[mapserver-commits] r12103 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Tue Aug 23 10:08:56 EDT 2011
Author: havatv
Date: 2011-08-23 07:08:56 -0700 (Tue, 23 Aug 2011)
New Revision: 12103
   branches/branch-6-0/docs/en/mapfile/reference.txt
   trunk/docs/en/mapfile/reference.txt
Added indexes (#4001)
Modified: branches/branch-6-0/docs/en/mapfile/reference.txt
--- branches/branch-6-0/docs/en/mapfile/reference.txt	2011-08-23 14:03:43 UTC (rev 12102)
+++ branches/branch-6-0/docs/en/mapfile/reference.txt	2011-08-23 14:08:56 UTC (rev 12103)
@@ -1,3 +1,8 @@
+.. index::
+   single: REFERENCE
 .. _reference:
@@ -11,38 +16,68 @@
 queries will depict the extent of the area of interest. Finally, feature based
 queries will display the selection feature(s) used.
+.. index::
+   pair: REFERENCE; COLOR
 COLOR [r] [g] [b]
     Color in which the reference box is drawn. Set any component to -1 for
     no fill. Default is red.
+.. index::
+   pair: REFERENCE; EXTENT
 EXTENT [minx][miny][maxx][maxy]
     The spatial extent of the base reference image.
+.. index::
+   pair: REFERENCE; IMAGE
 IMAGE [filename]
     Full filename of the base reference image. Must be a GIF image.
+.. index::
+   pair: REFERENCE; MARKER
 MARKER [integer|string]
     Defines a symbol (from the symbol file) to use when the box becomes too
     small (see MINBOXSIZE and MAXBOXSIZE below). Uses a crosshair by default.
+.. index::
+   pair: REFERENCE; MARKERSIZE
 MARKERSIZE [integer]
     Defines the size of the symbol to use instead of a box (see MARKER above).
+.. index::
+   pair: REFERENCE; MINBOXSIZE
 MINBOXSIZE [integer]
     If box is smaller than MINBOXSIZE (use box width or height) then use the
     symbol defined by MARKER and MARKERSIZE.
+.. index::
+   pair: REFERENCE; MAXBOXSIZE
 MAXBOXSIZE [integer]
     If box is greater than MAXBOXSIZE (use box width or height) then draw
     nothing (Often the whole map gets covered when zoomed way out and it's
     perfectly obvious where you are).
+.. index::
+   pair: REFERENCE; OUTLINECOLOR
 OUTLINECOLOR [r] [g] [b]
     Color to use for outlining the reference box. Set any component to -1
     for no outline.
+.. index::
+   pair: REFERENCE; SIZE
 SIZE [x][y]
     Size, in pixels, of the base reference image.
+.. index::
+   pair: REFERENCE; STATUS
 STATUS [on|off]
-    Is the reference map to be created? Default it off.
\ No newline at end of file
+    Is the reference map to be created? Default it off.
Modified: trunk/docs/en/mapfile/reference.txt
--- trunk/docs/en/mapfile/reference.txt	2011-08-23 14:03:43 UTC (rev 12102)
+++ trunk/docs/en/mapfile/reference.txt	2011-08-23 14:08:56 UTC (rev 12103)
@@ -1,3 +1,8 @@
+.. index::
+   single: REFERENCE
 .. _reference:
@@ -11,38 +16,68 @@
+.. index::
 COLOR [r] [g] [b]
+.. index::
+.. index::
 IMAGE [filename]
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
     for no outline.
+.. index::
 SIZE [x][y]
+.. index::
 STATUS [on|off]
