[mapserver-commits] r12300 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:14:59 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:14:59 -0700 (Fri, 26 Aug 2011)
New Revision: 12300
trunk/mapserver/mapcache/src/cache_disk.c
add GetFeatureInfo handling for WMS and WMTS services
closes issue 39.
thomas.bonfort | 2011-02-08 18:37:54 +0100 (Tue, 08 Feb 2011)
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:14:55 UTC (rev 12299)
+++ trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:14:59 UTC (rev 12300)
@@ -25,7 +25,7 @@
#include <unistd.h>
#endif
-void _geocache_cache_disk_blank_tile_key(geocache_context *ctx, geocache_tile *tile, unsigned char *color, char **path) {
+static void _geocache_cache_disk_blank_tile_key(geocache_context *ctx, geocache_tile *tile, unsigned char *color, char **path) {
*path = apr_psprintf(ctx->pool,"%s/%s/%s/blanks/%02X%02X%02X%02X.%s",
((geocache_cache_disk*)tile->tileset->cache)->base_directory,
tile->tileset->name,
@@ -93,7 +93,7 @@
-int _geocache_cache_disk_has_tile(geocache_context *ctx, geocache_tile *tile) {
+static int _geocache_cache_disk_has_tile(geocache_context *ctx, geocache_tile *tile) {
char *filename;
apr_file_t *f;
_geocache_cache_disk_tile_key(ctx, tile, &filename);
@@ -114,7 +114,7 @@
* \private \memberof geocache_cache_disk
* \sa geocache_cache::tile_get()
-int _geocache_cache_disk_get(geocache_context *ctx, geocache_tile *tile) {
+static int _geocache_cache_disk_get(geocache_context *ctx, geocache_tile *tile) {
char *filename;
apr_file_t *f;
apr_finfo_t finfo;
@@ -173,7 +173,7 @@
* \sa geocache_cache::tile_set()
-void _geocache_cache_disk_set(geocache_context *ctx, geocache_tile *tile) {
+static void _geocache_cache_disk_set(geocache_context *ctx, geocache_tile *tile) {
apr_size_t bytes;
apr_file_t *f;
apr_status_t ret;
@@ -296,7 +296,7 @@
-void _geocache_cache_disk_configuration_parse(geocache_context *ctx, ezxml_t node, geocache_cache *cache) {
+static void _geocache_cache_disk_configuration_parse(geocache_context *ctx, ezxml_t node, geocache_cache *cache) {
ezxml_t cur_node;
geocache_cache_disk *dcache = (geocache_cache_disk*)cache;
@@ -319,7 +319,7 @@
-void _geocache_cache_disk_configuration_check(geocache_context *ctx, geocache_cache *cache) {
+static void _geocache_cache_disk_configuration_check(geocache_context *ctx, geocache_cache *cache) {
apr_status_t status;
/* check all required parameters are configured */
More information about the mapserver-commits
