[mapserver-commits] r11989 - branches/branch-6-0/docs/en/input
branches/branch-6-0/docs/en/mapfile trunk/docs/en/input
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Thu Aug 4 05:26:56 EDT 2011
Author: havatv
Date: 2011-08-04 02:26:56 -0700 (Thu, 04 Aug 2011)
New Revision: 11989
branches/branch-6-0/docs/en/input/raster.txt
branches/branch-6-0/docs/en/mapfile/layer.txt
trunk/docs/en/input/raster.txt
trunk/docs/en/mapfile/layer.txt
Added processing directives (LABEL_NO_CLIP to layer, OVERSAMPLE_RATIO to raster) to the documentation (#2909 and #3952). Also sorted the elements alphabetically.
Modified: branches/branch-6-0/docs/en/input/raster.txt
--- branches/branch-6-0/docs/en/input/raster.txt 2011-08-04 08:50:51 UTC (rev 11988)
+++ branches/branch-6-0/docs/en/input/raster.txt 2011-08-04 09:26:56 UTC (rev 11989)
@@ -401,16 +401,6 @@
options to the GDAL based raster renderer. The following processing options
are supported in MapServer 4.0 and newer.
-**DITHER=YES**
- This turns on error diffusion mode, used to convert 24bit images to 8bit
- with error diffusion to get better color results.
- Example:
- PROCESSING "DITHER=YES"
**BANDS=red_or_grey[,green,blue[,alpha]]**
This directive allows a specific band or bands to be selected from a
raster file. If one band is selected, it is treated as greyscale. If 3 are
@@ -423,27 +413,52 @@
PROCESSING "BANDS=4,2,1"
-**SCALE[_n]=AUTO or min,max**
- This directive instructs the GDAL reader to pre-scale the incoming raster
- data. It is primarily used to scale 16bit or floating point data to the
- range 0-255, but can also be used to constrast stretch 8bit data. If an
- explicit min/max are provided then the input data is stretch (or squished)
- such that the minimum value maps to zero, and the maximum to 255. If AUTO
- is used instead, a min/max is automatically computed. To control the
- scaling of individual input bands, use the SCALE_1, SCALE_2 and SCALE_3
- keywords (for red, green and blue) instead of SCALE which applies to all
- bands.
+**COLOR_MATCH_THRESHOLD=n**
+ Alter the precision with which colors need to match an entry in the color
+ table to use it when producing 8bit colormapped output (IMAGEMODE PC256).
+ Normally colors from a raster colormap (or greyscale values) need to match
+ exactly. This relaxes the requirement to being within the specified color
+ distance. So a COLOR_MATCH_THRESHOLD of 3 would mean that an existing
+ color entry within 3 (sum of difference in red, green and blue) would be
+ used instead of creating a new colormap entry. Especially with greyscale
+ raster layers, which would normally use all 256 color entries if
+ available, this can be a good way to avoid "stealing" your whole colormap
+ for a raster layer. Normally values in the range 2-6 will give good
+ results.
+ Example:
+ PROCESSING "COLOR_MATCH_THRESHOLD=3"
+**DITHER=YES**
+ This turns on error diffusion mode, used to convert 24bit images to 8bit
+ with error diffusion to get better color results.
Example:
- PROCESSING "SCALE=AUTO"
- or
- PROCESSING "SCALE_1=409,1203"
- PROCESSING "SCALE_2=203,296"
- PROCESSING "SCALE_3=339,1004"
+ PROCESSING "DITHER=YES"
+**LOAD_FULL_RES_IMAGE=YES/NO**
+ This option affects how image data is loaded for the resampler when
+ reprojecting or otherwise going through complex resampling (as opposed
+ to the fast default image decimation code path). This forces the source
+ image to be loaded at full resolution if turned on (default is NO). This
+ helps work around problems with default image resolution selection in
+ when radical warping is being done. It can result in very slow processing
+ if the source image is large.
+**LOAD_WHOLE_IMAGE=YES/NO**
+ This option affects how image data is loaded for the resampler (as above).
+ This option, if turned on, will cause the whole source image to be loaded
+ and helps make up for problem identifying the area required, usually due
+ to radical image reprojection near a dateline or projection "horizon".
+ The default is NO. Turning this on can dramatically affect rendering
+ performance and memory requirements.
**LUT[_n]=<lut_spec>**
This directive (MapServer 4.9+) instructs the GDAL reader to apply a
custom LUT (lookup table) to one or all color bands as a form of on the
@@ -491,26 +506,16 @@
PROCESSING "LUT=munich.crv"
+**OVERSAMPLE_RATIO=double**
+ Default is 2.5. Rendering time will increase with increasing
+ OVERSAMPLE_RATIO.
-**COLOR_MATCH_THRESHOLD=n**
- Alter the precision with which colors need to match an entry in the color
- table to use it when producing 8bit colormapped output (IMAGEMODE PC256).
- Normally colors from a raster colormap (or greyscale values) need to match
- exactly. This relaxes the requirement to being within the specified color
- distance. So a COLOR_MATCH_THRESHOLD of 3 would mean that an existing
- color entry within 3 (sum of difference in red, green and blue) would be
- used instead of creating a new colormap entry. Especially with greyscale
- raster layers, which would normally use all 256 color entries if
- available, this can be a good way to avoid "stealing" your whole colormap
- for a raster layer. Normally values in the range 2-6 will give good
- results.
Example:
- PROCESSING "COLOR_MATCH_THRESHOLD=3"
+ PROCESSING "OVERSAMPLE_RATIO=1.0"
**RESAMPLE=NEAREST/AVERAGE/BILINEAR**
This option can be used to control the resampling kernel used sampling
raster images. The default (and fastest) is NEAREST. AVERAGE will perform
@@ -535,24 +540,27 @@
PROCESSING "RESAMPLE=AVERAGE"
PROCESSING "RESAMPLE=BILINEAR"
-**LOAD_FULL_RES_IMAGE=YES/NO**
- This option affects how image data is loaded for the resampler when
- reprojecting or otherwise going through complex resampling (as opposed
- to the fast default image decimation code path). This forces the source
- image to be loaded at full resolution if turned on (default is NO). This
- helps work around problems with default image resolution selection in
- when radical warping is being done. It can result in very slow processing
- if the source image is large.
-**LOAD_WHOLE_IMAGE=YES/NO**
- This option affects how image data is loaded for the resampler (as above).
- This option, if turned on, will cause the whole source image to be loaded
- and helps make up for problem identifying the area required, usually due
- to radical image reprojection near a dateline or projection "horizon".
- The default is NO. Turning this on can dramatically affect rendering
- performance and memory requirements.
+**SCALE[_n]=AUTO or min,max**
+ This directive instructs the GDAL reader to pre-scale the incoming raster
+ data. It is primarily used to scale 16bit or floating point data to the
+ range 0-255, but can also be used to constrast stretch 8bit data. If an
+ explicit min/max are provided then the input data is stretch (or squished)
+ such that the minimum value maps to zero, and the maximum to 255. If AUTO
+ is used instead, a min/max is automatically computed. To control the
+ scaling of individual input bands, use the SCALE_1, SCALE_2 and SCALE_3
+ keywords (for red, green and blue) instead of SCALE which applies to all
+ bands.
+ Example:
+ PROCESSING "SCALE=AUTO"
+ or
+ PROCESSING "SCALE_1=409,1203"
+ PROCESSING "SCALE_2=203,296"
+ PROCESSING "SCALE_3=339,1004"
Raster Query
Modified: branches/branch-6-0/docs/en/mapfile/layer.txt
--- branches/branch-6-0/docs/en/mapfile/layer.txt 2011-08-04 08:50:51 UTC (rev 11988)
+++ branches/branch-6-0/docs/en/mapfile/layer.txt 2011-08-04 09:26:56 UTC (rev 11989)
@@ -437,6 +437,13 @@
PROCESSING "CLOSE_CONNECTION=DEFER"
+ - **Label Directive** - The LABEL_NO_CLIP processing option can be used
+ to turn off label clipping.
+ .. code-block:: mapfile
+ PROCESSING "LABEL_NO_CLIP=True"
- **OGR Styles Directive** - This directive can be used for obtaining
label styles through MapScript. For more information see the
:ref:`MapServer's OGR document <styleitemauto-label-styles>`.
Modified: trunk/docs/en/input/raster.txt
--- trunk/docs/en/input/raster.txt 2011-08-04 08:50:51 UTC (rev 11988)
+++ trunk/docs/en/input/raster.txt 2011-08-04 09:26:56 UTC (rev 11989)
-**DITHER=YES**
- Example:
- bands.
+ results.
+ Example:
+**DITHER=YES**
Example:
- or
+ OVERSAMPLE_RATIO.
- results.
Example:
+ bands.
+ Example:
+ or
Raster Query
Modified: trunk/docs/en/mapfile/layer.txt
--- trunk/docs/en/mapfile/layer.txt 2011-08-04 08:50:51 UTC (rev 11988)
+++ trunk/docs/en/mapfile/layer.txt 2011-08-04 09:26:56 UTC (rev 11989)
More information about the mapserver-commits
