[mapserver-commits] r11468 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Apr 5 15:42:39 EDT 2011
Author: assefa
Date: 2011-04-05 12:42:39 -0700 (Tue, 05 Apr 2011)
New Revision: 11468
trunk/mapserver/mapkmlrenderer.cpp
trunk/mapserver/mapkmlrenderer.h
Add ows/kml_exclude_items (#3560)
Modified: trunk/mapserver/mapkmlrenderer.cpp
--- trunk/mapserver/mapkmlrenderer.cpp 2011-04-05 18:31:19 UTC (rev 11467)
+++ trunk/mapserver/mapkmlrenderer.cpp 2011-04-05 19:42:39 UTC (rev 11468)
@@ -51,6 +51,8 @@
pszLayerDescMetadata = NULL;
papszLayerIncludeItems = NULL;
nIncludeItems=0;
+ papszLayerExcludeItems = NULL;
+ nExcludeItems=0;
pszLayerNameAttributeMetadata = NULL; /*metadata to use for a name for each feature*/
LineStyle = NULL;
@@ -222,7 +224,7 @@
return;
/*turn of labelcache*/
- //layer->labelcache = MS_OFF;
+ layer->labelcache = MS_OFF;
/*if there are labels we want the coordinates to
be the center of the element.*/
@@ -377,6 +379,13 @@
if (value)
papszLayerIncludeItems = msStringSplit(value, ',', &nIncludeItems);
+ value=msLookupHashTable(&layer->metadata, "kml_exclude_items");
+ if (!value)
+ value=msLookupHashTable(&layer->metadata, "ows_exclude_items");
+ if (value)
+ papszLayerExcludeItems = msStringSplit(value, ',', &nExcludeItems);
if (msLookupHashTable(&layer->metadata, "kml_name_item"))
pszLayerNameAttributeMetadata = msLookupHashTable(&layer->metadata, "kml_name_item");
@@ -430,8 +439,12 @@
if (papszLayerIncludeItems && nIncludeItems>0)
msFreeCharArray(papszLayerIncludeItems, nIncludeItems);
+ papszLayerIncludeItems=NULL;
- papszLayerIncludeItems=NULL;
+ if (papszLayerExcludeItems && nExcludeItems>0)
+ msFreeCharArray(papszLayerExcludeItems, nExcludeItems);
+ papszLayerExcludeItems=NULL;
return MS_SUCCESS;
@@ -1252,7 +1265,8 @@
msFree(pszTmpDesc);
return descriptionNode;
- else if (papszLayerIncludeItems && nIncludeItems > 0)
+ else if ((papszLayerIncludeItems && nIncludeItems > 0) ||
+ (papszLayerExcludeItems && nExcludeItems > 0))
/* preffered way is to use the ExtendedData tag (#3728) */
@@ -1262,30 +1276,47 @@
xmlNodePtr extendedDataNode = xmlNewNode(NULL, BAD_CAST "ExtendedData");
xmlNodePtr dataNode = NULL;
const char*pszAlias=NULL;
+ int bIncludeAll = MS_FALSE;
+ if(papszLayerIncludeItems && nIncludeItems == 1 &&
+ strcasecmp(papszLayerIncludeItems[0], "all") == 0)
+ bIncludeAll = MS_TRUE;
for (int i=0; i<currentLayer->numitems; i++)
- int j=0;
+ int j=0,k=0;
/*TODO optimize to calculate this only once per layer*/
for (j=0; j<nIncludeItems;j++)
if (strcasecmp(currentLayer->items[i], papszLayerIncludeItems[j]) == 0)
break;
- if (j<nIncludeItems)
+ if (j<nIncludeItems || bIncludeAll)
- dataNode = xmlNewNode(NULL, BAD_CAST "Data");
- xmlNewProp(dataNode, BAD_CAST "name", BAD_CAST currentLayer->items[i]);
- pszAlias = getAliasName(currentLayer, currentLayer->items[i], "GO");
- if (pszAlias)
- xmlNewChild(dataNode, NULL, BAD_CAST "displayName", BAD_CAST pszAlias);
- else
- xmlNewChild(dataNode, NULL, BAD_CAST "displayName", BAD_CAST currentLayer->items[i]);
- if (shape->values[i] && strlen(shape->values[i]))
- xmlNewChild(dataNode, NULL, BAD_CAST "value", BAD_CAST shape->values[i]);
- else
- xmlNewChild(dataNode, NULL, BAD_CAST "value", NULL);
- xmlAddChild(extendedDataNode, dataNode);
+ if (papszLayerExcludeItems && nExcludeItems > 0)
+ for (k=0; k<nExcludeItems;k++)
+ if (strcasecmp(currentLayer->items[i], papszLayerExcludeItems[k]) == 0)
+ break;
+ if (nExcludeItems == 0 || k == nExcludeItems)
+ dataNode = xmlNewNode(NULL, BAD_CAST "Data");
+ xmlNewProp(dataNode, BAD_CAST "name", BAD_CAST currentLayer->items[i]);
+ pszAlias = getAliasName(currentLayer, currentLayer->items[i], "GO");
+ if (pszAlias)
+ xmlNewChild(dataNode, NULL, BAD_CAST "displayName", BAD_CAST pszAlias);
+ else
+ xmlNewChild(dataNode, NULL, BAD_CAST "displayName", BAD_CAST currentLayer->items[i]);
+ if (shape->values[i] && strlen(shape->values[i]))
+ xmlNewChild(dataNode, NULL, BAD_CAST "value", BAD_CAST shape->values[i]);
+ else
+ xmlNewChild(dataNode, NULL, BAD_CAST "value", NULL);
+ xmlAddChild(extendedDataNode, dataNode);
Modified: trunk/mapserver/mapkmlrenderer.h
--- trunk/mapserver/mapkmlrenderer.h 2011-04-05 18:31:19 UTC (rev 11467)
+++ trunk/mapserver/mapkmlrenderer.h 2011-04-05 19:42:39 UTC (rev 11468)
@@ -43,6 +43,8 @@
const char *pszLayerDescMetadata; /*if the kml_description is set*/
char **papszLayerIncludeItems;
int nIncludeItems;
+ char **papszLayerExcludeItems;
+ int nExcludeItems;
char *pszLayerNameAttributeMetadata;
protected:
More information about the mapserver-commits
