[mapserver-commits] r12169 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:03:57 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:03:57 -0700 (Fri, 26 Aug 2011)
New Revision: 12169
Added:
trunk/mapserver/mapcache/src/lock.c
trunk/mapserver/mapcache/src/source_gdal.c
trunk/mapserver/mapcache/src/cache_disk.c
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/fastcgi_geocache.c
trunk/mapserver/mapcache/src/tileset.c
report errors back to users (will be configurable)
thomas.bonfort | 2010-12-09 16:13:51 +0100 (Thu, 09 Dec 2010)
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:03:51 UTC (rev 12168)
+++ trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:03:57 UTC (rev 12169)
@@ -85,150 +85,8 @@
return GEOCACHE_FALSE;
- * \brief lock the given tile so other processes know it is being processed
- * this function creates a file with a .lck extension and puts an exclusive lock on it
- * \sa geocache_cache::tile_lock()
- * \sa geocache_cache::tile_lock_exists()
- * \private \memberof geocache_cache_disk
-void _geocache_cache_disk_tile_lock(geocache_context *ctx, geocache_tile *tile) {
- char *filename;
- char *basename;
- char *dirname;
- apr_file_t *f;
- apr_status_t rv;
- _geocache_cache_disk_tile_key_split(ctx, tile, &dirname, &basename);
- GC_CHECK_ERROR(ctx);
- rv = apr_dir_make_recursive(dirname,APR_OS_DEFAULT,ctx->pool);
- if(rv != APR_SUCCESS) {
- ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to create directory %s",dirname);
- return;
- filename = apr_psprintf(ctx->pool,"%s/%s.lck",dirname,basename);
- /*create file, and fail if it already exists*/
- if(apr_file_open(&f, filename,
- APR_FOPEN_CREATE|APR_FOPEN_EXCL|APR_FOPEN_WRITE|APR_FOPEN_SHARELOCK|APR_FOPEN_BUFFERED|APR_FOPEN_BINARY,
- APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
- * opening failed, is this because we don't have write permissions, or because
- * the file already exists?
- if(apr_file_open(&f, filename, APR_FOPEN_CREATE|APR_FOPEN_WRITE, APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
- ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to create file %s",filename);
- return; /* we could not create the file */
- } else {
- ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to create lockfile %s, because it already exists",filename);
- apr_file_close(f);
- return; /* we have write access, but the file already exists */
- rv = apr_file_lock(f, APR_FLOCK_EXCLUSIVE|APR_FLOCK_NONBLOCK);
- if(rv == EAGAIN) {
- ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "####### TILE LOCK ######## file %s is already locked",filename);
- } else {
- ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to lock file %s",filename);
- return;
- tile->lock = f;
- * \brief unlock a previously locked tile
- * \sa geocache_cache::tile_unlock()
-void _geocache_cache_disk_tile_unlock(geocache_context *ctx, geocache_tile *tile) {
- apr_file_t *f = (apr_file_t*)tile->lock;
- const char *fname;
- if(!tile->lock) {
- char *filename;
- char *lockname;
- _geocache_cache_disk_tile_key(ctx, tile, &filename);
- ctx->log(ctx, GEOCACHE_ERROR, "###### TILE UNLOCK ######### attempting to unlock tile %s not created by this thread", filename);
- lockname = apr_psprintf(ctx->pool,"%s.lck",filename);
- if(apr_file_open(&f, lockname,APR_FOPEN_READ,APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
- ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "###### TILE UNLOCK ######### tile %s is not locked", lockname);
- return;
- } else {
- f = (apr_file_t*)tile->lock;
- apr_file_name_get(&fname,f);
- apr_file_remove(fname,ctx->pool);
- int rv = apr_file_unlock(f);
- ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to unlock file %s",fname);
- return;
- rv = apr_file_close(f);
- ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to close file %s", fname);
- return;
- tile->lock = NULL;
- * \brief query tile to check if the corresponding lockfile exists
-int _geocache_cache_disk_tile_is_locked(geocache_context *ctx, geocache_tile *tile) {
- char *filename;
- char *lockname;
- apr_file_t *f;
- if(tile->lock)
- return GEOCACHE_TRUE;
- return GEOCACHE_FALSE;
- } else {
- * \brief wait for a lock on given tile
- * this function will not return until the lock on the tile has been removed
- * \sa geocache_cache::tile_lock_wait()
-void _geocache_cache_disk_tile_wait_for_lock(geocache_context *ctx, geocache_tile *tile) {
- char *filename;
- char *lockname;
- apr_file_t *f;
-#ifdef DEBUG
- if(tile->lock) {
- ctx->set_error(ctx,GEOCACHE_DISK_ERROR, "### BUG ### waiting for a lock we have created ourself");
- return;
-#endif
- ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "### BUG ### waiting for a lock on an unlocked file");
- return;
- apr_file_lock(f,APR_FLOCK_SHARED);
* \brief get file content of given tile
* fills the geocache_tile::data of the given tile with content stored in the file
@@ -287,7 +145,7 @@
void _geocache_cache_disk_set(geocache_context *ctx, geocache_tile *tile) {
apr_size_t bytes;
apr_file_t *f;
- char *filename;
+ char *basename, *path, *filename;
#ifdef DEBUG
/* all this should be checked at a higher level */
if(!tile->data || !tile->data->size) {
@@ -299,8 +157,15 @@
return;
#endif
+ _geocache_cache_disk_tile_key_split(ctx, tile, &path, &basename);
+ if(APR_SUCCESS != apr_dir_make_recursive(path,APR_OS_DEFAULT,ctx->pool)) {
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to create directory %s",path);
+ return;
+ filename = apr_psprintf(ctx->pool,"%s/%s",path,basename);
if(((geocache_cache_disk*)tile->tileset->cache)->symlink_blank) {
geocache_image *image = geocache_imageio_decode(ctx, tile->data);
@@ -431,10 +296,6 @@
cache->cache.tile_set = _geocache_cache_disk_set;
cache->cache.configuration_check = _geocache_cache_disk_configuration_check;
cache->cache.configuration_parse = _geocache_cache_disk_configuration_parse;
- cache->cache.tile_lock = _geocache_cache_disk_tile_lock;
- cache->cache.tile_unlock = _geocache_cache_disk_tile_unlock;
- cache->cache.tile_lock_exists = _geocache_cache_disk_tile_is_locked;
- cache->cache.tile_lock_wait = _geocache_cache_disk_tile_wait_for_lock;
return (geocache_cache*)cache;
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:03:51 UTC (rev 12168)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:03:57 UTC (rev 12169)
@@ -5,6 +5,7 @@
#include <stdlib.h>
#include <apr_strings.h>
#include <apr_hash.h>
+#include <apr_file_io.h>
geocache_cfg* geocache_configuration_create(apr_pool_t *pool) {
geocache_cfg *cfg = (geocache_cfg*)apr_pcalloc(pool, sizeof(geocache_cfg));
@@ -23,6 +24,7 @@
geocache_imageio_create_jpeg_format(pool,"JPEG",95),
"JPEG");
cfg->merge_format = geocache_configuration_get_image_format(cfg,"PNG");
+ cfg->lockdir = "/tmp/geocache_locks";
return cfg;
@@ -47,6 +49,7 @@
void geocache_configuration_add_tileset(geocache_cfg *config, geocache_tileset *tileset, const char * key) {
+ tileset->config = config;
apr_hash_set(config->tilesets, key, APR_HASH_KEY_STRING, (void*)tileset);
@@ -446,7 +449,8 @@
void geocache_configuration_parse(geocache_context *ctx, const char *filename, geocache_cfg *config) {
xmlDocPtr doc;
+ char *testlockfilename;
+ apr_file_t *testlockfile;
doc = xmlReadFile(filename, NULL, 0);
if (doc == NULL) {
ctx->set_error(ctx,GEOCACHE_PARSE_ERROR, "libxml2 failed to parse file %s. Is it valid XML?", filename);
@@ -483,11 +487,13 @@
if(!value || !*value || xmlStrcmp(value, BAD_CAST "false")) {
config->services[GEOCACHE_SERVICE_WMS] = geocache_service_wms_create(ctx);
- }else if(!xmlStrcmp(service_node->name, BAD_CAST "tms")) {
+ xmlFree(value);
+ } else if(!xmlStrcmp(service_node->name, BAD_CAST "tms")) {
xmlChar* value = xmlNodeGetContent(service_node);
config->services[GEOCACHE_SERVICE_TMS] = geocache_service_tms_create(ctx);
+ xmlFree(value);
} else if(!xmlStrcmp(cur_node->name, BAD_CAST "merge_format")) {
@@ -500,11 +506,16 @@
config->merge_format = format;
+ } else if(!xmlStrcmp(cur_node->name, BAD_CAST "lock_dir")) {
+ xmlChar *value = xmlNodeGetContent(cur_node);
+ config->lockdir = apr_pstrdup(ctx->pool, (char*)value);
+ xmlFree(value);
} else {
ctx->set_error(ctx, GEOCACHE_PARSE_ERROR, "failed to parse geocache config file %s: unknown tag <%s>",
filename, cur_node->name);
return;
} else {
@@ -515,6 +526,20 @@
return;
+ /* check our lock directory is valid and writable */
+ if(APR_SUCCESS != apr_dir_make_recursive(config->lockdir, APR_OS_DEFAULT, ctx->pool)) {
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to create lock directory %s",config->lockdir);
+ return;
+ testlockfilename = apr_psprintf(ctx->pool,"%s/test.lock",config->lockdir);
+ if(apr_file_open(&testlockfile, testlockfilename, APR_FOPEN_CREATE|APR_FOPEN_WRITE,
+ APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to create test lockfile %s",testlockfilename);
+ return; /* we could not create the file */
+ apr_file_close(testlockfile);
+ apr_file_remove(testlockfilename,ctx->pool);
if(!config->services[GEOCACHE_SERVICE_WMS] &&
!config->services[GEOCACHE_SERVICE_TMS]) {
ctx->set_error(ctx, GEOCACHE_PARSE_ERROR, "no services configured."
Modified: trunk/mapserver/mapcache/src/fastcgi_geocache.c
--- trunk/mapserver/mapcache/src/fastcgi_geocache.c 2011-08-26 11:03:51 UTC (rev 12168)
+++ trunk/mapserver/mapcache/src/fastcgi_geocache.c 2011-08-26 11:03:57 UTC (rev 12169)
@@ -105,11 +105,18 @@
geocache_context_fcgi *ctx = apr_pcalloc(pool, sizeof(geocache_context_fcgi));
ctx->ctx.pool = pool;
init_fcgi_context(ctx);
- ret = apr_proc_mutex_create(&ctx->mutex,"geocache_mutex",APR_LOCK_DEFAULT,pool);
+ ctx->ctx.log(ctx,GEOCACHE_DEBUG,"before mutex");
+ ret = apr_proc_mutex_child_init(&ctx->mutex,"geocache_mutex",pool);
+ ctx->ctx.log(ctx,GEOCACHE_DEBUG,"after mutex");
if(ret != APR_SUCCESS) {
- ctx->ctx.set_error(&ctx->ctx,GEOCACHE_MUTEX_ERROR,"failed to created mutex");
- } else {
- apr_pool_cleanup_register(pool,ctx->mutex,(void*)apr_proc_mutex_destroy, apr_pool_cleanup_null);
+ ctx->ctx.log(ctx,GEOCACHE_DEBUG,"create mutex");
+ ret = apr_proc_mutex_create(&ctx->mutex,"geocache_mutex",APR_LOCK_DEFAULT,pool);
+ if(ret != APR_SUCCESS) {
+ ctx->ctx.set_error(&ctx->ctx,GEOCACHE_MUTEX_ERROR,"failed to created mutex");
+ } else {
+ apr_pool_cleanup_register(pool,ctx->mutex,(void*)apr_proc_mutex_destroy, apr_pool_cleanup_null);
return ctx;
Added: trunk/mapserver/mapcache/src/lock.c
--- trunk/mapserver/mapcache/src/lock.c (rev 0)
+++ trunk/mapserver/mapcache/src/lock.c 2011-08-26 11:03:57 UTC (rev 12169)
@@ -0,0 +1,135 @@
+#include "geocache.h"
+#include <apr_strings.h>
+char *geocache_tileset_tile_lock_key(geocache_context *ctx, geocache_tile *tile) {
+ return apr_psprintf(ctx->pool,
+ "%s/%s-%d-%d-%d.lck",
+ tile->tileset->config->lockdir,
+ tile->tileset->name,
+ tile->z, tile->y, tile->x);
+ * \brief lock the given tile so other processes know it is being processed
+ * this function creates a file with a .lck extension and puts an exclusive lock on it
+ * \sa geocache_cache::tile_lock()
+ * \sa geocache_cache::tile_lock_exists()
+ * \private \memberof geocache_cache_disk
+void geocache_tileset_tile_lock(geocache_context *ctx, geocache_tile *tile) {
+ char *lockname;
+ apr_file_t *f;
+ apr_status_t rv;
+ lockname = geocache_tileset_tile_lock_key(ctx,tile);
+ /*create file, and fail if it already exists*/
+ if (apr_file_open(&f, lockname,
+ APR_FOPEN_CREATE | APR_FOPEN_EXCL | APR_FOPEN_WRITE | APR_FOPEN_SHARELOCK | APR_FOPEN_BUFFERED | APR_FOPEN_BINARY,
+ * opening failed, is this because we don't have write permissions, or because
+ * the file already exists?
+ if (apr_file_open(&f, lockname, APR_FOPEN_CREATE | APR_FOPEN_WRITE, APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to create lockfile %s", lockname);
+ } else {
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to create lockfile %s, because it already exists", lockname);
+ apr_file_close(f);
+ return; /* we have write access, but the file already exists */
+ rv = apr_file_lock(f, APR_FLOCK_EXCLUSIVE | APR_FLOCK_NONBLOCK);
+ if (rv != APR_SUCCESS) {
+ if (rv == EAGAIN) {
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "####### TILE LOCK ######## file %s is already locked", lockname);
+ } else {
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to lock file %s", lockname);
+ return;
+ tile->lock = f;
+ * \brief unlock a previously locked tile
+ * \sa geocache_cache::tile_unlock()
+void geocache_tileset_tile_unlock(geocache_context *ctx, geocache_tile *tile) {
+ apr_file_t *f = (apr_file_t*) tile->lock;
+ const char *lockname;
+ if (!tile->lock) {
+ lockname = geocache_tileset_tile_lock_key(ctx, tile);
+ ctx->log(ctx, GEOCACHE_ERROR, "###### TILE UNLOCK ######### attempting to unlock tile %s not created by this thread", lockname);
+ /*fail if the lock does not exists*/
+ if (apr_file_open(&f, lockname, APR_FOPEN_READ, APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "###### TILE UNLOCK ######### tile %s is not locked", lockname);
+ return;
+ } else {
+ f = (apr_file_t*) tile->lock;
+ apr_file_name_get(&lockname, f);
+ apr_file_remove(lockname, ctx->pool);
+ int rv = apr_file_unlock(f);
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to unlock file %s", lockname);
+ return;
+ rv = apr_file_close(f);
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "failed to close file %s", lockname);
+ return;
+ tile->lock = NULL;
+ * \brief query tile to check if the corresponding lockfile exists
+int geocache_tileset_tile_lock_exists(geocache_context *ctx, geocache_tile *tile) {
+ char *lockname;
+ apr_file_t *f;
+ if (tile->lock)
+ return GEOCACHE_TRUE;
+ return GEOCACHE_FALSE;
+ } else {
+ * \brief wait for a lock on given tile
+ * this function will not return until the lock on the tile has been removed
+ * \sa geocache_cache::tile_lock_wait()
+void geocache_tileset_tile_lock_wait(geocache_context *ctx, geocache_tile *tile) {
+ char *lockname;
+ apr_file_t *f;
+#ifdef DEBUG
+ if (tile->lock) {
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "### BUG ### waiting for a lock we have created ourself");
+ return;
+#endif
+ ctx->set_error(ctx, GEOCACHE_DISK_ERROR, "### BUG ### waiting for a lock on an unlocked file");
+ return;
+ apr_file_lock(f, APR_FLOCK_SHARED);
Added: trunk/mapserver/mapcache/src/source_gdal.c
--- trunk/mapserver/mapcache/src/source_gdal.c (rev 0)
+++ trunk/mapserver/mapcache/src/source_gdal.c 2011-08-26 11:03:57 UTC (rev 12169)
@@ -0,0 +1,102 @@
+#include <libxml/tree.h>
+#include <apr_tables.h>
+ * \private \memberof geocache_source_gdal
+ * \sa geocache_source::render_tile()
+void _geocache_source_gdal_render_tile(geocache_context *ctx, geocache_tile *tile) {
+ geocache_source_gdal *gdal = (geocache_source_gdal*)tile->tileset->source;
+ apr_table_t *params = apr_table_clone(ctx->pool,gdal->gdal_default_params);
+ double bbox[4];
+ geocache_tileset_tile_bbox(tile,bbox);
+ apr_table_setn(params,"BBOX",apr_psprintf(ctx->pool,"%f,%f,%f,%f",bbox[0],bbox[1],bbox[2],bbox[3]));
+ apr_table_setn(params,"WIDTH",apr_psprintf(ctx->pool,"%d",tile->sx));
+ apr_table_setn(params,"HEIGHT",apr_psprintf(ctx->pool,"%d",tile->sy));
+ apr_table_setn(params,"FORMAT","image/png");
+ apr_table_setn(params,"SRS",tile->tileset->srs);
+ apr_table_overlap(params,gdal->gdal_params,0);
+ tile->data = geocache_buffer_create(1000,ctx->pool);
+ geocache_http_request_url_with_params(ctx,gdal->url,params,tile->data);
+ * \sa geocache_source::render_metatile()
+void _geocache_source_gdal_render_metatile(geocache_context *ctx, geocache_metatile *tile) {
+ geocache_source_gdal *gdal = (geocache_source_gdal*)tile->tile.tileset->source;
+ tile->tile.data = geocache_buffer_create(30000,ctx->pool);
+ geocache_http_request_url_with_params(ctx,gdal->url,params,tile->tile.data);
+ GC_CHECK_ERROR(ctx);
+ if(!geocache_imageio_is_valid_format(ctx,tile->tile.data)) {
+ ctx->set_error(ctx, GEOCACHE_SOURCE_GDAL, "gdal request failed for tileset %s: %d %d %d returned an unsupported format",
+ tile->tile.tileset->name, tile->tile.x, tile->tile.y, tile->tile.z);
+ * \sa geocache_source::configuration_parse()
+void _geocache_source_gdal_configuration_parse(geocache_context *ctx, xmlNode *xml, geocache_source *source) {
+ xmlNode *cur_node;
+ geocache_source_gdal *src = (geocache_source_gdal*)source;
+ for(cur_node = xml->children; cur_node; cur_node = cur_node->next) {
+ if(cur_node->type != XML_ELEMENT_NODE) continue;
+ if(!xmlStrcmp(cur_node->name, BAD_CAST "data")) {
+ char* value = (char*)xmlNodeGetContent(cur_node);
+ src->data = value;
+ } else if(!xmlStrcmp(cur_node->name, BAD_CAST "options")) {
+ xmlNode *param_node;
+ for(param_node = cur_node->children; param_node; param_node = param_node->next) {
+ char *key,*value;
+ if(param_node->type != XML_ELEMENT_NODE) continue;
+ value = (char*)xmlNodeGetContent(param_node);
+ key = apr_pstrdup(ctx->pool, (char*)param_node->name);
+ apr_table_setn(src->gdal_params, key, value);
+ * \sa geocache_source::configuration_check()
+void _geocache_source_gdal_configuration_check(geocache_context *ctx, geocache_source *source) {
+ /* check all required parameters are configured */
+ if(!strlen(src->data)) {
+ ctx->set_error(ctx, GEOCACHE_SOURCE_GDAL, "gdal source %s has no data",source->name);
+ /* TODO: open source and check it accepts given options */
+geocache_source* geocache_source_gdal_create(geocache_context *ctx) {
+ geocache_source_gdal *source = apr_pcalloc(ctx->pool, sizeof(geocache_source_gdal));
+ if(!source) {
+ ctx->set_error(ctx, GEOCACHE_ALLOC_ERROR, "failed to allocate gdal source");
+ return NULL;
+ geocache_source_init(ctx, &(source->source));
+ source->source.type = GEOCACHE_SOURCE_GDAL;
+ source->source.supports_metatiling = 1;
+ source->source.render_tile = _geocache_source_gdal_render_tile;
+ source->source.render_metatile = _geocache_source_gdal_render_metatile;
+ source->source.configuration_check = _geocache_source_gdal_configuration_check;
+ source->source.configuration_parse = _geocache_source_gdal_configuration_parse;
+ source->options = apr_table_make(ctx->pool,4);
+ return (geocache_source*)source;
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:03:51 UTC (rev 12168)
+++ trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:03:57 UTC (rev 12169)
@@ -66,13 +66,13 @@
int i;
for(i=0; i<mt->ntiles; i++) {
geocache_tile *tile = &(mt->tiles[i]);
- mt->tile.tileset->cache->tile_lock(ctx, tile);
+ geocache_tileset_tile_lock(ctx, tile);
if(GC_HAS_ERROR(ctx)) {
/* undo successful locks */
int j;
for(j=0;j<i;j++) {
tile = &(mt->tiles[j]);
- mt->tile.tileset->cache->tile_unlock(ctx,tile);
+ geocache_tileset_tile_unlock(ctx,tile);
@@ -85,7 +85,7 @@
int i;
- mt->tile.tileset->cache->tile_unlock(ctx, tile);
+ geocache_tileset_tile_unlock(ctx, tile);
@@ -175,6 +175,7 @@
tileset->extent[0]=tileset->extent[1]=tileset->extent[2]=tileset->extent[3]=0;
tileset->forwarded_params = apr_table_make(ctx->pool,1);
tileset->format = NULL;
+ tileset->config = NULL;
return tileset;
@@ -244,7 +245,7 @@
ctx->global_lock_aquire(ctx,0);
- isLocked = tile->tileset->cache->tile_lock_exists(ctx, tile);
+ isLocked = geocache_tileset_tile_lock_exists(ctx, tile);
if(isLocked == GEOCACHE_FALSE) {
/* no other thread is doing the rendering, we aquire and lock a list of tiles to render */
mt = _geocache_tileset_metatile_get(ctx, tile);
@@ -261,7 +262,7 @@
ctx->log(ctx, GEOCACHE_DEBUG, "cache wait: tileset %s - tile %d %d %d",
tile->tileset->name,tile->x, tile->y,tile->z);
#endif
- tile->tileset->cache->tile_lock_wait(ctx,tile);
+ geocache_tileset_tile_lock_wait(ctx,tile);
} else {
/* no other thread is doing the rendering, do it ourselves */
More information about the mapserver-commits
