[mapserver-commits] r12096 - branches/branch-6-0/docs/en/mapfile
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Tue Aug 23 08:55:44 EDT 2011
Author: havatv
Date: 2011-08-23 05:55:44 -0700 (Tue, 23 Aug 2011)
New Revision: 12096
branches/branch-6-0/docs/en/mapfile/grid.txt
trunk/docs/en/mapfile/grid.txt
Added indexes (#4001)
Modified: branches/branch-6-0/docs/en/mapfile/grid.txt
--- branches/branch-6-0/docs/en/mapfile/grid.txt 2011-08-23 12:52:39 UTC (rev 12095)
+++ branches/branch-6-0/docs/en/mapfile/grid.txt 2011-08-23 12:55:44 UTC (rev 12096)
@@ -1,9 +1,15 @@
.. _grid:
+.. index::
+ single: GRID
GRID
+.. index::
+ pair: GRID; LABELFORMAT
LABELFORMAT [DD|DDMM|DDMMSS|C format string]
Format of the label. "DD" for degrees, "DDMM" for degrees minutes, and
"DDMMSS" for degrees, minutes, seconds. A C-style formatting string is
@@ -11,27 +17,45 @@
The default is decimal display of whatever SRS you're rendering the GRID
with.
+.. index::
+ pair: GRID; MINARCS
MINARCS [double]
The minimum number of arcs to draw. Increase this parameter to get
more lines. Optional.
+.. index::
+ pair: GRID; MAXARCS
MAXARCS [double]
The maximum number of arcs to draw. Decrease this parameter to
get fewer lines. Optional.
+.. index::
+ pair: GRID; MININTERVAL
MININTERVAL [double]
The minimum number of intervals to try to use. The distance between
the grid lines, in the units of the grid's coordinate system. Optional.
+.. index::
+ pair: GRID; MAXINTERVAL
MAXINTERVAL [double]
The maximum number of intervals to try to use. The distance between
+.. index::
+ pair: GRID; MINSUBDIVIDE
MINSUBDIVIDE [double]
The minimum number of segments to use when rendering an arc. If the
lines should be very curved, use this to smooth the lines by adding more
segments. Optional.
+.. index::
+ pair: GRID; MAXSUBDIVIDE
MAXSUBDIVIDE [double]
The maximum number of segments to use when rendering an arc. If the
graticule should be very straight, use this to minimize the number of
Modified: trunk/docs/en/mapfile/grid.txt
--- trunk/docs/en/mapfile/grid.txt 2011-08-23 12:52:39 UTC (rev 12095)
+++ trunk/docs/en/mapfile/grid.txt 2011-08-23 12:55:44 UTC (rev 12096)
@@ -1,9 +1,15 @@
.. _grid:
+.. index::
+ single: GRID
GRID
+.. index::
@@ -11,27 +17,45 @@
with.
+.. index::
MINARCS [double]
+.. index::
MAXARCS [double]
+.. index::
+.. index::
+.. index::
segments. Optional.
+.. index::
More information about the mapserver-commits
