[mapserver-commits] r11605 - trunk/docs/en/output
Wed Apr 20 12:56:02 EDT 2011
Author: tbonfort
Date: 2011-04-20 09:56:01 -0700 (Wed, 20 Apr 2011)
New Revision: 11605
Added:
   trunk/docs/en/output/template_output.txt
   trunk/docs/en/output/index.txt
add documentation for template output (#3838)
Modified: trunk/docs/en/output/index.txt
--- trunk/docs/en/output/index.txt	2011-04-19 21:57:08 UTC (rev 11604)
+++ trunk/docs/en/output/index.txt	2011-04-20 16:56:01 UTC (rev 11605)
@@ -18,5 +18,6 @@
    pdf
    svg
    tile_mode
+   template_output
    kml_output
Added: trunk/docs/en/output/template_output.txt
--- trunk/docs/en/output/template_output.txt	                        (rev 0)
+++ trunk/docs/en/output/template_output.txt	2011-04-20 16:56:01 UTC (rev 11605)
@@ -0,0 +1,295 @@
+.. _template_output:
+ Template-Driven Output
+:Author: Chris Hodgson
+:Contact: chodgson at refractions.net
+:Last Updated: 2011-04-13
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+Introduction
+RFC 36 added support for defining template-driven OUTPUTFORMATs for use with
+feature queries, including WMS GetFeatureInfo and WFS GetFeature. This allows
+for custom text-oriented output such as GeoJSON, KML, or XML.
+The templates are essentially the same as with the standard MapServer query
+:ref:`Template`, however there are some additional tags to allow for template
+definition in a single file instead of the standard header/template/footer.
+.. note::
+    There are other, simpler, ways to output some of these formats using MapServer.
+    However, template-driven output provides maximal flexibility and customization
+    of the output, at the cost of additional complexity and configuration.
+OUTPUTFORMAT Declarations
+Details of template-driven output formats are controlled by an :ref:`OUTPUTFORMAT`
+declaration.  The declarations define the template file to be used, as well as
+other standard OUTPUTFORMAT options.
+Examples:
+.. code-block:: mapfile
+  OUTPUTFORMAT
+    NAME "kayml"
+    DRIVER "TEMPLATE"
+    MIMETYPE "application/vnd.google-earth.kml+xml"
+    FORMATOPTION "FILE=myTemplate.kml"
+    FORMATOPTION "ATTACHMENT=queryResults.kml"
+  END
+  OUTPUTFORMAT
+    NAME "geojson"
+    DRIVER "TEMPLATE"
+    FORMATOPTION "FILE=myTemplate.json"
+  END
+  OUTPUTFORMAT
+    NAME "customxml"
+    DRIVER "TEMPLATE"
+    FORMATOPTION "FILE=myTemplate.xml"
+  END
+The template file to be used is determined by the "FILE=..." FORMATOPTION.
+The template filename is relative to the mapfile's path. As is standard with
+MapServer template files, the file must containt the magic string
+‘mapserver template’ in the first line of the file, usually within a comment,
+but this line is not output to the client.
+Note that both the MIMETYPE and FORMATOPTION "ATTACHMENT=..." parameters are
+very useful for controlling how a web browser handles the output file.
+Template Substitution Tags
+These tags only work in query result templates, and their purpose is primarily
+to simplify the templating to a single file for custom ouput formats.
+[include src="otherTemplate.txt"]
+    Includes another template file; the path to the template file is relative
+    to the mapfile path.
+[resultset name=layername]...[/resultset]
+    Defines the location of the results for a given layer.
+[feature]...[/feature]
+    Defines the loop around the features returned for a given layer.
+    Optional arguments:
+    - limit=
+        specifies the maximum number of features to output for this layer.
+    - trimlast=
+        specifies a string to be trimmed off of the end of the final feature
+        that is output. This is intended to allow for trailing record
+        delimiters to be removed. See the examples below.
+[join name=join1]...[/join]
+    defines the loop around the features join from another layer.
+Examples
+This example shows how to emulate the old 3-file system using the new system,
+to compare the usage:
+  <!-- mapserver template -->
+  [include src="templates/header.html"]
+  [resultset name=lakes]
+    ... old layer HEADER stuff goes here, if a layer has no results this block disappears...
+    [feature]
+      ...repeat this block for each feature in the result set...
+      [join name=join1]
+        ...repeat this block for each joined row...
+      [/join]
+    [/feature]
+    ...old layer FOOTER stuff goes here...
+  [/resultset]
+  [resulset name=streams]
+    [feature]
+    [/feature]
+  [/resultset]
+  [include src="templates/footer.html"]
+A specific GML3 example:
+  <?xml version="1.0" encoding="ISO-8859-1"?>
+  [resultset layer=mums]
+  <MapServerUserMeetings xmlns="http://localhost/ms_ogc_workshop" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://localhost/ms_ogc_workshop ./mums.xsd">
+   <gml:description>This is a GML document which provides locations of all MapServer User Meeting that have taken place</gml:description>
+   <gml:name>MapServer User Meetings</gml:name>
+   <gml:boundedBy>
+    <gml:Envelope>
+     <gml:coordinates>-93.093055556,44.944444444 -75.7,45.4166667</gml:coordinates>
+    </gml:Envelope>
+   </gml:boundedBy>
+   [feature]
+   <gml:featureMember>
+    <Meeting>
+     <gml:description>[desc]</gml:description>
+     <gml:name>[name]</gml:name>
+     <gml:location>
+      <gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
+       <gml:pos>[x] [y]</gml:pos>
+      </gml:Point>
+     </gml:location>
+     <year>[year]</year>
+     <venue>[venue]</venue>
+     <website>[url]</website>
+    </Meeting>
+   </gml:featureMember>
+   [/feature]
+   <dateCreated>2007-08-13T17:17:32Z</dateCreated>
+  </MapServerUserMeetings>
+  [resultset]
+A GeoJSON example:
+  // mapserver template
+    "type": "FeatureCollection",
+    "features": [
+      [feature trimlast=',']
+        "type": "Feature",
+        "id": "[id]",
+        "geometry": {
+          "type": "PointLineString",
+          "coordinates": [
+              "type": "Point",
+              "coordinates": [[x], [y]]
+        "properties": {
+          "description": "[description]",
+          "venue": "[venue]",
+          "year": "[year]"
+      [/feature]
+  [/resultset]
+A more complicated KML example. Note the use of [shpxy] to support multipolygons
+with holes, and also that a point placemark is included with each feature using
+[shplabel]:
+    <!--MapServer Template-->
+    <?xml version="1.0" encoding="UTF-8"?>
+    <kml xmlns="http://www.opengis.net/kml/2.2" xmlns:gx="http://www.google.com/kml/ext/2.2" xmlns:kml="http://www.opengis.net/kml/2.2" xmlns:atom="http://www.w3.org/2005/Atom">
+    <Document>
+	<Style id="parks_highlight">
+		<IconStyle>
+			<scale>1.4</scale>
+			<Icon>
+				<href>http://maps.google.com/mapfiles/kml/shapes/parks.png</href>
+			</Icon>
+			<hotSpot x="0.5" y="0" xunits="fraction" yunits="fraction"/>
+		</IconStyle>
+		<LineStyle>
+			<color>ffff5500</color>
+			<width>4.2</width>
+		</LineStyle>
+		<PolyStyle>
+			<color>aaaaaaaa</color>
+		</PolyStyle>
+		<BalloonStyle>
+			<text>
+				<![CDATA[
+					<p ALIGN="center"><b>$[name]</b></p>
+					$[description]
+			</text>
+		</BalloonStyle>
+	</Style>
+	<Style id="parks_normal">
+		<IconStyle>
+			<scale>1.2</scale>
+			<Icon>
+			</Icon>
+		</IconStyle>
+		<LineStyle>
+		</LineStyle>
+		<PolyStyle>
+			<color>ff7fff55</color>
+		</PolyStyle>
+		<BalloonStyle>
+			<text>
+				<![CDATA[
+					$[description]
+			</text>
+		</BalloonStyle>
+	</Style>
+	<StyleMap id="parks_map">
+		<Pair>
+			<key>normal</key>
+			<styleUrl>#parks_normal</styleUrl>
+		</Pair>
+		<Pair>
+			<key>highlight</key>
+			<styleUrl>#parks_highlight</styleUrl>
+		</Pair>
+	</StyleMap>
+    [resultset layer=parks]
+	<Folder>
+		<name>Parks</name>
+                [feature trimlast=',' limit=1]
+		<Placemark>
+			<name>[NAME]</name>
+			<Snippet/>
+			<description>
+				<![CDATA[
+					<p>Year Established: [YEAR_ESTABLISHED]</p>
+					<p>Area: [AREA_KILOMETERS_SQUARED] sq km</p>
+			</description>
+			<styleUrl>#parks_map</styleUrl>
+			<ExtendedData>
+			  <Data name="Year Established">[YEAR_ESTABLISHED]</Data>
+		          <Data name="Area">[AREA_KILOMETERS_SQUARED]</Data>
+			</ExtendedData>
+			<MultiGeometry>
+			<Point>
+				<coordinates>[shplabel proj=epsg:4326 precision=10],0</coordinates>
+			</Point>
+    [shpxy ph="<Polygon><tessellate>1</tessellate>" pf="</Polygon>" xf="," xh=" " yh=" " yf=",0 " orh="<outerBoundaryIs><LinearRing><coordinates>" orf="</coordinates></LinearRing></outerBoundaryIs>" irh="<innerBoundaryIs><LinearRing><coordinates>" irf="</coordinates></LinearRing></innerBoundaryIs>" proj=epsg:4326 precision=10]
+			</MultiGeometry>
+		</Placemark>
+                [/feature]
+	</Folder>
+    [/resultset]
+    </Document>
+    </kml>
