[mapserver-commits] r11544 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Apr 12 08:38:18 EDT 2011
Author: aboudreault
Date: 2011-04-12 05:38:18 -0700 (Tue, 12 Apr 2011)
New Revision: 11544
trunk/mapserver/mapfile.c
trunk/mapserver/mapgml.c
trunk/mapserver/mapwcs.c
trunk/mapserver/mapwfs.c
DUMP shouldn't be needed in OGC request (#3830)
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c 2011-04-12 12:12:42 UTC (rev 11543)
+++ trunk/mapserver/mapfile.c 2011-04-12 12:38:18 UTC (rev 11544)
@@ -3969,7 +3969,6 @@
writeKeyword(stream, indent, "CONNECTIONTYPE", layer->connectiontype, 9, MS_SDE, "SDE", MS_OGR, "OGR", MS_POSTGIS, "POSTGIS", MS_WMS, "WMS", MS_ORACLESPATIAL, "ORACLESPATIAL", MS_WFS, "WFS", MS_GRATICULE, "GRATICULE", MS_PLUGIN, "PLUGIN", MS_UNION, "UNION");
writeString(stream, indent, "DATA", NULL, layer->data);
writeNumber(stream, indent, "DEBUG", 0, layer->debug); /* is this right? see loadLayer() */
- writeKeyword(stream, indent, "DUMP", layer->dump, 1, MS_TRUE, "TRUE");
writeExtent(stream, indent, "EXTENT", layer->extent);
writeExpression(stream, indent, "FILTER", &(layer->filter));
writeString(stream, indent, "FILTERITEM", NULL, layer->filteritem);
Modified: trunk/mapserver/mapgml.c
--- trunk/mapserver/mapgml.c 2011-04-12 12:12:42 UTC (rev 11543)
+++ trunk/mapserver/mapgml.c 2011-04-12 12:38:18 UTC (rev 11544)
@@ -1178,7 +1178,7 @@
const char *pszOutputSRS = NULL;
lp = (GET_LAYER(map, map->layerorder[i]));
- if(lp->dump == MS_TRUE && lp->resultcache && lp->resultcache->numresults > 0) { /* found results */
+ if(lp->resultcache && lp->resultcache->numresults > 0) { /* found results */
#ifdef USE_PROJ
/* Determine output SRS, if map has none, then try using layer's native SRS */
@@ -1410,7 +1410,7 @@
lp = GET_LAYER(map, map->layerorder[i]);
char *layerName;
const char *value;
int featureIdIndex=-1; /* no feature id */
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c 2011-04-12 12:12:42 UTC (rev 11543)
+++ trunk/mapserver/mapwcs.c 2011-04-12 12:38:18 UTC (rev 11544)
@@ -234,8 +234,8 @@
int msWCSIsLayerSupported(layerObj *layer)
- /* only raster layers, with 'DUMP TRUE' explicitly defined, are elligible to be served via WCS, WMS rasters are not ok */
- if(layer->dump && (layer->type == MS_LAYER_RASTER) && layer->connectiontype != MS_WMS) return MS_TRUE;
+ /* only raster layers, are elligible to be served via WCS, WMS rasters are not ok */
+ if((layer->type == MS_LAYER_RASTER) && layer->connectiontype != MS_WMS) return MS_TRUE;
return MS_FALSE;
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c 2011-04-12 12:12:42 UTC (rev 11543)
+++ trunk/mapserver/mapwfs.c 2011-04-12 12:38:18 UTC (rev 11544)
@@ -471,10 +471,8 @@
/* In order to be supported, lp->type must be specified, even for
** layers that are OGR, SDE, SDO, etc connections.
- ** lp->dump must be explicitly set to TRUE in mapfile.
- if (lp->dump &&
- (lp->type == MS_LAYER_POINT ||
+ if ((lp->type == MS_LAYER_POINT ||
lp->type == MS_LAYER_LINE ||
lp->type == MS_LAYER_POLYGON ) &&
lp->connectiontype != MS_WMS &&
@@ -833,7 +831,6 @@
if (!msIntegerInArray(lp->index, ows_request->enabled_layers, ows_request->numlayers))
continue;
- /* List only vector layers in which DUMP=TRUE */
if (msWFSIsLayerSupported(lp))
msWFSDumpLayer(map, lp);
@@ -1946,7 +1943,7 @@
if (!bLayerFound) {
/* Requested layer name was not in capabilities:
- * either it just doesn't exist, or it's missing DUMP TRUE
+ * either it just doesn't exist
msSetError(MS_WFSERR,
"TYPENAME '%s' doesn't exist in this server. Please check the capabilities and reformulate your request.",
More information about the mapserver-commits
