[mapserver-commits] r12299 - trunk/mapserver/mapcache
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:14:55 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:14:55 -0700 (Fri, 26 Aug 2011)
New Revision: 12299
trunk/mapserver/mapcache/configure.in
be more precise for "google" extents along with well-known-scalesets. was causing some
empty lines to appear due to rounding errors
thomas.bonfort | 2011-02-08 11:33:01 +0100 (Tue, 08 Feb 2011)
Modified: trunk/mapserver/mapcache/configure.in
--- trunk/mapserver/mapcache/configure.in 2011-08-26 11:14:51 UTC (rev 12298)
+++ trunk/mapserver/mapcache/configure.in 2011-08-26 11:14:55 UTC (rev 12299)
@@ -160,36 +160,43 @@
AC_DEFUN([PCRE_CHECK],[
- AC_MSG_CHECKING([pcre library])
+ PCRE_LIBS=''
+ PCRE_CFLAGS=''
+ AC_MSG_CHECKING([for pcre library inclusion])
AC_ARG_WITH(pcre,
[ --with-pcre[[=prefix]] use pcre instead of posix regular expressions],,
with_pcre="yes")
if test "x$with_pcre" = "xno" ; then
- AC_MSG_RESULT([disabled])
+ AC_MSG_RESULT([disabled by request])
else
- AC_MSG_RESULT([(testing)])
- AC_CHECK_LIB(pcre, pcre_study)
- if test "$ac_cv_lib_pcre_pcre_study" = "yes" ; then
- PCRE_LIBS="-lpcre"
- AC_MSG_CHECKING([lib pcre])
- AC_MSG_RESULT([$PCRE_LIBS])
- PCRE_ENABLED="-DUSE_PCRE"
+ if test "x$with_pcre" = "xyes" ; then
+ AC_MSG_RESULT([in system locations])
+ AC_CHECK_LIB(pcre, pcre_compile,PCRE_LIBS=[-lpcre],
+ [AC_MSG_WARN([pcre library not found, will fall back
+ to posix regular expressions which are less powerfull])])
+ if test -n "$PCRE_LIBS"; then
+ AC_CHECK_HEADER([pcre.h],PCRE_ENABLED=[-DUSE_PCRE],[AC_MSG_WARN([pcre.h not found, will fall back
+ fi
else
OLDLDFLAGS="$LDFLAGS" ; LDFLAGS="$LDFLAGS -L$with_pcre/lib"
OLDCPPFLAGS="$CPPFLAGS" ; CPPFLAGS="$CPPFLAGS -I$with_pcre/include"
- AC_CHECK_LIB(pcre, pcre_compile)
+ AC_CHECK_LIB(pcre, pcre_compile,PCRE_LIBS="-L$with_pcre/lib -lpcre",
+ [AC_MSG_WARN([pcre library not found in $with_pcre/lib, will fall back
CPPFLAGS="$OLDCPPFLAGS"
LDFLAGS="$OLDLDFLAGS"
- if test "$ac_cv_lib_pcre_pcre_compile" = "yes" ; then
- AC_MSG_RESULT(.setting PCRE_LIBS -L$with_pcre/lib -lpcre)
- PCRE_LIBS="-L$with_pcre/lib -lpcre"
- test -d "$with_pcre/include" && PCRE_CFLAGS="-I$with_pcre/include"
- else
- AC_MSG_RESULT([no, (WARNING)])
+ test -f $with_pcre/include/pcre.h && PCRE_CFLAGS="-I$with_pcre/include"
+ test -f $with_pcre/lib/pcre.h && PCRE_CFLAGS="-I$with_pcre/lib"
+ test -f $with_pcre/pcre.h && PCRE_CFLAGS="-I$with_pcre"
+ if test -z $PCRE_CFLAGS; then
+ AC_MSG_WARN([pcre.h not found, will fall back
+ else
+ PCRE_ENABLED="-DUSE_PCRE"
+ fi
fi
fi
fi
More information about the mapserver-commits
