[mapserver-commits] r11543 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Tue Apr 12 08:12:42 EDT 2011
Author: jmckenna
Date: 2011-04-12 05:12:42 -0700 (Tue, 12 Apr 2011)
New Revision: 11543
trunk/docs/en/mapfile/union.txt
add mapscript example
Modified: trunk/docs/en/mapfile/union.txt
--- trunk/docs/en/mapfile/union.txt 2011-04-12 12:06:42 UTC (rev 11542)
+++ trunk/docs/en/mapfile/union.txt 2011-04-12 12:12:42 UTC (rev 11543)
@@ -10,6 +10,10 @@
:Contact: jmckenna at gatewaygeomatics.com
:Last Updated: 2011-04-11
+.. contents:: Table of Contents
+ :depth: 3
+ :backlinks: top
Description
@@ -34,8 +38,7 @@
You may wish to disable the visibility (change their STATUS) of the source layers
to avoid displaying the features twice.
-Mapfile Example
+For example:
.. code-block:: mapfile
@@ -102,9 +105,12 @@
MapServer will reproject the source layers to the union layer if requested. (for more information on projections
in MapServer refer to :ref:`PROJECTION`)
-Working Mapfile Example
+Examples
+Mapfile Example
The follow example contains 3 source layers in different formats, and one layer (yellow)
in a different projection. The union layer uses the **STYLEITEM "AUTO"** parameter to
draw the styles from the source layers. (in this case MapServer will reproject the yellow
@@ -183,4 +189,29 @@
END
END
- END # Map
\ No newline at end of file
+ END # Map
+PHP MapScript Example
+.. code-block:: php
+ <?php
+ // open map
+ $oMap = ms_newMapObj( "D:/ms4w/apps/osm/map/osm.map" );
+ // create union layer
+ $oLayer = ms_newLayerObj($oMap);
+ $oLayer->set("name", "unioned");
+ $oLayer->set("type", MS_LAYER_POLYGON);
+ $oLayer->set("status", MS_ON);
+ $oLayer->setConnectionType(MS_UNION);
+ $oLayer->set("connection", "red,green,yellow");
+ $oLayer->set("styleitem", "AUTO");
+ $oLayer->setProjection("init=epsg:3978");
+ // create empty class
+ $oClass = ms_newClassObj($oLayer);
More information about the mapserver-commits
