[mapserver-commits] r12097 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Tue Aug 23 09:03:28 EDT 2011
Author: havatv
Date: 2011-08-23 06:03:28 -0700 (Tue, 23 Aug 2011)
New Revision: 12097
   branches/branch-6-0/docs/en/mapfile/join.txt
   trunk/docs/en/mapfile/join.txt
Added indexes (#4001)
Modified: branches/branch-6-0/docs/en/mapfile/join.txt
--- branches/branch-6-0/docs/en/mapfile/join.txt	2011-08-23 12:55:44 UTC (rev 12096)
+++ branches/branch-6-0/docs/en/mapfile/join.txt	2011-08-23 13:03:28 UTC (rev 12097)
@@ -4,7 +4,7 @@
  JOIN
-.. index:: Join
+.. index:: JOIN
 Description
@@ -14,6 +14,9 @@
 use joins to affect the look of a map. The primary purpose is to enable lookup
 tables for coded data (e.g. 1 => Forest) but there are other possible uses.
+.. index::
+   pair: JOIN; Supported formats
 Supported Formats
@@ -24,41 +27,65 @@
 Mapfile Parameters:
+.. index::
+   pair: JOIN; CONNECTION
 CONNECTION [string]
     Parameters required for the join table's database connection (not required
-    for DBF or CSV joins). The following is an example connection for :ref:`PostgreSQL
-    <input_postgis>`:
+    for DBF or CSV joins). The following is an example connection for
+    :ref:`PostgreSQL <input_postgis>`:
     .. code-block:: mapfile
       CONNECTION "host=127.0.0.1 port=5432 user=postgres password=postgres dbname=somename"
       CONNECTIONTYPE POSTGRESQL
+.. index::
+   pair: JOIN; CONNECTIONTYPE
 CONNECTIONTYPE [csv|postgresql]
     Type of connection (not required for DBF joins). For PostgreSQL
     use `postgresql`, for CSV use `csv`.
+.. index::
+   pair: JOIN; FOOTER
 FOOTER [filename]
     Template to use *after* a layer's set of results have been sent. In other
     words, this header HTML will be displayed after the contents of the
     `TEMPLATE` HTML.
+.. index::
+   pair: JOIN; FROM
 FROM [item]
     Join item in the dataset.  This is case sensitive.
+.. index::
+   pair: JOIN; HEADER
 HEADER [filename]
     Template to use *before* a layer's set of results have been sent. In other
     words, this header HTML will be displayed before the contents of the
     `TEMPLATE` HTML.
+.. index::
+   pair: JOIN; NAME
 NAME [string]
     Unique name for this join. Required.
+.. index::
+   pair: JOIN; TABLE
 TABLE [filename|tablename]
     For file-based joins this is the name of XBase or comma delimited file
     (relative to the location of the mapfile) to join TO. For PostgreSQL
     support this is the name of the PostgreSQL table to join TO.
+.. index::
+   pair: JOIN; TEMPLATE
 TEMPLATE [filename]
     Template to use with one-to-many joins. The template is processed once
     for each record and can only contain substitutions for items in the joined
@@ -66,9 +93,15 @@
     [joinname_columnname], where joinname is the NAME specified for the JOIN
     object.
+.. index::
+   pair: JOIN; TO
 TO [item]
     Join item in the table to be joined. This is case sensitive.
+.. index::
+   pair: JOIN; TYPE
 TYPE [ONE-TO-ONE|ONE-TO-MANY]
     The type of join. Default is one-to-one.
Modified: trunk/docs/en/mapfile/join.txt
--- trunk/docs/en/mapfile/join.txt	2011-08-23 12:55:44 UTC (rev 12096)
+++ trunk/docs/en/mapfile/join.txt	2011-08-23 13:03:28 UTC (rev 12097)
@@ -4,7 +4,7 @@
  JOIN
-.. index:: Join
+.. index:: JOIN
 Description
@@ -14,6 +14,9 @@
+.. index::
 Supported Formats
@@ -24,41 +27,65 @@
 Mapfile Parameters:
+.. index::
 CONNECTION [string]
-    <input_postgis>`:
+.. index::
+.. index::
 FOOTER [filename]
     `TEMPLATE` HTML.
+.. index::
+   pair: JOIN; FROM
 FROM [item]
+.. index::
 HEADER [filename]
     `TEMPLATE` HTML.
+.. index::
+   pair: JOIN; NAME
 NAME [string]
+.. index::
+   pair: JOIN; TABLE
+.. index::
 TEMPLATE [filename]
@@ -66,9 +93,15 @@
     object.
+.. index::
+   pair: JOIN; TO
 TO [item]
+.. index::
+   pair: JOIN; TYPE
