[mapserver-commits] r12094 - branches/branch-6-0/docs/en/mapfile
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Tue Aug 23 08:50:13 EDT 2011
Author: havatv
Date: 2011-08-23 05:50:13 -0700 (Tue, 23 Aug 2011)
New Revision: 12094
branches/branch-6-0/docs/en/mapfile/feature.txt
trunk/docs/en/mapfile/feature.txt
Added indexes (#4001)
Modified: branches/branch-6-0/docs/en/mapfile/feature.txt
--- branches/branch-6-0/docs/en/mapfile/feature.txt 2011-08-23 12:45:22 UTC (rev 12093)
+++ branches/branch-6-0/docs/en/mapfile/feature.txt 2011-08-23 12:50:13 UTC (rev 12094)
@@ -1,9 +1,15 @@
.. _feature:
+.. index::
+ single: FEATURE
FEATURE
+.. index::
+ pair: FEATURE; POINTS
POINTS
A set of xy pairs terminated with an END, for example:
@@ -11,11 +17,14 @@
POINTS 1 1 50 50 1 50 1 1 END
-.. note::
+ .. note::
- POLYGON/POLYLINE layers POINTS must start and end with the
- same point (i.e. close the feature).
+ POLYGON/POLYLINE layers POINTS must start and end with the
+ same point (i.e. close the feature).
+.. index::
+ pair: FEATURE; ITEMS
ITEMS
Comma separated list of the feature attributes:
@@ -23,15 +32,21 @@
ITEMS "value1;value2;value3"
-.. note::
+ .. note::
- Specifying the same number of items is recommended for each features
- of the same layer. The item names should be specified as a PROCESSING
- option of the layer.
+ Specifying the same number of items is recommended for each
+ features of the same layer. The item names should be specified
+ as a PROCESSING option of the layer.
+.. index::
+ pair: FEATURE; TEXT
TEXT [string]
String to use for labeling this feature.
+.. index::
+ pair: FEATURE; WKT
WKT [string]
A geometry expressed in OpenGIS Well Known Text geometry format.
This feature is only supported if MapServer is built with OGR or GEOS
@@ -44,6 +59,7 @@
.. note::
- Inline features should be defined as their own layers in the mapfile. If
- another CONNECTIONTYPE is specified in the same layer, MapServer will always
- use the inline features to draw the layer and ignore the other CONNECTIONTYPEs.
\ No newline at end of file
+ Inline features should be defined as their own layers in the
+ mapfile. If another CONNECTIONTYPE is specified in the same layer,
+ MapServer will always use the inline features to draw the layer
+ and ignore the other CONNECTIONTYPEs.
Modified: trunk/docs/en/mapfile/feature.txt
--- trunk/docs/en/mapfile/feature.txt 2011-08-23 12:45:22 UTC (rev 12093)
+++ trunk/docs/en/mapfile/feature.txt 2011-08-23 12:50:13 UTC (rev 12094)
@@ -1,9 +1,15 @@
.. _feature:
+.. index::
+ single: FEATURE
FEATURE
+.. index::
POINTS
@@ -11,11 +17,14 @@
-.. note::
+ .. note::
+.. index::
ITEMS
@@ -23,15 +32,21 @@
-.. note::
+ .. note::
+.. index::
TEXT [string]
+.. index::
WKT [string]
@@ -44,6 +59,7 @@
.. note::
More information about the mapserver-commits
