[mapserver-commits] r11532 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Apr 11 16:19:32 EDT 2011
Author: assefa
Date: 2011-04-11 13:19:32 -0700 (Mon, 11 Apr 2011)
New Revision: 11532
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapows.c
trunk/mapserver/mapwms.c
wms_getmap_formatlist causes first defined outputformat to be returned by getmap (#3826)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-04-11 19:03:34 UTC (rev 11531)
+++ trunk/mapserver/HISTORY.TXT 2011-04-11 20:19:32 UTC (rev 11532)
@@ -15,6 +15,8 @@
Current Version (SVN trunk):
+- wms_getmap_formatlist causes first defined outputformat to be returned by getmap (#3826)
- fix building of mapcluster.c when OGR support is disabled
- fix some valgrind found memory leaks (offset symbols, and gd io contexts)
Modified: trunk/mapserver/mapows.c
--- trunk/mapserver/mapows.c 2011-04-11 19:03:34 UTC (rev 11531)
+++ trunk/mapserver/mapows.c 2011-04-11 20:19:32 UTC (rev 11532)
@@ -2202,6 +2202,7 @@
if (map && format && metadata && namespaces && name)
+ msApplyDefaultOutputFormats(map);
format_list = msOWSLookupMetadata(metadata, namespaces, name);
n = 0;
if ( format_list)
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c 2011-04-11 19:03:34 UTC (rev 11531)
+++ trunk/mapserver/mapwms.c 2011-04-11 20:19:32 UTC (rev 11532)
@@ -671,7 +671,6 @@
else if (strcasecmp(names[i], "FORMAT") == 0) {
const char *format_list = NULL;
- outputFormatObj *psFormat=NULL;
formatfound = 1;
if (strcasecmp(values[i], "application/openlayers")!=0)
@@ -680,9 +679,9 @@
format_list = msOWSLookupMetadata(&(map->web.metadata), "M","getmap_formatlist");
if (format_list)
- psFormat = msOwsIsOutputFormatValid(map, values[i], &(map->web.metadata),
- "M", "getmap_formatlist");
- if (psFormat == NULL &&
+ format = msOwsIsOutputFormatValid(map, values[i], &(map->web.metadata),
+ "M", "getmap_formatlist");
+ if (format == NULL &&
msSetError(MS_IMGERR,
More information about the mapserver-commits
