[mapserver-commits] r12101 - branches/branch-6-0/docs/en/mapfile
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Tue Aug 23 10:00:11 EDT 2011
Author: havatv
Date: 2011-08-23 07:00:11 -0700 (Tue, 23 Aug 2011)
New Revision: 12101
branches/branch-6-0/docs/en/mapfile/outputformat.txt
trunk/docs/en/mapfile/outputformat.txt
Added indexes (#4001)
Modified: branches/branch-6-0/docs/en/mapfile/outputformat.txt
--- branches/branch-6-0/docs/en/mapfile/outputformat.txt 2011-08-23 13:37:01 UTC (rev 12100)
+++ branches/branch-6-0/docs/en/mapfile/outputformat.txt 2011-08-23 14:00:11 UTC (rev 12101)
@@ -1,5 +1,8 @@
.. _outputformat:
+.. index::
+ single: OUTPUTFORMAT
OUTPUTFORMAT
@@ -21,61 +24,64 @@
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
+ FORMATOPTION "GAMMA=0.75"
END
OUTPUTFORMAT
- NAME gif
- DRIVER "GD/GIF"
+ NAME "gif"
+ DRIVER GD/GIF
MIMETYPE "image/gif"
IMAGEMODE PC256
EXTENSION "gif"
END
OUTPUTFORMAT
- NAME png8
- DRIVER "AGG/PNG8"
+ NAME "png8"
+ DRIVER AGG/PNG8
MIMETYPE "image/png; mode=8bit"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "QUANTIZE_FORCE=on"
FORMATOPTION "QUANTIZE_COLORS=256"
END
OUTPUTFORMAT
- NAME jpeg
- DRIVER "AGG/JPEG"
+ NAME "jpeg"
+ DRIVER AGG/JPEG
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
END
OUTPUTFORMAT
- NAME svg
- DRIVER "CAIRO/SVG"
+ NAME "svg"
+ DRIVER CAIRO/SVG
MIMETYPE "image/svg+xml"
IMAGEMODE RGB
EXTENSION "svg"
END
OUTPUTFORMAT
- NAME pdf
- DRIVER "CAIRO/PDF"
+ NAME "pdf"
+ DRIVER CAIRO/PDF
MIMETYPE "application/x-pdf"
IMAGEMODE RGB
EXTENSION "pdf"
END
OUTPUTFORMAT
- NAME GTiff
- DRIVER "GDAL/GTiff"
+ NAME "GTiff"
+ DRIVER GDAL/GTiff
MIMETYPE "image/tiff"
IMAGEMODE RGB
EXTENSION "tif"
END
OUTPUTFORMAT
- NAME kml
- DRIVER "KML"
+ NAME "kml"
+ DRIVER KML
MIMETYPE "application/vnd.google-earth.kml.xml"
IMAGEMODE RGB
EXTENSION "kml"
END
OUTPUTFORMAT
- NAME kmz
- DRIVER "KMZ"
+ NAME "kmz"
+ DRIVER KMZ
MIMETYPE "application/vnd.google-earth.kmz"
IMAGEMODE RGB
EXTENSION "kmz"
@@ -88,13 +94,9 @@
EXTENSION "png"
END
-NAME [name]
- The name to use use in the IMAGETYPE keyword of the map file to
- select this output format. This name is also used in metadata describing
- wxs formats allowed, and can be used (sometimes along with mimetype) to
- select the output format via keywords in OGC requests. (optional)
+.. index::
+ pair: OUTPUTFORMAT; DRIVER
DRIVER [name]
The name of the driver to use to generate this output format. Some driver
names include the definition of the format if the driver supports multiple
@@ -106,104 +108,184 @@
output can be generated with either GDAL or GD (GD is generally more
efficient). TEMPLATE should be used for template based output. (mandatory)
-IMAGEMODE [PC256/RGB/RGBA/INT16/FLOAT32/FEATURE]
- Selects the imaging mode in which the output is generated. Does matter
- for non-raster formats like Flash. Not all formats support all
- combinations. For instance GD supports only PC256. (optional)
- - PC256: Produced a pseudocolored result with up to 256 colors in
- the palette (legacy MapServer mode). Only supported for GD/GIF
- and GD/PNG.
- - RGB: Render in 24bit Red/Green/Blue mode. Supports all colors
- but does not support transparency.
- - RGBA: Render in 32bit Red/Green/Blue/Alpha mode. Supports all
- colors, and alpha based transparency. All features are rendered
- against an initially transparent background.
- - BYTE: Render raw 8bit pixel values (no presentation). Only
- works for RASTER layers (through GDAL) and WMS layers currently.
- - INT16: Render raw 16bit signed pixel values (no presentation).
- Only works for RASTER layers (through GDAL) and WMS layers currently.
- - FLOAT32: Render raw 32bit floating point pixel values
- (no presentation). Only works for RASTER layers (through GDAL)
- and WMS layers currently.
- - FEATURE: Output is a non-image result, such as features written
- via templates or OGR.
-MIMETYPE [type]
- Provide the mime type to be used when returning results over the web.
- (optional)
+.. index::
+ pair: OUTPUTFORMAT; EXTENSION
EXTENSION [type]
Provide the extension to use when creating files of this type. (optional)
-TRANSPARENT [ON/OFF]
- Indicates whether transparency should be enabled for this format. Note
- that transparency does not work for IMAGEMODE RGB output. Not all formats
- support transparency (optional). When transparency is enabled for the
- typical case of 8-bit pseudocolored map generation, the IMAGECOLOR color
- will be marked as transparent in the output file palette. Any other map
- components drawn in this color will also be transparent, so for map
- generation with transparency it is best to use an otherwise unused color
- as the background color.
+.. index::
+ pair: OUTPUTFORMAT; FORMATOPTION
.. _FORMATOPTION:
FORMATOPTION [option]
Provides a driver or format specific option. Zero or more FORMATOPTION
statement may be present within a OUTPUTFORMAT declaration. (optional)
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; QUALITY
- AGG/JPEG: The "QUALITY=n" option may be used to set the quality of
jpeg produced (value from 0-100).
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; INTERLACE
- GD/PNG: The "INTERLACE=[ON/OFF]" option may be used to turn
interlacing on or off.
- GD/GIF: The "INTERLACE=[ON/OFF]" option may be used to turn
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; TILED
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; BLOCKXSIZE
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; BLOCKYSIZE
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; INTERLEAVE
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; COMPRESS
- GDAL/GTiff: Supports the TILED=YES, BLOCKXSIZE=n, BLOCKYSIZE=n,
INTERLEAVE=[PIXEL/BAND] and COMPRESS=[NONE,PACKBITS,JPEG,LZW,DEFLATE]
format specific options.
- GDAL/\*: All FORMATOPTIONs are passed onto the GDAL create function.
Options supported by GDAL are described in the detailed documentation
for each GDAL format
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; NULLVALUE
- GDAL/\*: NULLVALUE=n is used in raw image modes (IMAGEMODE
BYTE/INT16/FLOAT) to pre-initialize the raster and an attempt is made
to record this in the resulting file as the nodata value. This is
automatically set in WCS mode if rangeset_nullvalue is set.
- OGR/\*: See OGR Output document for details of OGR format options.
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; GAMMA
+ - AGG/\*: GAMMA=n is used to specify the gamma correction to apply to polygon
+ rendering. Allowed values are ]0.0,1.0] , default is 0.75. This value is
+ used to prevent artifacts from appearing on the border of contiguous
+ polygons. Set to 1.0 to disable gamma correction.
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; COMPRESSION
- AGG/PNG: COMPRESSION=n is used to determine the ZLIB compression applied to
the png creation. n is expected to be an integer value from 0 to 9, with 0
meaning *no* compression (not recommended), 1 meaning fastest compression,
and 9 meaning best compression. The compression levels come at a cost (be it
in terms of cpu processing or file size, chose the setting that suits you
most). The default is COMPRESSION=6.
- AGG/PNG supports quantizing from 24/32 bits to 8bits,
in order to reduce the final image size (and therefore save bandwidth) (see
also http://trac.osgeo.org/mapserver/ticket/2436#comment:4 for strategies
when applying these options):
- - "QUANTIZE_FORCE=on" used to reduce an RGB or RGBA image into an 8bit
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; QUANTIZE_FORCE
+ - "QUANTIZE_FORCE=on" used to reduce an RGB or RGBA image into an 8bit
(or less) paletted images. The colors used in the palette are selected
to best fit the actual colors in the RGB or RGBA image.
- - "QUANTIZE_COLORS=256" used to specify the number of colors to be used
- when applying quantization. Maximum value is 256. Specifying anything
- between 17 and 255 is probably a waste of quality as each pixel is still
- encoded with a full byte. Specifying a value under 16 will produce tiny
- images, but severly degraded.
- - "PALETTE_FORCE=on" is used to reduce image depth with a predefined palette.
- This option is incompatible with the previous quantization options.
- - "PALETTE=/path/to/palette.txt" is used to define the absolute path where
- palette colors can be found. This file must contain 256 entries of r,g,b
- triplets for RGB imagemodes, or r,g,b,a quadruplets for
- RGBA imagemodes. The expected format is one triplet (or quadruplet) per
- line, each value separated by commas, and each triplet/quadruplet on a
- single line. If you want to use transparency with a palette, it is
- important to have these two colors in the palette file:
- 0,0,0,0 and 255,255,255,255.
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; QUANTIZE_COLORS
- .. NOTE::
- 0,0,0,0 is important if you have fully transparent areas.
- 255,255,255,255 is opaque white.
- The important colors to have in your palette really depend on your
- actual map, although 0,0,0,0 , 0,0,0,255 , and 255,255,255,255 are
- very likely to show up most of the time.
+ - "QUANTIZE_COLORS=256" used to specify the number of colors to be used
+ when applying quantization. Maximum value is 256. Specifying anything
+ between 17 and 255 is probably a waste of quality as each pixel is still
+ encoded with a full byte. Specifying a value under 16 will produce tiny
+ images, but severly degraded.
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; PALETTE
+ - "PALETTE=/path/to/palette.txt" is used to define the absolute path where
+ palette colors can be found. This file must contain 256 entries of r,g,b
+ triplets for RGB imagemodes, or r,g,b,a quadruplets for
+ RGBA imagemodes. The expected format is one triplet (or quadruplet) per
+ line, each value separated by commas, and each triplet/quadruplet on a
+ single line. If you want to use transparency with a palette, it is
+ important to have these two colors in the palette file:
+ 0,0,0,0 and 255,255,255,255.
+ .. NOTE::
+ 0,0,0,0 is important if you have fully transparent areas.
+ 255,255,255,255 is opaque white.
+ The important colors to have in your palette really depend on your
+ actual map, although 0,0,0,0 , 0,0,0,255 , and 255,255,255,255 are
+ very likely to show up most of the time.
+ .. index::
+ triple: OUTPUTFORMAT; FORMATOPTION; PALETTE_FORCE
+ - "PALETTE_FORCE=on" is used to reduce image depth with a predefined palette.
+ This option is incompatible with the previous quantization options.
+.. index::
+ pair: OUTPUTFORMAT; IMAGEMODE
+IMAGEMODE [PC256/RGB/RGBA/INT16/FLOAT32/FEATURE]
+ Selects the imaging mode in which the output is generated. Does matter
+ for non-raster formats like Flash. Not all formats support all
+ combinations. For instance GD supports only PC256. (optional)
+ - PC256: Produced a pseudocolored result with up to 256 colors in
+ the palette (legacy MapServer mode). Only supported for GD/GIF
+ and GD/PNG.
+ - RGB: Render in 24bit Red/Green/Blue mode. Supports all colors
+ but does not support transparency.
+ - RGBA: Render in 32bit Red/Green/Blue/Alpha mode. Supports all
+ colors, and alpha based transparency. All features are rendered
+ against an initially transparent background.
+ - BYTE: Render raw 8bit pixel values (no presentation). Only
+ works for RASTER layers (through GDAL) and WMS layers currently.
+ - INT16: Render raw 16bit signed pixel values (no presentation).
+ Only works for RASTER layers (through GDAL) and WMS layers currently.
+ - FLOAT32: Render raw 32bit floating point pixel values
+ (no presentation). Only works for RASTER layers (through GDAL)
+ and WMS layers currently.
+ - FEATURE: Output is a non-image result, such as features written
+ via templates or OGR.
+.. index::
+ pair: OUTPUTFORMAT; MIMETYPE
+MIMETYPE [type]
+ Provide the mime type to be used when returning results over the web.
+ (optional)
+.. index::
+ pair: OUTPUTFORMAT; NAME
+NAME [name]
+ The name to use in the IMAGETYPE keyword of the map file to
+ select this output format. This name is also used in metadata describing
+ wxs formats allowed, and can be used (sometimes along with mimetype) to
+ select the output format via keywords in OGC requests. (optional)
+.. index::
+ pair: OUTPUTFORMAT; TRANSPARENT
+TRANSPARENT [ON/OFF]
+ Indicates whether transparency should be enabled for this format. Note
+ that transparency does not work for IMAGEMODE RGB output. Not all formats
+ support transparency (optional). When transparency is enabled for the
+ typical case of 8-bit pseudocolored map generation, the IMAGECOLOR color
+ will be marked as transparent in the output file palette. Any other map
+ components drawn in this color will also be transparent, so for map
+ generation with transparency it is best to use an otherwise unused color
+ as the background color.
Modified: trunk/docs/en/mapfile/outputformat.txt
--- trunk/docs/en/mapfile/outputformat.txt 2011-08-23 13:37:01 UTC (rev 12100)
+++ trunk/docs/en/mapfile/outputformat.txt 2011-08-23 14:00:11 UTC (rev 12101)
@@ -1,5 +1,8 @@
.. _outputformat:
+.. index::
OUTPUTFORMAT
@@ -91,13 +94,9 @@
EXTENSION "png"
END
-NAME [name]
- The name to use in the IMAGETYPE keyword of the map file to
+.. index::
DRIVER [name]
@@ -109,108 +108,184 @@
- and GD/PNG.
-MIMETYPE [type]
- (optional)
+.. index::
EXTENSION [type]
+.. index::
.. _FORMATOPTION:
+ .. index::
+ .. index::
+ .. index::
+ .. index::
+ .. index::
+ .. index::
+ .. index::
+ .. index::
+ .. index::
+ .. index::
+ .. index::
+ .. index::
- .. NOTE::
+ .. index::
+ .. NOTE::
+ .. index::
+.. index::
+ and GD/PNG.
+.. index::
+MIMETYPE [type]
+ (optional)
+.. index::
+NAME [name]
+.. index::
More information about the mapserver-commits
