[mapserver-commits] r12327 - trunk/mapserver/mapcache/src
Fri Aug 26 07:17:11 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:17:11 -0700 (Fri, 26 Aug 2011)
New Revision: 12327
   trunk/mapserver/mapcache/src/cache_memcache.c
add srs aliases to WMS GetCapabilities
thomas.bonfort | 2011-03-07 13:39:32 +0100 (Mon, 07 Mar 2011)
Modified: trunk/mapserver/mapcache/src/cache_memcache.c
--- trunk/mapserver/mapcache/src/cache_memcache.c	2011-08-26 11:17:08 UTC (rev 12326)
+++ trunk/mapserver/mapcache/src/cache_memcache.c	2011-08-26 11:17:11 UTC (rev 12327)
@@ -77,6 +77,20 @@
    return GEOCACHE_TRUE;
+static void _geocache_cache_memcache_delete(geocache_context *ctx, geocache_tile *tile) {
+   char *key;
+   int rv;
+   char errmsg[120];
+   geocache_cache_memcache *cache = (geocache_cache_memcache*)tile->tileset->cache;
+   _geocache_cache_memcache_tile_key(ctx, tile, &key);
+   GC_CHECK_ERROR(ctx);
+   rv = apr_memcache_delete(cache->memcache,key,0);
+   if(rv != APR_SUCCESS) {
+      int code = 500;
+      if(rv == APR_NOTFOUND) code=404;
+      ctx->set_error(ctx,code,"memcache: failed to delete key %s: %s", key, apr_strerror(rv,errmsg,120));
  * \brief get content of given tile
@@ -214,6 +228,7 @@
    cache->cache.tile_get = _geocache_cache_memcache_get;
    cache->cache.tile_exists = _geocache_cache_memcache_has_tile;
    cache->cache.tile_set = _geocache_cache_memcache_set;
+   cache->cache.tile_delete = _geocache_cache_memcache_delete;
    cache->cache.configuration_check = _geocache_cache_memcache_configuration_check;
    cache->cache.configuration_parse = _geocache_cache_memcache_configuration_parse;
    return (geocache_cache*)cache;
