[mapserver-commits] r12297 - trunk/mapserver/mapcache
Fri Aug 26 07:14:47 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:14:47 -0700 (Fri, 26 Aug 2011)
New Revision: 12297
   trunk/mapserver/mapcache/geocache.xml
fix compiler warnings
thomas.bonfort | 2011-02-08 10:25:13 +0100 (Tue, 08 Feb 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:14:43 UTC (rev 12296)
+++ trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:14:47 UTC (rev 12297)
@@ -401,9 +401,9 @@
             mapserver mapfiles. the name of the mapfiles need not be known to mod-geocache, and can therefore be
             created even after mod-geocache has been started.
             when a user passes a MAPFILE=/path/to/mapfile, the string "path/to/mapfile" is validated against
-            the supplied regular expression. The one in this example allows a name composed of aphanumeric characters
-            spearated by slashes (/) and finishing with ".map", but will faill if there are two consecutive dots (..)
-            in the path, to prevent filesystem traversal.
+            the supplied (PCRE) regular expression. The one in this example allows a name composed of aphanumeric characters
+            spearated by slashes (/) and finishing with ".map" ( [a-zA-Z0-9\./]*\.map$ ) , but will faill if there
+            are two consecutive dots (..) in the path, to prevent filesystem traversal  ( (?!.*\.\.) ).
          <dimension type="regex" name="MAPFILE" default="/path/to/mapfile.map">^(?!.*\.\.)[a-zA-Z0-9\./]*\.map$</dimension>
