[mapserver-commits] r12328 - in trunk/mapserver/mapcache: include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:17:16 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:17:16 -0700 (Fri, 26 Aug 2011)
New Revision: 12328
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/geocache_seed.c
use ezxml writer for tms capabilities
Update issue 59
TMS transitionned
thomas.bonfort | 2011-03-07 16:31:44 +0100 (Mon, 07 Mar 2011)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:17:11 UTC (rev 12327)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:17:16 UTC (rev 12328)
@@ -998,6 +998,7 @@
void geocache_grid_get_closest_level(geocache_context *ctx, geocache_grid *grid, double resolution, int *level);
void geocache_tileset_tile_get(geocache_context *ctx, geocache_tile *tile);
+void geocache_tileset_tile_delete(geocache_context *ctx, geocache_tile *tile);
int geocache_grid_is_bbox_aligned(geocache_context *ctx, geocache_grid *grid, double *bbox);
Modified: trunk/mapserver/mapcache/src/geocache_seed.c
--- trunk/mapserver/mapcache/src/geocache_seed.c 2011-08-26 11:17:11 UTC (rev 12327)
+++ trunk/mapserver/mapcache/src/geocache_seed.c 2011-08-26 11:17:16 UTC (rev 12328)
@@ -4,6 +4,7 @@
#include <apr_getopt.h>
#include <signal.h>
#include <time.h>
+#include <apr_time.h>
typedef struct geocache_context_seeding geocache_context_seeding;
struct geocache_context_seeding{
@@ -27,7 +28,8 @@
{ "zoom", 'z', TRUE, "min and max zoomlevels to seed" },
{ "extent", 'e', TRUE, "extent" },
{ "nthreads", 'n', TRUE, "number of parallel threads to use" },
- { "help", 'h', FALSE, "show help" },
+ { "older", 'o', TRUE, "reseed tiles older than supplied date (format: year/month/day hour:minute, eg: 2011/01/31 20:45" },
+ { "help", 'h', FALSE, "show help" },
{ NULL, 0, 0, NULL },
@@ -71,7 +73,8 @@
/* do nothing */
-int tile_exists(geocache_context *ctx, geocache_tileset *tileset,
+apr_time_t age_limit = 0;
+int should_seed_tile(geocache_context *ctx, geocache_tileset *tileset,
int x, int y, int z,
geocache_grid_link *grid_link,
geocache_context *tmpctx) {
@@ -79,7 +82,18 @@
tile->x = x;
tile->y = y;
tile->z = z;
- return tileset->cache->tile_exists(tmpctx,tile);
+ int should_seed = tileset->cache->tile_exists(tmpctx,tile)?0:1;
+ /* if the tile exists and a time limit was specified, check the tile modification date */
+ if(!should_seed && age_limit) {
+ if(tileset->cache->tile_get(tmpctx,tile) == GEOCACHE_SUCCESS) {
+ if(tile->mtime && tile->mtime<age_limit) {
+ should_seed = 1;
+ geocache_tileset_tile_delete(tmpctx,tile);
+ return should_seed;
int curz;
@@ -114,7 +128,7 @@
ctx->nextx = tile->grid_link->grid_limits[ctx->nextz][0];
- if(! tile_exists(gctx, ctx->tileset, ctx->nextx, ctx->nexty, ctx->nextz, ctx->grid_link, tmpcontext)){
+ if(should_seed_tile(gctx, ctx->tileset, ctx->nextx, ctx->nexty, ctx->nextz, ctx->grid_link, tmpcontext)){
break;
@@ -201,15 +215,21 @@
int usage(const char *progname, char *msg) {
- printf("%s\nusage: %s options\n"
- "-c|--config conffile : configuration file to load\n"
- "-t|--tileset tileset : name of the tileset to seed\n"
- "-g|--grid grid : name of the grid to seed\n"
- "[-z|--zoom minzoom,maxzoom] : zoomlevels to seed\n"
- "[-e|--extent minx,miny,maxx,maxy] : extent to seed\n"
- "[-n|--nthreads n] : number of parallel threads\n",
- msg,progname);
- return 1;
+ int i=0;
+ if(msg)
+ printf("%s\nusage: %s options\n",msg,progname);
+ else
+ printf("usage: %s options\n",progname);
+ while(seed_options[i].name) {
+ if(seed_options[i].has_arg==TRUE) {
+ printf("-%c|--%s [value]: %s\n",seed_options[i].optch,seed_options[i].name, seed_options[i].description);
+ } else {
+ printf("-%c|--%s: %s\n",seed_options[i].optch,seed_options[i].name, seed_options[i].description);
+ i++;
+ return 1;
int main(int argc, const char **argv) {
@@ -229,6 +249,7 @@
int nthreads=1;
int optch;
int rv,n;
+ const char *old = NULL;
const char *optarg;
apr_initialize();
(void) signal(SIGINT,handle_sig_int);
@@ -270,6 +291,10 @@
return usage(argv[0], "failed to parse zooms, expecting comma separated 2 ints");
break;
+ case 'o':
+ old = optarg;
+ break;
if (rv != APR_EOF) {
@@ -317,6 +342,18 @@
if(zooms[1]>= grid_link->grid->nlevels) zooms[1] = grid_link->grid->nlevels - 1;
+ if(old) {
+ struct tm oldtime;
+ memset(&oldtime,0,sizeof(oldtime));
+ char *ret = strptime(old,"%Y/%m/%d %H:%M",&oldtime);
+ if(!ret || *ret){
+ return usage(argv[0],"failed to parse time");
+ if(APR_SUCCESS != apr_time_ansi_put(&age_limit,mktime(&oldtime))) {
+ return usage(argv[0],"failed to convert time");
geocache_context_seeding_init(&ctx,cfg,tileset,zooms[0],zooms[1],grid_link);
if(extent) {
// update the grid limits
@@ -327,7 +364,7 @@
ctx.nexty = grid_link->grid_limits[zooms[0]][1];
/* find the first tile to render if the first one already exists */
- if(tile_exists(gctx, tileset,
+ if(!should_seed_tile(gctx, tileset,
ctx.nextx, ctx.nexty, ctx.nextz,
grid_link, gctx)) {
geocache_tile *tile = geocache_tileset_tile_create(gctx->pool, tileset, grid_link);
More information about the mapserver-commits
