[mapserver-commits] r11606 - trunk/mapserver
Wed Apr 20 16:51:29 EDT 2011
Author: tamas
Date: 2011-04-20 13:51:29 -0700 (Wed, 20 Apr 2011)
New Revision: 11606
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapunion.c
Union Layer: fix for the STYLEITEM AUTO option (#3674)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-04-20 16:56:01 UTC (rev 11605)
+++ trunk/mapserver/HISTORY.TXT	2011-04-20 20:51:29 UTC (rev 11606)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk):
+- Union Layer: fix for the STYLEITEM AUTO option (#3674)
 - Union Layer: Add support for the layer FILTER expressions,
   add "Union:SourceLayerVisible" predefined attribute (#3674)
Modified: trunk/mapserver/mapunion.c
--- trunk/mapserver/mapunion.c	2011-04-20 16:56:01 UTC (rev 11605)
+++ trunk/mapserver/mapunion.c	2011-04-20 20:51:29 UTC (rev 11606)
@@ -398,19 +398,19 @@
         srclayer = &layerinfo->layers[layerinfo->layerIndex];
         while (srclayer->vtable->LayerNextShape(srclayer, shape) == MS_SUCCESS)
-            layerinfo->classIndex = msShapeGetClass(srclayer, layer->map, shape, layerinfo->classgroup, layerinfo->nclasses);
-            if((layerinfo->classIndex == -1) || (srclayer->class[layerinfo->classIndex]->status == MS_OFF))
+            if(strcasecmp(layer->styleitem, "AUTO") != 0)
-                // this shape is not visible, skip it
-                msFreeShape(shape);
-                if (rv == MS_SUCCESS)
-                    continue;
-                else
-                    break;
-            if(layer->styleitem)
+                /* need to retrieve the source layer classindex if styleitem AUTO is set */
+                layerinfo->classIndex = msShapeGetClass(srclayer, layer->map, shape, layerinfo->classgroup, layerinfo->nclasses);
+                if((layerinfo->classIndex == -1) || (srclayer->class[layerinfo->classIndex]->status == MS_OFF))
+                    // this shape is not visible, skip it
+                    msFreeShape(shape);
+                    if (rv == MS_SUCCESS)
+                        continue;
+                    else
+                        break;
                 if(strcasecmp(srclayer->styleitem, "AUTO") != 0)
                     /* Generic feature style handling as per RFC-61 */
