[mapserver-commits] r12170 - trunk/mapserver/mapcache/include
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:04:02 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:04:01 -0700 (Fri, 26 Aug 2011)
New Revision: 12170
trunk/mapserver/mapcache/include/geocache.h
fix png packing bits
thomas.bonfort | 2010-12-09 18:04:33 +0100 (Thu, 09 Dec 2010)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:03:57 UTC (rev 12169)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:04:01 UTC (rev 12170)
@@ -58,7 +58,7 @@
typedef struct geocache_source_wms geocache_source_wms;
typedef struct geocache_cache_disk geocache_cache_disk;
typedef struct geocache_request geocache_request;
-typedef struct geocache_service geocache_service;
+typedef struct geocache_service geocache_service;
typedef struct geocache_service_wms geocache_service_wms;
typedef struct geocache_service_wmts geocache_service_wmts;
typedef struct geocache_service_tms geocache_service_tms;
@@ -76,62 +76,64 @@
* \brief structure passed to most geocache functions to abstract common functions
struct geocache_context {
- * \brief indicate that an error has happened
- * \memberof geocache_context
- * \param c
- * \param code the error code
- * \param message human readable message of what happened
- void (*set_error)(geocache_context *ctx, geocache_error_code code, char *message, ...);
- * \brief query context to know if an error has occured
- geocache_error_code (*get_error)(geocache_context *ctx);
- * \brief get human readable message for the error
- char* (*get_error_message)(geocache_context *ctx);
- * \brief log a message
- void (*log)(geocache_context *ctx, geocache_log_level level, char *message, ...);
- * \brief aquire a lock shared between all instances of geocache.
- * depending on the underlying backend, this lock should be effective between threads and/or processes
- * \param c
- * \param nonblocking should the call block while waiting for the lock. if set to 0, the function will
- * return once the lock has been aquired. if set to 1, the function will return immediately, and
- * the return value should be checked to verify if the lock was successfully aquired, or if
- * another instance of geocache had already quired the lock
- * \returns GEOCACHE_SUCCESS if the lock was aquired
- * \returns GEOCACHE_FAILURE if there was an error aquiring the lock
- * \returns GEOCACHE_LOCKED if \param nonblocking was set to 1 and another instance has already aquired
- * the lock
- void (*global_lock_aquire)(geocache_context *ctx, int nonblocking);
- * \brief release a previously aquired lock
- * calling this function after an unsuccessful call to global_lock_aquire() or from a different thread
- * or process that has called global_lock_aquire() has undefined behavior
- void (*global_lock_release)(geocache_context *ctx);
- apr_pool_t *pool;
- char *_errmsg;
- geocache_error_code _errcode;
+ * \brief indicate that an error has happened
+ * \memberof geocache_context
+ * \param c
+ * \param code the error code
+ * \param message human readable message of what happened
+ void (*set_error)(geocache_context *ctx, geocache_error_code code, char *message, ...);
+ * \brief query context to know if an error has occured
+ geocache_error_code(*get_error)(geocache_context * ctx);
+ * \brief get human readable message for the error
+ char* (*get_error_message)(geocache_context * ctx);
+ * \brief log a message
+ void (*log)(geocache_context *ctx, geocache_log_level level, char *message, ...);
+ * \brief aquire a lock shared between all instances of geocache.
+ * depending on the underlying backend, this lock should be effective between threads and/or processes
+ * \param c
+ * \param nonblocking should the call block while waiting for the lock. if set to 0, the function will
+ * return once the lock has been aquired. if set to 1, the function will return immediately, and
+ * the return value should be checked to verify if the lock was successfully aquired, or if
+ * another instance of geocache had already quired the lock
+ * \returns GEOCACHE_SUCCESS if the lock was aquired
+ * \returns GEOCACHE_FAILURE if there was an error aquiring the lock
+ * \returns GEOCACHE_LOCKED if \param nonblocking was set to 1 and another instance has already aquired
+ * the lock
+ void (*global_lock_aquire)(geocache_context *ctx, int nonblocking);
+ * \brief release a previously aquired lock
+ * calling this function after an unsuccessful call to global_lock_aquire() or from a different thread
+ * or process that has called global_lock_aquire() has undefined behavior
+ void (*global_lock_release)(geocache_context * ctx);
+ const char* (*get_instance_id)(geocache_context * ctx);
+ apr_pool_t *pool;
+ char *_errmsg;
+ geocache_error_code _errcode;
void geocache_context_init(geocache_context *ctx);
@@ -139,6 +141,7 @@
#define GC_CHECK_ERROR_RETURN(ctx) (if(((geocache_context*)ctx)->_errcode) return GEOCACHE_FAILURE;)
#define GC_CHECK_ERROR(ctx) if(((geocache_context*)ctx)->_errcode) return;
#define GC_HAS_ERROR(ctx) (((geocache_context*)ctx)->_errcode > 0)
* \brief autoexpanding buffer that allocates memory from a pool
* \sa geocache_buffer_create()
@@ -146,10 +149,10 @@
struct geocache_buffer {
- unsigned char* buf ; /**< pointer to the actual data contained in buffer */
- size_t size ; /**< number of bytes actually used in the buffer */
- size_t avail ; /**< number of bytes allocated */
- apr_pool_t* pool; /**< apache pool to allocate from */
+ unsigned char* buf; /**< pointer to the actual data contained in buffer */
+ size_t size; /**< number of bytes actually used in the buffer */
+ size_t avail; /**< number of bytes allocated */
+ apr_pool_t* pool; /**< apache pool to allocate from */
/* in buffer.c */
@@ -174,106 +177,85 @@
/** \defgroup source Sources */
-typedef enum {GEOCACHE_SOURCE_WMS} geocache_source_type;
+typedef enum {
+ GEOCACHE_SOURCE_WMS
+} geocache_source_type;
/**\interface geocache_source
* \brief a source of data that can return image data
struct geocache_source {
- char *name; /**< the key this source can be referenced by */
- char *srs; /**< data SRS */
- double data_extent[4]; /**< extent in which this source can produce data */
- geocache_source_type type;
- int supports_metatiling;
- * \brief get the data for the tile
- * sets the geocache_tile::data for the given tile
- * \deprecated
- void (*render_tile)(geocache_context *ctx, geocache_tile *tile);
- * \brief get the data for the metatile
- * sets the geocache_metatile::tile::data for the given tile
- void (*render_metatile)(geocache_context *ctx, geocache_metatile *mt);
- void (*configuration_parse)(geocache_context *ctx, xmlNode *xml, geocache_source *source);
- void (*configuration_check)(geocache_context *ctx, geocache_source *source);
+ char *name; /**< the key this source can be referenced by */
+ char *srs; /**< data SRS */
+ double data_extent[4]; /**< extent in which this source can produce data */
+ geocache_source_type type;
+ int supports_metatiling;
+ * \brief get the data for the tile
+ * sets the geocache_tile::data for the given tile
+ * \deprecated
+ void (*render_tile)(geocache_context *ctx, geocache_tile * tile);
+ * \brief get the data for the metatile
+ * sets the geocache_metatile::tile::data for the given tile
+ void (*render_metatile)(geocache_context *ctx, geocache_metatile * mt);
+ void (*configuration_parse)(geocache_context *ctx, xmlNode *xml, geocache_source * source);
+ void (*configuration_check)(geocache_context *ctx, geocache_source * source);
/**\class geocache_source_wms
* \brief WMS geocache_source
* \implements geocache_source
struct geocache_source_wms {
- geocache_source source;
- char *url; /**< the base WMS url */
- apr_table_t *wms_default_params; /**< default WMS parameters (SERVICE,REQUEST,STYLES,VERSION) */
- apr_table_t *wms_params; /**< WMS parameters specified in configuration */
+ geocache_source source;
+ char *url; /**< the base WMS url */
+ apr_table_t *wms_default_params; /**< default WMS parameters (SERVICE,REQUEST,STYLES,VERSION) */
+ apr_table_t *wms_params; /**< WMS parameters specified in configuration */
/** \defgroup cache Caches */
-typedef enum {GEOCACHE_CACHE_DISK} geocache_cache_type;
+typedef enum {
+ GEOCACHE_CACHE_DISK
+} geocache_cache_type;
/** \interface geocache_cache
* \brief a place to cache a geocache_tile
struct geocache_cache {
- char *name; /**< key this cache is referenced by */
- geocache_cache_type type;
- * get tile content from cache
- * \returns GEOCACHE_SUCCESS if the data was correctly loaded from the disk
- * \returns GEOCACHE_FAILURE if the file exists but contains no data
- * \returns GEOCACHE_CACHE_MISS if the file does not exist on the disk
- * \memberof geocache_cache
- int (*tile_get)(geocache_context *ctx, geocache_tile *tile);
+ char *name; /**< key this cache is referenced by */
+ geocache_cache_type type;
+ * get tile content from cache
+ * \returns GEOCACHE_SUCCESS if the data was correctly loaded from the disk
+ * \returns GEOCACHE_FAILURE if the file exists but contains no data
+ * \returns GEOCACHE_CACHE_MISS if the file does not exist on the disk
+ * \memberof geocache_cache
+ int (*tile_get)(geocache_context *ctx, geocache_tile * tile);
- int (*tile_exists)(geocache_context *ctx, geocache_tile *tile);
- * set tile content to cache
- void (*tile_set)(geocache_context *ctx, geocache_tile *tile);
- void (*configuration_parse)(geocache_context *ctx, xmlNode *xml, geocache_cache *cache);
- void (*configuration_check)(geocache_context *ctx, geocache_cache *cache);
- * lock the tile
- void (*tile_lock)(geocache_context *ctx, geocache_tile *tile);
- * unlock the tile
- void (*tile_unlock)(geocache_context *ctx, geocache_tile *tile);
- * check if there is a lock on the tile (the lock will have been set by another process/thread)
- * \returns GEOCACHE_TRUE if the tile is locked by another process/thread
- * \returns GEOCACHE_FALSE if there is no lock on the tile
- int (*tile_lock_exists)(geocache_context *ctx, geocache_tile *tile);
- * wait for the lock set on the tile (the lock will have been set by another process/thread)
- void (*tile_lock_wait)(geocache_context *ctx, geocache_tile *tile);
+ int (*tile_exists)(geocache_context *ctx, geocache_tile * tile);
+ * set tile content to cache
+ void (*tile_set)(geocache_context *ctx, geocache_tile * tile);
+ void (*configuration_parse)(geocache_context *ctx, xmlNode *xml, geocache_cache * cache);
+ void (*configuration_check)(geocache_context *ctx, geocache_cache * cache);
/**\class geocache_cache_disk
@@ -281,9 +263,9 @@
* \implements geocache_cache
struct geocache_cache_disk {
- geocache_cache cache;
- char *base_directory;
- int symlink_blank;
+ geocache_cache cache;
+ char *base_directory;
+ int symlink_blank;
@@ -292,18 +274,18 @@
* \brief a request sent by a client
struct geocache_request {
- * a list of tiles requested by the client
- geocache_tile **tiles;
+ * a list of tiles requested by the client
+ geocache_tile **tiles;
- * the number of tiles requested by the client.
- * If more than one, and merging is enabled,
- * the supplied tiles will be merged together
- * before being returned to the client
- int ntiles;
+ * the number of tiles requested by the client.
+ * If more than one, and merging is enabled,
+ * the supplied tiles will be merged together
+ * before being returned to the client
+ int ntiles;
/** \defgroup services Services*/
@@ -311,20 +293,24 @@
#define GEOCACHE_SERVICES_COUNT 3
-typedef enum {GEOCACHE_SERVICE_WMS=0, GEOCACHE_SERVICE_TMS, GEOCACHE_SERVICE_WMTS} geocache_service_type;
+typedef enum {
+ GEOCACHE_SERVICE_WMS = 0, GEOCACHE_SERVICE_TMS, GEOCACHE_SERVICE_WMTS
+} geocache_service_type;
-typedef enum {GEOCACHE_UNIT_UNSET = 0, GEOCACHE_UNIT_METERS, GEOCACHE_UNIT_DEGREES, GEOCACHE_UNIT_FEET} geocache_unit;
+typedef enum {
+ GEOCACHE_UNIT_UNSET = 0, GEOCACHE_UNIT_METERS, GEOCACHE_UNIT_DEGREES, GEOCACHE_UNIT_FEET
+} geocache_unit;
/** \interface geocache_service
* \brief a standard service (eg WMS, TMS)
struct geocache_service {
- geocache_service_type type;
- * \returns a geocache_request corresponding to the parameters received
- * \returns NULL if the request does not correspond the the service
- geocache_request* (*parse_request)(geocache_context *ctx, char *path_info, apr_table_t *params, geocache_cfg *config);
+ geocache_service_type type;
+ * \returns a geocache_request corresponding to the parameters received
+ * \returns NULL if the request does not correspond the the service
+ geocache_request * (*parse_request)(geocache_context *ctx, char *path_info, apr_table_t *params, geocache_cfg * config);
/**\class geocache_service_wms
@@ -332,7 +318,7 @@
* \implements geocache_service
struct geocache_service_wms {
- geocache_service service;
+ geocache_service service;
/**\class geocache_service_tms
@@ -340,7 +326,7 @@
struct geocache_service_tms {
/**\class geocache_service_wmts
@@ -348,7 +334,7 @@
struct geocache_service_wmts {
@@ -366,20 +352,23 @@
/** \defgroup image Image Data Handling */
-typedef enum {GC_UNKNOWN, GC_PNG, GC_JPEG} geocache_image_format_type;
+typedef enum {
+ GC_UNKNOWN, GC_PNG, GC_JPEG
+} geocache_image_format_type;
/**\class geocache_image
* \brief representation of an RGBA image
* to access a pixel at position x,y, you should use the #GET_IMG_PIXEL macro
-struct geocache_image{
- unsigned char *data; /**< pointer to the beginning of image data, stored in rgba order */
- size_t w; /**< width of the image */
- size_t h; /**< height of the image */
- size_t stride; /**< stride of an image row */
+struct geocache_image {
+ unsigned char *data; /**< pointer to the beginning of image data, stored in rgba order */
+ size_t w; /**< width of the image */
+ size_t h; /**< height of the image */
+ size_t stride; /**< stride of an image row */
/** \def GET_IMG_PIXEL
@@ -427,47 +416,53 @@
/** \defgroup configuration Configuration*/
-struct geocache_server_cfg{
- apr_global_mutex_t *mutex;
+struct geocache_server_cfg {
+ apr_global_mutex_t *mutex;
* a configuration that will be served
struct geocache_cfg {
- char *configFile; /**< the filename from which this configuration was loaded */
+ char *configFile; /**< the filename from which this configuration was loaded */
- * a list of services that will be responded to
- geocache_service* services[GEOCACHE_SERVICES_COUNT];
+ * a list of services that will be responded to
+ geocache_service * services[GEOCACHE_SERVICES_COUNT];
- * hashtable containing configured geocache_source%s
- apr_hash_t *sources;
+ * hashtable containing configured geocache_source%s
+ apr_hash_t *sources;
- * hashtable containing configured geocache_cache%s
- apr_hash_t *caches;
+ * hashtable containing configured geocache_cache%s
+ apr_hash_t *caches;
- * hashtable containing configured geocache_tileset%s
- apr_hash_t *tilesets;
+ * hashtable containing configured geocache_tileset%s
+ apr_hash_t *tilesets;
- * hashtable containing configured geocache_image_format%s
- apr_hash_t *image_formats;
+ * hashtable containing configured geocache_image_format%s
+ apr_hash_t *image_formats;
- * the format to use when merging multiple tiles
- geocache_image_format *merge_format;
+ * the format to use when merging multiple tiles
+ geocache_image_format *merge_format;
+ * directory where we store file locks
+ char *lockdir;
@@ -513,24 +508,24 @@
* \sa geocache_tileset::metasize_x geocache_tileset::metasize_x geocache_tileset::metabuffer
struct geocache_tile {
- geocache_tileset *tileset; /**< the geocache_tileset that corresponds to the tile*/
- int x; /**< tile x index */
- int y; /**< tile y index */
- int z; /**< tile z index (zoom level) */
- int sx; /**< tile width in pixels */
- int sy; /**< tile height in pixels */
- * encoded image data for the tile.
- * \sa geocache_cache::tile_get()
- * \sa geocache_source::render_tile()
- * \sa geocache_source::render_metatile()
- * \sa geocache_image_format
- geocache_buffer *data;
- void *lock; /**< pointer to opaque structure set by a geocache_cache to reference a lock on the tile
+ geocache_tileset *tileset; /**< the geocache_tileset that corresponds to the tile*/
+ int x; /**< tile x index */
+ int y; /**< tile y index */
+ int z; /**< tile z index (zoom level) */
+ int sx; /**< tile width in pixels */
+ int sy; /**< tile height in pixels */
+ * encoded image data for the tile.
+ * \sa geocache_cache::tile_get()
+ * \sa geocache_source::render_tile()
+ * \sa geocache_source::render_metatile()
+ * \sa geocache_image_format
+ geocache_buffer *data;
+ void *lock; /**< pointer to opaque structure set by a geocache_cache to reference a lock on the tile
\sa geocache_cache::tile_lock() */
- apr_time_t mtime; /**< last modification time */
- int expires; /**< time in seconds after which the tile should be rechecked for validity */
+ apr_time_t mtime; /**< last modification time */
+ int expires; /**< time in seconds after which the tile should be rechecked for validity */
@@ -538,10 +533,10 @@
* \extends geocache_tile
struct geocache_metatile {
- geocache_tile tile; /**< the geocache_tile that corresponds to this metatile */
- double bbox[4]; /**< the bounding box covered by this metatile */
- int ntiles; /**< the number of geocache_metatile::tiles contained in this metatile */
- geocache_tile *tiles; /**< the list of geocache_tile s contained in this metatile */
+ geocache_tile tile; /**< the geocache_tile that corresponds to this metatile */
+ double bbox[4]; /**< the bounding box covered by this metatile */
+ int ntiles; /**< the number of geocache_metatile::tiles contained in this metatile */
+ geocache_tile *tiles; /**< the list of geocache_tile s contained in this metatile */
/**\class geocache_tileset
@@ -549,87 +544,92 @@
* stored by a geocache_cache in a geocache_format
struct geocache_tileset {
- * the name this tileset will be referenced by.
- * this is the key that is passed by clients e.g. in a WMS LAYERS= parameter
- char *name;
+ * the name this tileset will be referenced by.
+ * this is the key that is passed by clients e.g. in a WMS LAYERS= parameter
+ char *name;
- * the extent of the tileset.
- double extent[4];
+ * the extent of the tileset.
+ double extent[4];
- * the SRS of the tileset
- char *srs;
- * the unit of measure of the tileset
- geocache_unit units;
+ * the SRS of the tileset
+ char *srs;
- * width of a tile in pixels
- int tile_sx;
+ * the unit of measure of the tileset
+ geocache_unit units;
- * height of a tile in pixels
- int tile_sy;
+ * width of a tile in pixels
+ int tile_sx;
- * number of resolutions
- int levels;
+ * height of a tile in pixels
+ int tile_sy;
- * resolutions of the tiles
- double *resolutions;
+ * number of resolutions
+ int levels;
- * size of the metatile that should be requested to the geocache_tileset::source
- int metasize_x, metasize_y;
+ * resolutions of the tiles
+ double *resolutions;
- * size of the gutter around the metatile that should be requested to the geocache_tileset::source
- int metabuffer;
+ * size of the metatile that should be requested to the geocache_tileset::source
+ int metasize_x, metasize_y;
- * number of seconds that should be returned to the client in an Expires: header
- int expires;
+ * size of the gutter around the metatile that should be requested to the geocache_tileset::source
+ int metabuffer;
- * the cache in which the tiles should be stored
- geocache_cache *cache;
+ * number of seconds that should be returned to the client in an Expires: header
+ int expires;
- * the source from which tiles should be requested
- geocache_source *source;
+ * the cache in which the tiles should be stored
+ geocache_cache *cache;
- * the format to use when storing tiles coming from a metatile
- geocache_image_format *format;
+ * the source from which tiles should be requested
+ geocache_source *source;
- * the format to use when storing a tile coming from a source
- * if NULL, store what the source has produced without processing
- geocache_image_format *cache_format;
+ * the format to use when storing tiles coming from a metatile
+ geocache_image_format *format;
- * a list of parameters that can be forwarded from the client to the geocache_tileset::source
- apr_table_t *forwarded_params;
+ * the format to use when storing a tile coming from a source
+ * if NULL, store what the source has produced without processing
+ geocache_image_format *cache_format;
+ * a list of parameters that can be forwarded from the client to the geocache_tileset::source
+ apr_table_t *forwarded_params;
+ * handle to the configuration this tileset belongs to
+ geocache_cfg *config;
@@ -689,22 +689,44 @@
* @param x
* @param y
-void geocache_tileset_get_xy(geocache_context *ctx, geocache_tileset *tileset, double dx, double dy,int z, int *x, int *y);
+void geocache_tileset_get_xy(geocache_context *ctx, geocache_tileset *tileset, double dx, double dy, int z, int *x, int *y);
+ * lock the tile
+void geocache_tileset_tile_lock(geocache_context *ctx, geocache_tile *tile);
+ * unlock the tile
+void geocache_tileset_tile_unlock(geocache_context *ctx, geocache_tile *tile);
+ * check if there is a lock on the tile (the lock will have been set by another process/thread)
+ * \returns GEOCACHE_TRUE if the tile is locked by another process/thread
+ * \returns GEOCACHE_FALSE if there is no lock on the tile
+int geocache_tileset_tile_lock_exists(geocache_context *ctx, geocache_tile *tile);
+ * wait for the lock set on the tile (the lock will have been set by another process/thread)
+void geocache_tileset_tile_lock_wait(geocache_context *ctx, geocache_tile *tile);
/* in util.c */
int geocache_util_extract_int_list(geocache_context *ctx, char* args, const char sep, int **numbers,
- int *numbers_count);
+ int *numbers_count);
int geocache_util_extract_double_list(geocache_context *ctx, char* args, const char sep, double **numbers,
int geocache_util_mutex_aquire(geocache_context *r);
int geocache_util_mutex_release(geocache_context *r);
@@ -726,12 +748,12 @@
* \sa geocache_image_format_png
struct geocache_image_format {
- char *name; /**< the key by which this format will be referenced */
- char *extension; /**< the extension to use when saving a file with this format */
- geocache_buffer* (*write)(geocache_context *ctx, geocache_image *image, geocache_image_format *format);
- /**< pointer to a function that returns a geocache_buffer containing the given image encoded
- * in the specified format
+ char *name; /**< the key by which this format will be referenced */
+ char *extension; /**< the extension to use when saving a file with this format */
+ geocache_buffer * (*write)(geocache_context *ctx, geocache_image *image, geocache_image_format * format);
+ /**< pointer to a function that returns a geocache_buffer containing the given image encoded
+ * in the specified format
/**\defgroup imageio_png PNG Image IO
@@ -744,8 +766,8 @@
* \sa geocache_image_format_png_q
struct geocache_image_format_png {
- geocache_image_format format;
- geocache_compression_type compression_level; /**< PNG compression level to apply */
+ geocache_image_format format;
+ geocache_compression_type compression_level; /**< PNG compression level to apply */
/**\class geocache_image_format_png_q
@@ -753,8 +775,8 @@
* \extends geocache_image_format_png
struct geocache_image_format_png_q {
- geocache_image_format_png format;
- int ncolors; /**< number of colors used in quantization, 2-256 */
+ geocache_image_format_png format;
+ int ncolors; /**< number of colors used in quantization, 2-256 */
@@ -797,8 +819,8 @@
struct geocache_image_format_jpeg {
- int quality; /**< JPEG quality, 1-100 */
+ int quality; /**< JPEG quality, 1-100 */
geocache_image_format* geocache_imageio_create_jpeg_format(apr_pool_t *pool, char *name, int quality);
More information about the mapserver-commits
