[mapserver-commits] r12038 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Wed Aug 10 19:07:15 EDT 2011
Author: havatv
Date: 2011-08-10 16:07:15 -0700 (Wed, 10 Aug 2011)
New Revision: 12038
   branches/branch-6-0/docs/en/mapfile/class.txt
   branches/branch-6-0/docs/en/mapfile/layer.txt
   branches/branch-6-0/docs/en/mapfile/style.txt
   trunk/docs/en/mapfile/class.txt
   trunk/docs/en/mapfile/layer.txt
   trunk/docs/en/mapfile/style.txt
Included reference to symbolscaledenom in class and style minsize and maxsize, minwidth and maxwidth (#3154).
Modified: branches/branch-6-0/docs/en/mapfile/class.txt
--- branches/branch-6-0/docs/en/mapfile/class.txt	2011-08-10 22:26:21 UTC (rev 12037)
+++ branches/branch-6-0/docs/en/mapfile/class.txt	2011-08-10 23:07:15 UTC (rev 12038)
@@ -144,6 +144,7 @@
 MAXSIZE [integer]
     Maximum size in pixels to draw a symbol. Default is 50.
+    See :ref:`LAYER` :ref:`SYMBOLSCALEDENOM <symbolscaledenom>`.
 .. index::
     pair: MINSCALEDENOM; CLASS
@@ -169,6 +170,7 @@
 MINSIZE [integer]
     Minimum size in pixels to draw a symbol. Default is 0.
 NAME [string]
     Name to use in legends for this class. If not set class won't show
Modified: branches/branch-6-0/docs/en/mapfile/layer.txt
--- branches/branch-6-0/docs/en/mapfile/layer.txt	2011-08-10 22:26:21 UTC (rev 12037)
+++ branches/branch-6-0/docs/en/mapfile/layer.txt	2011-08-10 23:07:15 UTC (rev 12038)
@@ -526,6 +526,8 @@
 .. index::
     pair: SYMBOLSCALEDENOM; LAYER
+.. _SYMBOLSCALEDENOM:
 SYMBOLSCALEDENOM [double]
     The scale at which symbols and/or text appear full size. This allows for
     dynamic scaling of objects based on the scale of the map. If not set then
Modified: branches/branch-6-0/docs/en/mapfile/style.txt
--- branches/branch-6-0/docs/en/mapfile/style.txt	2011-08-10 22:26:21 UTC (rev 12037)
+++ branches/branch-6-0/docs/en/mapfile/style.txt	2011-08-10 23:07:15 UTC (rev 12038)
@@ -178,21 +178,25 @@
     Maximum size in pixels to draw a symbol. Default is 500.  Starting
     from version 5.4, the value can also be a decimal value (and not
     only integer).
 MAXWIDTH [double]
     Maximum width in pixels to draw the line work. Default is 32.
     Starting from version 5.4, the value can also be a decimal value
     (and not only integer).
 MINSIZE [double]
     Minimum size in pixels to draw a symbol. Default is 0.  Starting
     only integer).
 MINWIDTH [double]
     Minimum width in pixels to draw the line work. Default is 0.
 OFFSET [x][y]
     Geometry offset values in layer `SIZEUNITS`.
Modified: trunk/docs/en/mapfile/class.txt
--- trunk/docs/en/mapfile/class.txt	2011-08-10 22:26:21 UTC (rev 12037)
+++ trunk/docs/en/mapfile/class.txt	2011-08-10 23:07:15 UTC (rev 12038)
@@ -144,6 +144,7 @@
 MAXSIZE [integer]
 .. index::
@@ -169,6 +170,7 @@
 MINSIZE [integer]
 NAME [string]
Modified: trunk/docs/en/mapfile/layer.txt
--- trunk/docs/en/mapfile/layer.txt	2011-08-10 22:26:21 UTC (rev 12037)
+++ trunk/docs/en/mapfile/layer.txt	2011-08-10 23:07:15 UTC (rev 12038)
@@ -526,6 +526,8 @@
 .. index::
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt	2011-08-10 22:26:21 UTC (rev 12037)
+++ trunk/docs/en/mapfile/style.txt	2011-08-10 23:07:15 UTC (rev 12038)
     only integer).
 MAXWIDTH [double]
 MINSIZE [double]
     only integer).
 MINWIDTH [double]
 OFFSET [x][y]
