[mapserver-commits] r12326 - trunk/mapserver/mapcache/src
    svn at osgeo.org
    svn at osgeo.org
    Fri Aug 26 07:17:08 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:17:08 -0700 (Fri, 26 Aug 2011)
New Revision: 12326
   trunk/mapserver/mapcache/src/cache_disk.c
   trunk/mapserver/mapcache/src/tileset.c
suppress debugging message.
be more precise in how we compute grid limits (take metatiling into account).
closes issue 58.
thomas.bonfort | 2011-03-07 13:15:52 +0100 (Mon, 07 Mar 2011)
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c	2011-08-26 11:17:03 UTC (rev 12325)
+++ trunk/mapserver/mapcache/src/cache_disk.c	2011-08-26 11:17:08 UTC (rev 12326)
@@ -107,6 +107,29 @@
 static void _geocache_cache_disk_delete(geocache_context *ctx, geocache_tile *tile) {
+   apr_status_t ret;
+   char errmsg[120];
+   char *filename;
+   apr_file_t *f;
+   _geocache_cache_disk_tile_key(ctx, tile, &filename);
+   GC_CHECK_ERROR(ctx);
+   /* delete the tile file if it already exists */
+   if((ret = apr_file_open(&f, filename,APR_FOPEN_READ,APR_OS_DEFAULT, ctx->pool)) == APR_SUCCESS) {
+      apr_file_close(f);
+      ret = apr_file_remove(filename,ctx->pool);
+      if(ret != APR_SUCCESS) {
+         ctx->set_error(ctx, 500,  "failed to remove existing file %s: %s",filename, apr_strerror(ret,errmsg,120));
+         return; /* we could not delete the file */
+   } else {
+      int code = 500;
+      if(ret == ENOENT) {
+         code = 404;
+      ctx->set_error(ctx, code,  "failed to remove file %s: %s",filename, apr_strerror(ret,errmsg,120));
+      return; /* we could not open the file */
@@ -206,6 +229,17 @@
        return;
    *hackptr2 = '/';
+         return; /* we could not create the file */
 #ifdef HAVE_SYMLINK
    if(((geocache_cache_disk*)tile->tileset->cache)->symlink_blank) {
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:17:03 UTC (rev 12325)
+++ trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:17:08 UTC (rev 12326)
@@ -352,5 +352,26 @@
+void geocache_tileset_tile_delete(geocache_context *ctx, geocache_tile *tile) {
+   int i;
+   /*delete the tile itself*/
+   tile->tileset->cache->tile_delete(ctx,tile);
+   geocache_metatile *mt = _geocache_tileset_metatile_get(ctx, tile);
+   for(i=0;i<mt->ntiles;i++) {
+      geocache_tile *subtile = &mt->tiles[i];
+      /* skip deleting the actual tile */
+      if(subtile->x == tile->x && subtile->y == tile->y) continue;
+      subtile->tileset->cache->tile_delete(ctx,tile);
+      /* silently pass failure if the tile was not found */
+      if(ctx->get_error(ctx) == 404) {
+         ctx->clear_errors(ctx);
 /* vim: ai ts=3 sts=3 et sw=3
More information about the mapserver-commits
