[mapserver-commits] r12102 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Tue Aug 23 10:03:43 EDT 2011
Author: havatv
Date: 2011-08-23 07:03:43 -0700 (Tue, 23 Aug 2011)
New Revision: 12102
   branches/branch-6-0/docs/en/mapfile/projection.txt
   trunk/docs/en/mapfile/projection.txt
Added indexes (#4001)
Modified: branches/branch-6-0/docs/en/mapfile/projection.txt
--- branches/branch-6-0/docs/en/mapfile/projection.txt	2011-08-23 14:00:11 UTC (rev 12101)
+++ branches/branch-6-0/docs/en/mapfile/projection.txt	2011-08-23 14:03:43 UTC (rev 12102)
@@ -1,9 +1,18 @@
 .. _projection:
+.. index::
+   single: PROJECTION
  PROJECTION
+.. index::
+   single: Geographical reference systems
+.. index::
+   single: Map projections
 There are thousands for geographical reference systems.  In order to
 combine datasets with different geographical reference systems into a
 map, the datasets will have to be transformed (projected) to the
Modified: trunk/docs/en/mapfile/projection.txt
--- trunk/docs/en/mapfile/projection.txt	2011-08-23 14:00:11 UTC (rev 12101)
+++ trunk/docs/en/mapfile/projection.txt	2011-08-23 14:03:43 UTC (rev 12102)
@@ -1,9 +1,18 @@
 .. _projection:
+.. index::
  PROJECTION
+.. index::
+.. index::
