[mapserver-commits] r12298 - trunk/mapserver/mapcache
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:14:51 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:14:51 -0700 (Fri, 26 Aug 2011)
New Revision: 12298
trunk/mapserver/mapcache/geocache.xml
add layer merging to full wms requests
thomas.bonfort | 2011-02-08 10:27:52 +0100 (Tue, 08 Feb 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:14:47 UTC (rev 12297)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:14:51 UTC (rev 12298)
@@ -400,7 +400,7 @@
the following creates a MAPFILE dimension, for using the same mod-geocache tileset with different
mapserver mapfiles. the name of the mapfiles need not be known to mod-geocache, and can therefore be
created even after mod-geocache has been started.
- when a user passes a MAPFILE=/path/to/mapfile, the string "path/to/mapfile" is validated against
+ when a user passes a MAPFILE=/path/to/mapfile, the string "/path/to/mapfile" is validated against
the supplied (PCRE) regular expression. The one in this example allows a name composed of aphanumeric characters
spearated by slashes (/) and finishing with ".map" ( [a-zA-Z0-9\./]*\.map$ ) , but will faill if there
are two consecutive dots (..) in the path, to prevent filesystem traversal ( (?!.*\.\.) ).
More information about the mapserver-commits
