[mapserver-commits] r12334 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:17:41 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:17:40 -0700 (Fri, 26 Aug 2011)
New Revision: 12334
trunk/mapserver/mapcache/src/cache_disk.c
add a more correct error message when unable to access tile
thomas.bonfort | 2011-03-10 16:56:25 +0100 (Thu, 10 Mar 2011)
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:17:36 UTC (rev 12333)
+++ trunk/mapserver/mapcache/src/cache_disk.c 2011-08-26 11:17:40 UTC (rev 12334)
@@ -357,19 +357,21 @@
* \private \memberof geocache_cache_disk
static void _geocache_cache_disk_configuration_check(geocache_context *ctx, geocache_cache *cache) {
- apr_status_t status;
geocache_cache_disk *dcache = (geocache_cache_disk*)cache;
/* check all required parameters are configured */
if(!dcache->base_directory || !strlen(dcache->base_directory)) {
ctx->set_error(ctx, 400, "disk cache %s has no base directory",dcache->cache.name);
return;
- /*create our directory for blank images*/
- status = apr_dir_make_recursive(dcache->base_directory,APR_OS_DEFAULT,ctx->pool);
- if(status != APR_SUCCESS) {
- ctx->set_error(ctx, 500, "failed to create directory %s for cache %s",dcache->base_directory,dcache->cache.name );
- return;
+ apr_dir_t *basedir;
+ apr_status_t rv;
+ rv = apr_dir_open(&basedir,dcache->base_directory,ctx->pool);
+ char errmsg[120];
+ if(rv != APR_SUCCESS) {
+ ctx->log(ctx,GEOCACHE_WARNING, "failed to open base directory %s for cache %s: %s."\
+ " This might lead to problems later on if the apache user does not have the rights to create this directory",
+ dcache->base_directory,cache->name,apr_strerror(rv,errmsg,120));
return;
More information about the mapserver-commits
