[mapserver-commits] r11467 - trunk/mapserver
Tue Apr 5 14:31:19 EDT 2011
Author: aboudreault
Date: 2011-04-05 11:31:19 -0700 (Tue, 05 Apr 2011)
New Revision: 11467
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapdraw.c
   trunk/mapserver/maplegend.c
Add opacity to legend (#3740)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-04-05 15:27:16 UTC (rev 11466)
+++ trunk/mapserver/HISTORY.TXT	2011-04-05 18:31:19 UTC (rev 11467)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk):
+- Add opacity to legend (#3740)
 - Updated PHP/MapScript with the new objects properties (#3735)
 - KML: set layeer's projection when it is not defined (#3809)
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2011-04-05 15:27:16 UTC (rev 11466)
+++ trunk/mapserver/mapdraw.c	2011-04-05 18:31:19 UTC (rev 11467)
@@ -741,7 +741,7 @@
       altrenderer->getRasterBufferHandle(image_draw,&rb);
       renderer->mergeRasterBuffer(image,&rb,layer->opacity*0.01,0,0,0,0,rb.width,rb.height);
-      altrenderer->freeImage( image_draw );
+      msFreeImage(image_draw);
   else if( image != image_draw) {
@@ -754,7 +754,7 @@
-	  renderer->freeImage( image_draw );
 	  /* deref and possibly free temporary transparent output format.  */
 	  msApplyOutputFormat( &transFormat, NULL, MS_NOOVERRIDE, MS_NOOVERRIDE, MS_NOOVERRIDE );
Modified: trunk/mapserver/maplegend.c
--- trunk/mapserver/maplegend.c	2011-04-05 15:27:16 UTC (rev 11466)
+++ trunk/mapserver/maplegend.c	2011-04-05 18:31:19 UTC (rev 11467)
@@ -49,14 +49,46 @@
   pointObj marker;
   char szPath[MS_MAXPATHLEN];
   styleObj outline_style;
+  imageObj *image_draw = image;
+  int originalopacity = lp->opacity;
   rendererVTableObj *renderer;
+  outputFormatObj *transFormat = NULL, *altFormat=NULL;
+  const char *alternativeFormatString = NULL;
   if(!MS_RENDERER_PLUGIN(image->format)) {
       msSetError(MS_MISCERR,"unsupported image format","msDrawLegendIcon()");
       return MS_FAILURE;
+  alternativeFormatString = msLayerGetProcessingKey(lp, "RENDERER");
+  if (MS_RENDERER_PLUGIN(image_draw->format) && alternativeFormatString!=NULL &&
+      (altFormat=  msSelectOutputFormat(map, alternativeFormatString)))
+      msInitializeRendererVTable(altFormat);
+      image_draw = msImageCreate(image->width, image->height,
+                                 altFormat, image->imagepath, image->imageurl, map->resolution, map->defresolution, &map->imagecolor);
+      renderer = MS_IMAGE_RENDERER(image_draw);
+  else if (MS_RENDERER_PLUGIN(image_draw->format)) {
+      if (lp->opacity > 0 && lp->opacity < 100) {
+          if (!renderer->supports_transparent_layers) {
+              msApplyOutputFormat(&transFormat, image->format, MS_TRUE,
+                                  MS_NOOVERRIDE,MS_NOOVERRIDE);
+                                         transFormat, image->imagepath, image->imageurl, map->resolution, map->defresolution, NULL);
+              if (!image_draw) {
+                  msSetError(MS_MISCERR, "Unable to initialize temporary transparent image.",
+                             "msDrawLegendIcon()");
+                  return (MS_FAILURE);
+              /* set opacity to full, as the renderer should be rendering a fully opaque image */
+              lp->opacity=100;
-  renderer = MS_IMAGE_RENDERER(image);
   if(renderer->supports_clipping && MS_VALID_COLOR(map->legend.outlinecolor)) {
     /* keep GD specific code here for now as it supports clipping */
@@ -65,7 +97,7 @@
     clip.maxy = dstY + height -1;
     clip.minx = dstX;
     clip.miny = dstY;
-    renderer->setClip(image,clip);
+    renderer->setClip(image_draw,clip);
   /* initialize the box used for polygons and for outlines */
@@ -113,7 +145,7 @@
     marker.y = dstY + MS_NINT(height / 2.0);
     if (theclass->numstyles > 0) {
       for(i=0; i<theclass->numstyles; i++)
-        msDrawMarkerSymbol(&map->symbolset, image, &marker, theclass->styles[i], lp->scalefactor);
+        msDrawMarkerSymbol(&map->symbolset, image_draw, &marker, theclass->styles[i], lp->scalefactor);
     } else if (theclass->label.size!=-1) {
       labelObj label = theclass->label;
       double lsize = label.size;
@@ -122,7 +154,7 @@
       label.angle = 0;
       label.position = MS_CC;
       if (label.type == MS_TRUETYPE) label.size = height;
-      msDrawLabel(map, image, marker, (char*)"Az", &label,1.0);
+      msDrawLabel(map, image_draw, marker, (char*)"Az", &label,1.0);
       label.size = lsize;
       label.position = lpos;
       label.angle = langle;
@@ -154,11 +186,11 @@
         imgStyle.maxsize = imgStyle.size;
       imgStyle.symbol = symbolNum;
-      msDrawMarkerSymbol(&map->symbolset,image,&marker,&imgStyle,lp->scalefactor);
+      msDrawMarkerSymbol(&map->symbolset,image_draw,&marker,&imgStyle,lp->scalefactor);
       /* TO DO: we may want to handle this differently depending on the relative size of the keyimage */
     } else {
     break;
   case MS_LAYER_LINE:
@@ -182,7 +214,7 @@
     zigzag.line[0].point[3].y = dstY + offset;
-      msDrawLineSymbol(&map->symbolset, image, &zigzag, theclass->styles[i], lp->scalefactor);
+      msDrawLineSymbol(&map->symbolset, image_draw, &zigzag, theclass->styles[i], lp->scalefactor);
     free(zigzag.line[0].point);
     free(zigzag.line);
@@ -192,7 +224,7 @@
   case MS_LAYER_CHART:
   case MS_LAYER_POLYGON:
-      msDrawShadeSymbol(&map->symbolset, image, &box, theclass->styles[i], lp->scalefactor);
+      msDrawShadeSymbol(&map->symbolset, image_draw, &box, theclass->styles[i], lp->scalefactor);
     break;
   default:
     return MS_FAILURE;
@@ -203,12 +235,40 @@
   if(MS_VALID_COLOR(map->legend.outlinecolor)) {
     initStyle(&outline_style);
     outline_style.color = map->legend.outlinecolor;
-    msDrawLineSymbol(&map->symbolset, image, &box, &outline_style, 1.0);
+    msDrawLineSymbol(&map->symbolset, image_draw, &box, &outline_style, 1.0);
     /* reset clipping rectangle */
     if(renderer->supports_clipping)
-    	renderer->resetClip(image);
+    	renderer->resetClip(image_draw);
+  if (altFormat)
+      rendererVTableObj *renderer = MS_IMAGE_RENDERER(image);
+      rendererVTableObj *altrenderer = MS_IMAGE_RENDERER(image_draw);
+      rasterBufferObj rb;
+      memset(&rb,0,sizeof(rasterBufferObj));
+      altrenderer->getRasterBufferHandle(image_draw,&rb);
+      renderer->mergeRasterBuffer(image,&rb,lp->opacity*0.01,0,0,0,0,rb.width,rb.height);
+  else if(image != image_draw) {
+	  rendererVTableObj *renderer = MS_IMAGE_RENDERER(image_draw);
+	  lp->opacity = originalopacity;
+	  renderer->getRasterBufferHandle(image_draw,&rb);
+	  /* deref and possibly free temporary transparent output format.  */
+	  msApplyOutputFormat( &transFormat, NULL, MS_NOOVERRIDE, MS_NOOVERRIDE, MS_NOOVERRIDE );
   free(box.line[0].point);
   free(box.line);
