties (#3537)
Modified: trunk/docs/en/mapscript/php/index.txt
--- trunk/docs/en/mapscript/php/index.txt 2011-04-05 15:18:00 UTC (rev 11465)
+++ trunk/docs/en/mapscript/php/index.txt 2011-04-05 15:27:16 UTC (rev 11466)
@@ -136,7 +136,7 @@
Image Mode types (:ref:`outputFormatObj <outputformat>`)
MS_IMAGEMODE_PC256, MS_IMAGEMODE_RGB, MS_IMAGEMODE_RGBA,
MS_IMAGEMODE_INT16, MS_IMAGEMODE_FLOAT32, MS_IMAGEMODE_BYTE,
- MS_IMAGEMODE_NULL
+ MS_IMAGEMODE_FEATURE, MS_IMAGEMODE_NULL
Style/Attribue binding
MS_STYLE_BINDING_SIZE, MS_STYLE_BINDING_ANGLE, MS_STYLE_BINDING_COLOR,
@@ -145,7 +145,8 @@
Label/Attribute binding
MS_LABEL_BINDING_SIZE, MS_LABEL_BINDING_ANGLE, MS_LABEL_BINDING_COLOR,
MS_LABEL_BINDING_OUTLINECOLOR, MS_LABEL_BINDING_FONT,
- MS_LABEL_BINDING_PRIORITY
+ MS_LABEL_BINDING_PRIORITY, MS_LABEL_BINDING_POSITION,
+ MS_LABEL_BINDING_SHADOWSIZEX, MS_LABEL_BINDING_SHADOWSIZEY
Alignment
MS_ALIGN_LEFT, MS_ALIGN_CENTER, MS_ALIGN_RIGHT
@@ -503,6 +504,8 @@
int width (read-only)
int height (read-only)
+int resolution (read-only)
+int resolutionfactor (read-only)
string imagepath
string imageurl
@@ -559,6 +562,7 @@
int numstyles (Read-Only)
int shapeindex (Read-Only)
int status (Read-Only)
+int markerid (Read-Only)
string text (Read-Only)
int tileindex (Read-Only)
@@ -722,6 +726,7 @@
double labelminscaledenom
double labelmaxscaledenom
int maxfeatures
+int startindex
colorObj offsite
int annotate
int transform
@@ -743,6 +748,7 @@
string requires
string labelrequires
hashTableObj metadata
+hashTableObj bindvals
projectionObj projection
clusterObj cluster
@@ -2512,6 +2518,7 @@
string log
string imagepath
+string temppath
string template
string imageurl
string header
More information about the mapserver-commits
