[mapserver-commits] r11533 - in trunk/docs/en: images mapfile
Mon Apr 11 18:03:18 EDT 2011
Author: jmckenna
Date: 2011-04-11 15:03:18 -0700 (Mon, 11 Apr 2011)
New Revision: 11533
Added:
   trunk/docs/en/images/union.png
   trunk/docs/en/mapfile/union.txt
   trunk/docs/en/mapfile/index.txt
enhance new connectiontype union doc
Added: trunk/docs/en/images/union.png
(Binary files differ)
Property changes on: trunk/docs/en/images/union.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: trunk/docs/en/mapfile/index.txt
--- trunk/docs/en/mapfile/index.txt	2011-04-11 20:19:32 UTC (rev 11532)
+++ trunk/docs/en/mapfile/index.txt	2011-04-11 22:03:18 UTC (rev 11533)
@@ -52,6 +52,7 @@
    symbol
    symbology/examples
    template
+   union
    variable_sub
    web
Added: trunk/docs/en/mapfile/union.txt
--- trunk/docs/en/mapfile/union.txt	                        (rev 0)
+++ trunk/docs/en/mapfile/union.txt	2011-04-11 22:03:18 UTC (rev 11533)
@@ -0,0 +1,178 @@
+.. _union:
+ Union Layer
+:Author: Tamas Szekeres
+:Contact: szekerest at gmail.com
+:Author: Jeff McKenna
+:Contact: jmckenna at gatewaygeomatics.com
+:Last Updated: 2011-04-11
+Description
+Since version 6.0, MapServer has the ability to display features from multiple
+layers (called *'source layers'*) in a single mapfile layer. This feature was
+added through :ref:`rfc68`.
+Requirements
+This is a native MapServer option that doesn't use any external libraries to support it.
+Mapfile Configuration
+* The CONNECTIONTYPE parameter must be set to UNION.
+* The CONNECTION parameter must contain a comma separated list of the source layer names.
+* All of the source layers and the union layer must be the same TYPE (e.g. all must be TYPE
+  POINT, or all TYPE POLYGON etc.)
+.. note::
+    You may wish to disable the visibility (change their STATUS) of the source layers
+    to avoid displaying the features twice.
+Mapfile Example
+.. code-block:: mapfile
+    LAYER
+      NAME "union-layer"
+      TYPE POINT
+      STATUS DEFAULT
+      CONNECTIONTYPE UNION
+      CONNECTION "layer1,layer2,layer3" # reference to the source layers
+      PROCESSING "ITEMS=itemname1,itemname2,itemname3"
+    END
+    LAYER
+      NAME "layer1"
+      TYPE POINT
+      STATUS OFF
+      CONNECTIONTYPE OGR
+      CONNECTION ...
+    END
+    LAYER
+      NAME "layer2"
+      TYPE POINT
+      STATUS OFF
+      CONNECTIONTYPE SHAPE
+      CONNECTION ...
+    END
+    LAYER
+      NAME "layer3"
+      TYPE POINT
+      STATUS OFF
+      CONNECTION ...
+    END
+Feature attributes
+In the LAYER definition you may refer to any attributes supported by each of the source layers.
+In addition to the source layer attributes the union layer provides the following additional attributes:
+1) Combine:SourceLayerName - The name of the source layer the feature belongs to
+2) Combine:SourceLayerGroup - The group of the source layer the feature belongs to
+During the selection / feature query operations only the 'Combine:SourceLayerName' and 'Combine:SourceLayerGroup'
+attributes are provided by default. The set of the provided attributes can manually be overridden
+(and further attributes can be exposed) by using the ITEMS processing option (refer to the example above).
+Classes and Styles
+We can define the symbology and labelling for the union layers in the same way as for
+any other layer by specifying the classes and styles. In addition the STYLEITEM AUTO
+option is also supported for the union layer, which provides to display
+the features as specified at the source layers. The source layers
+may also use the STYLEITEM AUTO setting if the underlying data source provides that.
+Projections
+For speed, it is recommended to always use the same projection for the union layer and source layers. However
+MapServer will reproject the source layers to the union layer if requested.  (for more information on projections
+in MapServer refer to :ref:`PROJECTION`)
+Working Mapfile Example
+The follow example contains 3 source layers in different formats, and one layer (yellow)
+in a different projection.  The union layer uses the **STYLEITEM "AUTO"** parameter to
+draw the styles from the source layers.  (in this case MapServer will reproject the yellow
+features, in EPSG:4326, for the union layer, which is in EPSG:3978).
+  LAYER
+    NAME 'unioned'
+    TYPE POLYGON
+    STATUS DEFAULT
+    CONNECTION "red,green,yellow"
+    STYLEITEM "AUTO"
+    # Define an empty class that will be filled at runtime from the color and
+    # styles read from each source layer.
+    CLASS
+    END
+    PROJECTION
+      "init=epsg:3978"
+    END
+  END
+  LAYER
+    NAME 'red'
+    TYPE POLYGON
+    STATUS OFF
+    DATA 'nb.shp'
+    CLASS
+       NAME 'red'
+       STYLE
+         OUTLINECOLOR 0 0 0
+         COLOR 255 85 0
+       END
+    END
+  END
+  LAYER
+    NAME 'green'
+    TYPE POLYGON
+    STATUS OFF
+    CONNECTION 'ns.mif'
+    CLASS
+       NAME 'green'
+       STYLE
+         COLOR 90 218 71
+       END
+    END
+  END
+  LAYER
+    NAME 'yellow'
+    TYPE POLYGON
+    STATUS OFF
+    CONNECTION 'pei.gml'
+    CLASS
+       NAME 'yellow'
+       STYLE
+         COLOR 255 255 0
+       END
+    END
+    PROJECTION
+      "init=epsg:4326"
+    END
+  END
+.. image:: ../images/union.png
