[mapserver-commits] r12036 - branches/branch-6-0/docs/en/mapscript
branches/branch-6-0/docs/en/mapscript/php
trunk/docs/en/mapscript trunk/docs/en/mapscript/php
svn at osgeo.org
svn at osgeo.org
Wed Aug 10 17:39:08 EDT 2011
Author: havatv
Date: 2011-08-10 14:39:07 -0700 (Wed, 10 Aug 2011)
New Revision: 12036
branches/branch-6-0/docs/en/mapscript/mapscript.txt
branches/branch-6-0/docs/en/mapscript/php/index.txt
trunk/docs/en/mapscript/mapscript.txt
trunk/docs/en/mapscript/php/index.txt
Added getresultsbounds to the mapscript documentation (#2967). php and swig.
Modified: branches/branch-6-0/docs/en/mapscript/mapscript.txt
--- branches/branch-6-0/docs/en/mapscript/mapscript.txt 2011-08-10 10:50:24 UTC (rev 12035)
+++ branches/branch-6-0/docs/en/mapscript/mapscript.txt 2011-08-10 21:39:07 UTC (rev 12036)
@@ -1099,6 +1099,9 @@
Returns a reference to layer's result cache. Should be NULL prior to
any query, or after a failed query or query with no results.
+getResultsBounds() : rectObj_
+ Returns the bounds of the features in the result cache.
getShape( shapeObj_ shape, int tileindex, int shapeindex ) : int
Get a shape from layer data.
Modified: branches/branch-6-0/docs/en/mapscript/php/index.txt
--- branches/branch-6-0/docs/en/mapscript/php/index.txt 2011-08-10 10:50:24 UTC (rev 12035)
+++ branches/branch-6-0/docs/en/mapscript/php/index.txt 2011-08-10 21:39:07 UTC (rev 12036)
@@ -922,13 +922,16 @@
setWKTProjection requires GDAL support
int getNumResults()
- Returns the number of results from this layer in the last query.
+ Returns the number of results in the last query.
resultObj getResult(int index)
Returns a resultObj by index from a layer object with
index in the range 0 to numresults-1.
Returns a valid object or FALSE(0) if index is invalid.
+rectObj getResultsBounds()
+ Returns the bounding box of the latest result.
int open()
Open the layer for use with getShape().
Returns MS_SUCCESS/MS_FAILURE.
Modified: trunk/docs/en/mapscript/mapscript.txt
--- trunk/docs/en/mapscript/mapscript.txt 2011-08-10 10:50:24 UTC (rev 12035)
+++ trunk/docs/en/mapscript/mapscript.txt 2011-08-10 21:39:07 UTC (rev 12036)
Modified: trunk/docs/en/mapscript/php/index.txt
--- trunk/docs/en/mapscript/php/index.txt 2011-08-10 10:50:24 UTC (rev 12035)
+++ trunk/docs/en/mapscript/php/index.txt 2011-08-10 21:39:07 UTC (rev 12036)
int getNumResults()
int open()
More information about the mapserver-commits
