[mapserver-commits] r12093 - branches/branch-6-0/docs/en/mapfile
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Tue Aug 23 08:45:22 EDT 2011
Author: havatv
Date: 2011-08-23 05:45:22 -0700 (Tue, 23 Aug 2011)
New Revision: 12093
branches/branch-6-0/docs/en/mapfile/cluster.txt
trunk/docs/en/mapfile/cluster.txt
Added indexes (#4001)
Modified: branches/branch-6-0/docs/en/mapfile/cluster.txt
--- branches/branch-6-0/docs/en/mapfile/cluster.txt 2011-08-23 12:41:05 UTC (rev 12092)
+++ branches/branch-6-0/docs/en/mapfile/cluster.txt 2011-08-23 12:45:22 UTC (rev 12093)
@@ -13,9 +13,11 @@
Description
-Since version 6.0, MapServer has the ability to combine multiple features from a
-point layer into single (aggregated) features based on their relative positions.
-Only *POINT* layers are supported. This feature was added through :ref:`rfc69`.
+Since version 6.0, MapServer has the ability to combine multiple
+features from a point layer into single (aggregated) features based on
+their relative positions.
+Only *POINT* layers are supported.
+This feature was added through :ref:`rfc69`.
Supported Layer Types
@@ -25,25 +27,42 @@
Mapfile Parameters
+.. index::
+ pair: CLUSTER; MAXDISTANCE
MAXDISTANCE [double]
- Specifies the distance of the search region (rectangle or ellipse) in pixel positions.
+ Specifies the distance of the search region (rectangle or ellipse)
+ in pixel positions.
+.. index::
+ pair: CLUSTER; REGION
REGION [string]
- Defines the search region around a feature in which the neighbouring features are negotiated.
+ Defines the search region around a feature in which the
+ neighbouring features are negotiated.
Can be 'rectangle' or 'ellipse'.
+.. index::
+ pair: CLUSTER; GROUP
:ref:`GROUP <expressions>` [string]
- This expression evaluates to a string and only the features that have the
- same group value are negotiated. This parameter can be omitted. The evaluated group value is
- available in the 'Cluster:Group' feature attribute.
+ This expression evaluates to a string and only the features that
+ have the same group value are negotiated. This parameter can be
+ omitted. The evaluated group value is available in the
+ 'Cluster:Group' feature attribute.
+.. index::
+ pair: CLUSTER; FILTER
:ref:`FILTER <expressions>` [string]
- We can define the FILTER expression filter some of the features from the final output.
- This expression evaluates to a boolean value and if this value is false
- the corresponding shape is filtered out.
- This expression is evaluated after the the feature negotiation is completed, therefore
- the 'Cluster:FeatureCount' parameter can also be used, which provides the option
- to filter the shapes having too many or to few neighbors within the search region.
+ We can define the FILTER expression filter some of the features
+ from the final output. This expression evaluates to a boolean
+ value and if this value is false the corresponding shape is
+ filtered out. This expression is evaluated after the the feature
+ negotiation is completed, therefore the 'Cluster:FeatureCount'
+ parameter can also be used, which provides the option to filter
+ the shapes having too many or to few neighbors within the search
+ region.
Mapfile Snippet
@@ -70,29 +89,50 @@
END
+.. index::
+ pair: CLUSTER; feature attributes
Feature attributes
The clustered layer itself provides the following aggregated attributes:
+.. index::
+ pair: CLUSTER; FeatureCount
+.. index::
+ pair: CLUSTER; Group
1. Cluster:FeatureCount - count of the features in the clustered shape
-2. Cluster:Group - The group value of the cluster (to which the group expression is evaluated)
+2. Cluster:Group - The group value of the cluster (to which the group
+ expression is evaluated)
-These attributes (in addition to the attributes provided by the original data source) can be used to configure
-the labels of the features and can also be used in expressions.
-The ITEMS processing option can be used to specify a subset of the attributes from the original
-layer in the query operations according to the user's preference.
+These attributes (in addition to the attributes provided by the
+original data source) can be used to configure the labels of the
+features and can also be used in expressions. The ITEMS processing
+option can be used to specify a subset of the attributes from the
+original layer in the query operations according to the user's
+preference.
-We can use simple aggregate functions (Min, Max, Sum, Count) to specify how the clustered attribute should be
-calculated from the original attributes. The aggregate function should be specified as a prefix separated by ':' in
-the attibute definition, like: [Max:itemname]. If we don't specify aggregate functions for the source
-layer attributes, then the actual value of the cluster attribute will be non-deterministic if the cluster contains
-multiple shapes with different values. The Count aggregate function in fact provides the same value as Cluster:FeatureCount.
+.. index::
+ pair: CLUSTER; Aggregate functions
+We can use simple aggregate functions (Min, Max, Sum, Count) to
+specify how the clustered attribute should be calculated from the
+original attributes. The aggregate function should be specified as a
+prefix separated by ':' in the attibute definition, like:
+[Max:itemname]. If we don't specify aggregate functions for the source
+layer attributes, then the actual value of the cluster attribute will
+be non-deterministic if the cluster contains multiple shapes with
+different values. The Count aggregate function in fact provides the
+same value as Cluster:FeatureCount.
PHP MapScript Usage
-The :ref:`CLUSTER object <phpclusterobj>` is exposed through PHP MapScript. An example follows:
+The :ref:`CLUSTER object <phpclusterobj>` is exposed through PHP
+MapScript. An example follows:
.. code-block:: php
@@ -103,13 +143,14 @@
Example: Clustering Railway Stations
-The following example uses a point datasource, in this case in KML format, to display clusters of railway
-stations. Two classes are used: one to style and label the cluster, and one to style and label the single
-railway station.
+The following example uses a point datasource, in this case in KML
+format, to display clusters of railway stations. Two classes are
+used: one to style and label the cluster, and one to style and label
+the single railway station.
.. note::
- Since we can't declare 2 labelitems, for the single railway class we use the *TEXT* parameter to label
- the station.
+ Since we can't declare 2 labelitems, for the single railway class
+ we use the *TEXT* parameter to label the station.
Mapfile Layer
Modified: trunk/docs/en/mapfile/cluster.txt
--- trunk/docs/en/mapfile/cluster.txt 2011-08-23 12:41:05 UTC (rev 12092)
+++ trunk/docs/en/mapfile/cluster.txt 2011-08-23 12:45:22 UTC (rev 12093)
@@ -13,9 +13,11 @@
Description
@@ -25,25 +27,42 @@
Mapfile Parameters
+.. index::
+.. index::
REGION [string]
+.. index::
+.. index::
+ region.
Mapfile Snippet
@@ -70,29 +89,50 @@
END
+.. index::
Feature attributes
+.. index::
+.. index::
+preference.
+.. index::
PHP MapScript Usage
.. code-block:: php
-railway station.
.. note::
- the station.
Mapfile Layer
More information about the mapserver-commits
