[mapserver-commits] r11990 - branches/branch-6-0/docs/en/mapfile branches/branch-6-0/docs/en/tutorial trunk/docs/en/mapfile trunk/docs/en/tutorial
Thu Aug 4 06:04:31 EDT 2011
Author: havatv
Date: 2011-08-04 03:04:31 -0700 (Thu, 04 Aug 2011)
New Revision: 11990
   branches/branch-6-0/docs/en/mapfile/join.txt
   branches/branch-6-0/docs/en/mapfile/labelencoding.txt
   branches/branch-6-0/docs/en/tutorial/section1.txt
   trunk/docs/en/mapfile/join.txt
   trunk/docs/en/mapfile/labelencoding.txt
   trunk/docs/en/tutorial/section1.txt
Fixed some overfull lines in the PDF documentation (#3947) - section1, join, labelencoding
Modified: branches/branch-6-0/docs/en/mapfile/join.txt
--- branches/branch-6-0/docs/en/mapfile/join.txt	2011-08-04 09:26:56 UTC (rev 11989)
+++ branches/branch-6-0/docs/en/mapfile/join.txt	2011-08-04 10:04:31 UTC (rev 11990)
@@ -192,8 +192,10 @@
-  >ogrinfo -ro PG:"host=127.0.0.1 port=5432 user=postgres password=postgre dbname=join" lookup -summary
-  INFO: Open of `PG:host=127.0.0.1 port=5432 user=postgres password=postgres dbname=join'
+  >ogrinfo -ro PG:"host=127.0.0.1 port=5432 user=postgres password=postgre
+               dbname=join" lookup -summary
+  INFO: Open of `PG:host=127.0.0.1 port=5432 user=postgres password=postgres
+        dbname=join'
   using driver `PostgreSQL' successful.
   Layer name: lookup
@@ -355,4 +357,4 @@
 .. note::
     When testing with MapServer 5.6.5 and MySQL 5.1.49 on Windows this MySQL join caused a
-    mapserv.exe crash.
\ No newline at end of file
+    mapserv.exe crash.
Modified: branches/branch-6-0/docs/en/mapfile/labelencoding.txt
--- branches/branch-6-0/docs/en/mapfile/labelencoding.txt	2011-08-04 09:26:56 UTC (rev 11989)
+++ branches/branch-6-0/docs/en/mapfile/labelencoding.txt	2011-08-04 10:04:31 UTC (rev 11990)
@@ -52,11 +52,14 @@
    > mapserv -v
-     MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG
-     SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
-     SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
-     SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG SUPPORTS=TILECACHE INPUT=JPEG
-     INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
+     MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
+     OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
+     SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
+     SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
+     SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
+     SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG
+     SUPPORTS=TILECACHE INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
+     INPUT=SHAPEFILE
 Step 2: Verify That Your Files' Encoding is Supported by ICONV
@@ -185,4 +188,4 @@
 During initial implementation, this functionality was tested using the different Japanese encoding systems:
-Shift-JIS, EUC-JP, UTF-8, as well as Thai's TIS-620 encoding system.
+Shift-JIS, EUC-JP, UTF-8, as well as Thai's TIS-620 encoding system.
Modified: branches/branch-6-0/docs/en/tutorial/section1.txt
--- branches/branch-6-0/docs/en/tutorial/section1.txt	2011-08-04 09:26:56 UTC (rev 11989)
+++ branches/branch-6-0/docs/en/tutorial/section1.txt	2011-08-04 10:04:31 UTC (rev 11990)
@@ -3,31 +3,48 @@
 Section 1: Static Maps and the MapFile
-- Take a shapefile. Any shapefile. We can use MapServer to display that shapefile on a web browser. Look...
+- Take a shapefile. Any shapefile. We can use MapServer to display
+  that shapefile on a web browser. Look...
     - :ref:`Example 1.1 - A map with a single layer <example1-1>`
-- We can display the same shapefile repeatedly. We can display the polygon attributes on one LAYER and and the line attributes on another...
+- We can display the same shapefile repeatedly. We can display the
+  polygon attributes on one LAYER and and the line attributes on
+  another...
     - :ref:`Example 1.2 - A map with two layers <example1-2>`
-- And we can select which parts of the shapefile to display. We do this using the CLASS object...
+- And we can select which parts of the shapefile to display. We do
+  this using the CLASS object...
     - :ref:`Example 1.3 - Using classes to make a "useful" map <example1-3>`
 - We can also label our maps...
     - :ref:`Example 1.4 - Labeling layers and label layers <example1-4>`
-- Or add raster data such as satellite images, aerial photographs, or shaded reliefs...
+- Or add raster data such as satellite images, aerial photographs, or
+  shaded reliefs...
     - :ref:`Example 1.5 - Adding a raster layer <example1-5>`
-- We can reproject our data from just about any projection to just about any... Yeah, check it out!
+- We can reproject our data from just about any projection to just
+  about any... Yeah, check it out!
     - :ref:`Example 1.6 - Projection/Reprojection <example1-6`
-- And we can use layers from other map servers on the internet (as long as they are WMS servers)...
+- And we can use layers from other map servers on the internet (as
+  long as they are WMS servers)...
     - :ref:`Example 1.7 - Adding a WMS layer <example1-7>`
 - MapServer can output to various formats such as PDF and GeoTIFF.
     - :ref:`Example 1.8 - A different output format <example1-8>`
-- MapServer not only generates static maps, it can also create interactive maps...
+- MapServer not only generates static maps, it can also create
+  interactive maps...
     - `Example 1.9 - The difference between map and browse mode <http://demo.mapserver.org/cgi-bin/mapserv?map=/osgeo/mapserver/tutorial/htdocs/example1-9.map&layer=states&layer=modis>`_
Modified: trunk/docs/en/mapfile/join.txt
--- trunk/docs/en/mapfile/join.txt	2011-08-04 09:26:56 UTC (rev 11989)
+++ trunk/docs/en/mapfile/join.txt	2011-08-04 10:04:31 UTC (rev 11990)
+        dbname=join'
   Layer name: lookup
@@ -355,4 +357,4 @@
 .. note::
Modified: trunk/docs/en/mapfile/labelencoding.txt
--- trunk/docs/en/mapfile/labelencoding.txt	2011-08-04 09:26:56 UTC (rev 11989)
+++ trunk/docs/en/mapfile/labelencoding.txt	2011-08-04 10:04:31 UTC (rev 11990)
@@ -52,11 +52,14 @@
    > mapserv -v
+     INPUT=SHAPEFILE
@@ -185,4 +188,4 @@
Modified: trunk/docs/en/tutorial/section1.txt
--- trunk/docs/en/tutorial/section1.txt	2011-08-04 09:26:56 UTC (rev 11989)
+++ trunk/docs/en/tutorial/section1.txt	2011-08-04 10:04:31 UTC (rev 11990)
@@ -3,31 +3,48 @@
+  another...
+  shaded reliefs...
