[mapserver-commits] r12104 - trunk/docs/en/development/rfc
Tue Aug 23 12:37:37 EDT 2011
Author: assefa
Date: 2011-08-23 09:37:37 -0700 (Tue, 23 Aug 2011)
New Revision: 12104
Added:
   trunk/docs/en/development/rfc/ms-rfc-73.txt
   trunk/docs/en/development/rfc/index.txt
svg symbols ssupport
Modified: trunk/docs/en/development/rfc/index.txt
--- trunk/docs/en/development/rfc/index.txt	2011-08-23 14:08:56 UTC (rev 12103)
+++ trunk/docs/en/development/rfc/index.txt	2011-08-23 16:37:37 UTC (rev 12104)
@@ -82,3 +82,4 @@
    ms-rfc-70
    ms-rfc-71
    ms-rfc-72
+   ms-rfc-73
Added: trunk/docs/en/development/rfc/ms-rfc-73.txt
--- trunk/docs/en/development/rfc/ms-rfc-73.txt	                        (rev 0)
+++ trunk/docs/en/development/rfc/ms-rfc-73.txt	2011-08-23 16:37:37 UTC (rev 12104)
@@ -0,0 +1,84 @@
+.. _rfc73:
+MS RFC 73: Improved SVG symbols support
+:Date: 2011/05/19
+:Authors: Zak James (zjames at dmsolutions.ca)
+:Authors: Yewondwossen Assefa (yassefa at dmsolutions.ca)
+:Last Edited: 2011/05/19
+:Status:  Proposed
+:Version: MapServer 6.2
+:Id: $Id:$
+Overview
+The SVG format offers several advantages over existing mapserver symbol types
+but existing support is limited. We propose the implementation of complete
+support using the libsvg-cairo library, part of the cairo project.
+Technical Solution
+All renderers will be extended with an added supports_svg flag, set to 0 for
+all but the cairo renderer. When an SVG symbol is requested, other renderers
+will trigger a call to msRenderSVGToPixmap which will parse the referenced svg
+file (using libsvg-cairo) and render the svg into the symbol's pixmapbuffer
+using cairo. After this operation, normal pixmap symbol handling will be used.
+For the cairo renderer, the renderSVGSymbolCairo function will use libsvg-cairo
+to parse the symbol, but will then use the cairo api to render the symbol
+directly.
+Configure.in will be modified to detect the --with-libsvg-cairo configure
+option and define USE_LIBSVG_CAIRO.
+Usage example
+  SYMBOL
+    NAME "svgsymbol"
+    TYPE SVG
+    IMAGE "/path/to/symbol.svg"
+  END
+... once defined, the symbol is used within the mapfile like any other.
+Backwards Compatibility Issues
+There are no compatibility issues with existing mapfiles. The SVG symbol type
+is already allowed within a SYMBOLSET. SVG Symbol support will be disabled by
+default. Enabling it will require installation of the libsvg-cairo library
+available from
+* http://cairographics.org/snapshots/libsvg-cairo-0.1.6.tar.gz
+Affected Files
+* mapserver.h
+* mapdraw.c
+* mapdummyrenderer.c
+* maprendering.c
+* mapsymbol.c
+* mapsymbol.h
+* mapcairo.c
+* mapagg.cpp
+* configure.in
+Ticket Id
+* http://trac.osgeo.org/mapserver/ticket/3671
+Voting History
Property changes on: trunk/docs/en/development/rfc/ms-rfc-73.txt
___________________________________________________________________
Added: svn:executable
