[mapserver-commits] r12037 - branches/branch-6-0/docs/en/mapfile
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Wed Aug 10 18:26:21 EDT 2011
Author: havatv
Date: 2011-08-10 15:26:21 -0700 (Wed, 10 Aug 2011)
New Revision: 12037
branches/branch-6-0/docs/en/mapfile/index.txt
branches/branch-6-0/docs/en/mapfile/layer.txt
branches/branch-6-0/docs/en/mapfile/map.txt
trunk/docs/en/mapfile/index.txt
trunk/docs/en/mapfile/layer.txt
trunk/docs/en/mapfile/map.txt
Updated mapfile, map and layer documentation with security related changes (#2977). Required MAP and SYMBOLSET + references to the template document.
Modified: branches/branch-6-0/docs/en/mapfile/index.txt
--- branches/branch-6-0/docs/en/mapfile/index.txt 2011-08-10 21:39:07 UTC (rev 12036)
+++ branches/branch-6-0/docs/en/mapfile/index.txt 2011-08-10 22:26:21 UTC (rev 12037)
@@ -17,6 +17,9 @@
objects, points MapServer to where data are located and defines how things are
to be drawn.
+The Mapfile consists of a :ref:`MAP` object, which has to start with
+the word `MAP`.
There are some important concepts that you must understand before you can
reliably use mapfiles to configure MapServer. First is the concept of a
:ref:`LAYER`. A layer is the combination of data plus styling. Data, in
Modified: branches/branch-6-0/docs/en/mapfile/layer.txt
--- branches/branch-6-0/docs/en/mapfile/layer.txt 2011-08-10 21:39:07 UTC (rev 12036)
+++ branches/branch-6-0/docs/en/mapfile/layer.txt 2011-08-10 22:26:21 UTC (rev 12037)
@@ -551,7 +551,8 @@
.. deprecated:: 5.0
:ref:`TEMPLATE <template>` [file|url]
- Used as a global alternative to CLASS TEMPLATE.
+ Used as a global alternative to :ref:`CLASS` `TEMPLATE`.
+ See :ref:`template` for more info.
:ref:`TILEINDEX <tileindex>` [filename|layername]
Name of the tileindex file or layer. A tileindex is similar to
Modified: branches/branch-6-0/docs/en/mapfile/map.txt
--- branches/branch-6-0/docs/en/mapfile/map.txt 2011-08-10 21:39:07 UTC (rev 12036)
+++ branches/branch-6-0/docs/en/mapfile/map.txt 2011-08-10 22:26:21 UTC (rev 12037)
@@ -4,6 +4,10 @@
MAP
+.. note::
+ The map object is started with the word `MAP`, and ended with the
+ word `END`.
ANGLE [double]
Angle, given in degrees, to rotate the map. Default is 0. The
rendered map will rotate in a clockwise direction. The following
@@ -331,6 +335,10 @@
Filename of the symbolset to use. Can be a path relative to the
mapfile, or a full path.
+ .. note::
+ The `SYMBOLSET` file must start with the word `SYMBOLSET` and
+ end with the word `END`.
:ref:`SYMBOL`
Signals the start of a :ref:`SYMBOL` object.
Modified: trunk/docs/en/mapfile/index.txt
--- trunk/docs/en/mapfile/index.txt 2011-08-10 21:39:07 UTC (rev 12036)
+++ trunk/docs/en/mapfile/index.txt 2011-08-10 22:26:21 UTC (rev 12037)
@@ -17,6 +17,9 @@
to be drawn.
+the word `MAP`.
Modified: trunk/docs/en/mapfile/layer.txt
--- trunk/docs/en/mapfile/layer.txt 2011-08-10 21:39:07 UTC (rev 12036)
+++ trunk/docs/en/mapfile/layer.txt 2011-08-10 22:26:21 UTC (rev 12037)
@@ -551,7 +551,8 @@
.. deprecated:: 5.0
Modified: trunk/docs/en/mapfile/map.txt
--- trunk/docs/en/mapfile/map.txt 2011-08-10 21:39:07 UTC (rev 12036)
+++ trunk/docs/en/mapfile/map.txt 2011-08-10 22:26:21 UTC (rev 12037)
@@ -4,6 +4,10 @@
MAP
+.. note::
+ word `END`.
ANGLE [double]
+ .. note::
:ref:`SYMBOL`
More information about the mapserver-commits
