[mapserver-commits] r12404 - in trunk/mapserver/mapcache: . include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:22:55 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:22:55 -0700 (Fri, 26 Aug 2011)
New Revision: 12404
trunk/mapserver/mapcache/geocache.xml
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/configuration.c
trunk/mapserver/mapcache/src/mod_geocache.c
update docs with new configure keywords and updated apache configuration keywords
thomas.bonfort | 2011-07-08 12:22:40 +0200 (Fri, 08 Jul 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:22:50 UTC (rev 12403)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:22:55 UTC (rev 12404)
@@ -125,25 +125,6 @@
</grid>
- <!-- french grids -->
- <grid name="FXX">
- <extent>-357823.2365 6037008.6939 1313632.3628 7230727.3772</extent>
- <srs>EPSG:2154</srs>
- <srsalias>EPSG:310024802</srsalias>
- <srsalias>IGNF:GEOPORTALFXX</srsalias>
- <resolutions>2048 1024 512 256 128 64 32 16 8 4 2 1 0.5 0.25 0.125 0.0625</resolutions>
- <units>m</units>
- <size>256 256</size>
- </grid>
- <grid name="Miller">
- <extent>-20037504 -10018752 20037504 10018752</extent>
- <srs>EPSG:310642901</srs>
- <srsalias>IGNF:MILLER</srsalias>
- <resolutions>39135.75 19567.875 9783.9375 4891.96875 2445.984375</resolutions>
- <units>m</units>
- </grid>
a cache is where tiles are stored once they have been rendered
the only "type" available right now is "disk"
@@ -486,8 +467,6 @@
<source>osm</source>
<cache>disk</cache>
<format>PNG</format>
- <grid>FXX</grid>
- <grid>Miller</grid>
<grid>WGS84</grid>
<grid>g</grid>
<metatile>5 5</metatile>
@@ -524,7 +503,7 @@
<service type="wms" enabled="true">
<forwarding_rule name="foo rule">
<http>
- <url>http://localhost/</url>
+ <url>http://localhost/cgi-bin/mapserv?map=/gro1/mapserver-utils/osm.map</url>
</http>
</forwarding_rule>
</service>
@@ -566,6 +545,5 @@
this location should be writable by the apache user
<lock_dir>/tmp</lock_dir>
- <pathinfo_hack/>
</geocache>
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:22:50 UTC (rev 12403)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:22:55 UTC (rev 12404)
@@ -823,8 +823,6 @@
apr_table_t *metadata;
const char *lockdir;
- int pathinfo_hack;
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:22:50 UTC (rev 12403)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:22:55 UTC (rev 12404)
@@ -1124,11 +1124,6 @@
apr_dir_close(lockdir);
- if((node = ezxml_child(doc,"pathinfo_hack")) != NULL) {
- config->pathinfo_hack = 1;
- } else {
- config->pathinfo_hack = 0;
cleanup:
ezxml_free(doc);
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:22:50 UTC (rev 12403)
+++ trunk/mapserver/mapcache/src/mod_geocache.c 2011-08-26 11:22:55 UTC (rev 12404)
@@ -27,7 +27,6 @@
#include <http_log.h>
#include "geocache.h"
#include <unistd.h>
-#include <stdlib.h>
#ifdef AP_NEED_SET_MUTEX_PERMS
#include "unixd.h"
@@ -259,6 +258,9 @@
geocache_cfg *config = NULL;
geocache_request *request = NULL;
+ geocache_context_apache_request *apache_ctx = apache_request_context_create(r);
+ geocache_context *global_ctx = (geocache_context*)apache_ctx;
+ int ret;
if (!r->handler || strcmp(r->handler, "geocache")) {
return DECLINED;
@@ -267,20 +269,12 @@
return HTTP_METHOD_NOT_ALLOWED;
- geocache_context_apache_request *apache_ctx = apache_request_context_create(r);
- geocache_context *global_ctx = (geocache_context*)apache_ctx;
- int ret;
params = geocache_http_parse_param_string(global_ctx, r->args);
config = ap_get_module_config(r->per_dir_config, &geocache_module);
- char *path_info = r->path_info;
- if(config->pathinfo_hack) {
- path_info = r->uri;
- geocache_service_dispatch_request(global_ctx,&request,path_info,params,config);
+ geocache_service_dispatch_request(global_ctx,&request,r->path_info,params,config);
if(GC_HAS_ERROR(global_ctx)) {
return report_error(apache_ctx);
@@ -299,13 +293,13 @@
* remove the path_info from the end of the url (we want the url of the base of the service)
* TODO: is there an apache api to access this ?
- if(*(path_info)) {
- char *end = strstr(url,path_info);
+ if(*(original->path_info)) {
+ char *end = strstr(url,original->path_info);
if(end) {
*end = '\0';
- request->service->create_capabilities_response(global_ctx,req_caps,url,path_info,config);
+ request->service->create_capabilities_response(global_ctx,req_caps,url,original->path_info,config);
More information about the mapserver-commits
