[mapserver-commits] r12335 - in trunk/mapserver/mapcache: . include src
Fri Aug 26 07:17:46 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:17:46 -0700 (Fri, 26 Aug 2011)
New Revision: 12335
   trunk/mapserver/mapcache/geocache.xml
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/configuration.c
   trunk/mapserver/mapcache/src/lock.c
add mixed image format
closes issue 63.
thomas.bonfort | 2011-03-11 10:52:08 +0100 (Fri, 11 Mar 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:17:40 UTC (rev 12334)
+++ trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:17:46 UTC (rev 12335)
@@ -540,6 +540,13 @@
           - assemble: build the full image by assembling the tiles from the cache
           - forward: forward the request to the configured source.
-   <full_wms>forward</full_wms>
+   <full_wms>assemble</full_wms>
+        location to put lockfiles (to block other clients while a metatile is being rendered.
+        defaults to /tmp
+        this location should be writable by the apache user
+   <lock_dir>/tmp</lock_dir>
 </geocache>
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:17:40 UTC (rev 12334)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:17:46 UTC (rev 12335)
@@ -58,8 +58,10 @@
 #define GEOCACHE_VERSION "0.3-dev"
 #define GEOCACHE_USERAGENT "mod-geocache/"GEOCACHE_VERSION
+#define GEOCACHE_LOCKFILE_PREFIX "_gc_lock"
 typedef struct geocache_image_format geocache_image_format;
 typedef struct geocache_image_format_png geocache_image_format_png;
 typedef struct geocache_image_format_png_q geocache_image_format_png_q;
@@ -762,6 +764,8 @@
     geocache_getmap_strategy getmap_strategy;
     apr_table_t *metadata;
+    const char *lockdir;
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:17:40 UTC (rev 12334)
+++ trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:17:46 UTC (rev 12335)
@@ -971,7 +971,39 @@
+   if((node = ezxml_child(doc,"lock_dir")) != NULL) {
+      config->lockdir = apr_pstrdup(ctx->pool, node->txt);
+   } else {
+      config->lockdir = apr_pstrdup(ctx->pool,"/tmp");
+   apr_dir_t *lockdir;
+   apr_status_t rv;
+   rv = apr_dir_open(&lockdir,config->lockdir,ctx->pool);
+   char errmsg[120];
+   if(rv != APR_SUCCESS) {
+      ctx->set_error(ctx,500, "failed to open lock directory %s: %s"
+            ,config->lockdir,apr_strerror(rv,errmsg,120));
+      goto cleanup;
+   apr_finfo_t finfo;
+   while ((apr_dir_read(&finfo, APR_FINFO_DIRENT|APR_FINFO_TYPE|APR_FINFO_NAME, lockdir)) == APR_SUCCESS) {
+      if(finfo.filetype == APR_REG) {
+         if(!strncmp(finfo.name, GEOCACHE_LOCKFILE_PREFIX, strlen(GEOCACHE_LOCKFILE_PREFIX))) {
+            ctx->log(ctx,GEOCACHE_WARNING,"found old lockfile %s/%s, deleting it",config->lockdir,
+                  finfo.name);
+            rv = apr_file_remove(apr_psprintf(ctx->pool,"%s/%s",config->lockdir, finfo.name),ctx->pool);
+               ctx->set_error(ctx,500, "failed to remove lockfile %s: %s",finfo.name,apr_strerror(rv,errmsg,120));
+               goto cleanup;
+   apr_dir_close(lockdir);
 cleanup:
    ezxml_free(doc);
    return;
Modified: trunk/mapserver/mapcache/src/lock.c
--- trunk/mapserver/mapcache/src/lock.c	2011-08-26 11:17:40 UTC (rev 12334)
+++ trunk/mapserver/mapcache/src/lock.c	2011-08-26 11:17:46 UTC (rev 12335)
@@ -22,6 +22,7 @@
 #include <fcntl.h>
+#ifdef USE_SEMLOCK
 static const char *alphabet = "abcdefghijklmnopqrstuvwxyz"
                        "ABCDEFGHIJKLMNOPQRSTUVWXYZ"
                        "0123456789"
@@ -47,11 +48,20 @@
    return ret;
+#endif
 char *geocache_tileset_metatile_lock_key(geocache_context *ctx, geocache_metatile *mt) {
    char *lockname = apr_psprintf(ctx->pool,
+#ifdef USE_SEMLOCK
          "/%s-%s-%s%s", /*x,y,z,tilesetname*/
          num_encode(ctx->pool,mt->x), num_encode(ctx->pool,mt->y),
-         num_encode(ctx->pool,mt->z), mt->map.tileset->name);
+         num_encode(ctx->pool,mt->z),
+#else
+         "%s/"GEOCACHE_LOCKFILE_PREFIX"-%d-%d-%d-%s",
+         ctx->config->lockdir,
+         mt->z,mt->y,mt->x,
+#endif
+         mt->map.tileset->name);
    /* if the tileset has multiple grids, add the name of the current grid to the lock key*/
    if(mt->map.tileset->grid_links->nelts > 1) {
@@ -74,6 +84,7 @@
+#ifdef USE_SEMLOCK
 #ifdef __APPLE__
 #ifndef SEM_NAME_LEN
 #define SEM_NAME_LEN 31
@@ -87,6 +98,8 @@
       lockname[SEM_NAME_LEN-1]='\0';
 #endif
+#endif
    return lockname;
@@ -98,6 +111,7 @@
 void geocache_tileset_metatile_lock(geocache_context *ctx, geocache_metatile *mt) {
    char *lockname = geocache_tileset_metatile_lock_key(ctx,mt);
+#ifdef USE_SEMLOCK
    sem_t *lock;
    if ((lock = sem_open(lockname, O_CREAT|O_EXCL, 0644, 1)) == SEM_FAILED) {
       ctx->set_error(ctx,500, "failed to create posix semaphore %s: %s",lockname, strerror(errno));
@@ -105,6 +119,26 @@
    sem_wait(lock);
    mt->lock = lock;
+#else
+   char errmsg[120];
+   apr_file_t *lock;
+   apr_status_t rv;
+   rv = apr_file_open(&lock,lockname,APR_WRITE|APR_CREATE|APR_EXCL|APR_SHARELOCK|APR_XTHREAD,APR_OS_DEFAULT,ctx->pool);
+   if(rv!=APR_SUCCESS) {
+      ctx->set_error(ctx,500, "failed to create lockfile %s: %s",
+            lockname, apr_strerror(rv,errmsg,120));
+      return;
+   /* we aquire an exclusive (i.e. write) lock on the file. For this to work, the file has to be opened with APR_WRITE mode */
+   rv = apr_file_lock(lock,APR_FLOCK_EXCLUSIVE|APR_FLOCK_NONBLOCK);
+      ctx->set_error(ctx,500, "failed to aquire an exclusive lock on lockfile %s: %s",
+      return;
+   mt->lock = lock;
+#endif
@@ -116,8 +150,9 @@
  * \sa geocache_cache::tile_lock_exists()
 void geocache_tileset_metatile_unlock(geocache_context *ctx, geocache_metatile *mt) {
+   const char *lockname = geocache_tileset_metatile_lock_key(ctx,mt);
+#ifdef USE_SEMLOCK
    sem_t *lock = (sem_t*) mt->lock;
-   const char *lockname = geocache_tileset_metatile_lock_key(ctx,mt);
    if (!mt->lock) {
       ctx->set_error(ctx,500,"###### TILE UNLOCK ######### attempting to unlock tile %s not created by this thread", lockname);
       return;
@@ -126,6 +161,30 @@
    sem_close(lock);
    sem_unlink(lockname);
    mt->lock = NULL;
+#else
+   char errmsg[120];
+   apr_status_t rv;
+   if (!mt->lock) {
+      ctx->set_error(ctx,500,"###### TILE UNLOCK ######### attempting to unlock tile %s not created by this thread", lockname);
+      return;
+   apr_file_t *lock = (apr_file_t*)mt->lock;
+   rv = apr_file_unlock(lock);
+      ctx->set_error(ctx,500, "failed to unlock lockfile %s: %s",
+   rv = apr_file_close(lock);
+      ctx->set_error(ctx,500, "failed to close lockfile %s: %s",
+   rv = apr_file_remove(lockname,ctx->pool);
+#endif
@@ -141,6 +200,7 @@
    if (mt->lock)
       return GEOCACHE_TRUE;
    lockname = geocache_tileset_metatile_lock_key(ctx, mt);
+#ifdef USE_SEMLOCK
    sem_t *lock = sem_open(lockname, 0, 0644, 1) ;
    if (lock == SEM_FAILED) {
       if(errno == ENOENT) {
@@ -153,6 +213,58 @@
       sem_close(lock);
+#else
+   apr_status_t rv;
+   char errmsg[120];
+   apr_file_t *lock;
+   rv = apr_file_open(&lock,lockname,APR_READ|APR_SHARELOCK|APR_XTHREAD,APR_OS_DEFAULT,ctx->pool);
+   if(APR_STATUS_IS_ENOENT(rv)) {
+      /* the lock file does not exist, the metatile is not locked */
+      return GEOCACHE_FALSE;
+   } else {
+      /* the file exists, or there was an error opening it */
+         /* we failed to open the file, bail out */
+         ctx->set_error(ctx,500,"lock_exists: failed to open lockfile %s: %s",lockname,
+               apr_strerror(rv,errmsg,120));
+      } else {
+         /* the file exists, which means there probably is a lock. make sure it isn't locked anyhow */
+         rv = apr_file_lock(lock,APR_FLOCK_SHARED|APR_FLOCK_NONBLOCK);
+            if(rv == APR_EAGAIN) {
+               /* the file is locked */
+               apr_file_close(lock);
+               return GEOCACHE_TRUE;
+            } else {
+               ctx->set_error(ctx,500, "lock_exists: failed to aquire lock on lockfile %s: %s",
+                  ctx->set_error(ctx,500, "lock_exists: failed to close lockfile %s: %s",
+         } else {
+            /* we managed to aquire a lock on the file, which means it isn't locked, even if it exists */
+            /* unlock the file */
+               ctx->set_error(ctx,500, "lock_exists: failed to unlock lockfile %s: %s",
+#endif
@@ -163,14 +275,17 @@
 void geocache_tileset_metatile_lock_wait(geocache_context *ctx, geocache_metatile *mt) {
   char *lockname;
-  sem_t *lock;
+  lockname = geocache_tileset_metatile_lock_key(ctx, mt);
 #ifdef DEBUG
   if (mt->lock) {
-    ctx->set_error(ctx, 500, "### BUG ### waiting for a lock we have created ourself");
+    ctx->set_error(ctx, 500, "### BUG ### lock_wait: waiting for a lock we have created ourself");
     return;
 #endif
-  lockname = geocache_tileset_metatile_lock_key(ctx, mt);
+#ifdef USE_SEMLOCK
+  sem_t *lock;
   if( lock == SEM_FAILED ) {
@@ -185,6 +300,36 @@
      sem_post(lock);
      sem_close(lock);
+#else
+   char errmsg[120];
+   apr_file_t *lock;
+   apr_status_t rv;
+         /* the lock file does not exist, it might have been removed since we checked.
+          * anyhow, there's no use waiting anymore
+         return;
+      } else {
+         ctx->set_error(ctx,500, "lock_wait: failed to open lockfile %s: %s",
+         return;
+   rv = apr_file_lock(lock,APR_FLOCK_SHARED);
+      ctx->set_error(ctx,500, "lock_wait: failed to aquire a shared lock on lockfile %s: %s",
+      ctx->set_error(ctx,500, "lock_wait: failed to close lockfile %s: %s",
+#endif
 /* vim: ai ts=3 sts=3 et sw=3
