[mapserver-commits] r12405 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:22:59 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:22:59 -0700 (Fri, 26 Aug 2011)
New Revision: 12405
trunk/mapserver/mapcache/src/service_wms.c
dont use a temporary memory pool when loading watermark image
thomas.bonfort | 2011-07-11 13:22:22 +0200 (Mon, 11 Jul 2011)
Modified: trunk/mapserver/mapcache/src/service_wms.c
--- trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:22:55 UTC (rev 12404)
+++ trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:22:59 UTC (rev 12405)
@@ -397,59 +397,70 @@
errmsg = "received wms request with no layers";
goto proxies;
} else {
- char *last, *key, *layers;
+ char *last, *layers;
+ const char *key;
int count=1;
+ int i,layeridx;
char *sep=",";
+ int x,y,z;
geocache_request_get_map *map_req = NULL;
geocache_request_get_tile *tile_req = NULL;
- layers = apr_pstrdup(ctx->pool,str);
- for(key=layers;*key;key++) if(*key == ',') count++;
+ geocache_grid_link *main_grid_link = NULL;
+ geocache_tileset *main_tileset = NULL;
+ /* count the number of layers that are requested */
+ for(key=str;*key;key++) if(*key == ',') count++;
- /* we have to loop twice on the requested layers, once to determine the request type,
- * and a second time to actually populate the request structure */
+ * look to see if we have a getTile or a getMap request. We do this by looking at the first
+ * wms layer that was provided in the request.
+ * Checking to see if all requested layers reference the grid will be done in a second step
+ geocache_request_type type = GEOCACHE_REQUEST_GET_TILE;
+ if(count ==1) {
+ key = str;
+ } else {
+ layers = apr_pstrdup(ctx->pool,str);
+ key = apr_strtok(layers, sep, &last); /* extract first layer */
+ main_tileset = geocache_configuration_get_tileset(config,key);
+ if(!main_tileset) {
+ errcode = 404;
+ errmsg = apr_psprintf(ctx->pool,"received wms request with invalid layer %s", key);
+ goto proxies;
- /*first pass around requested layers to see if we have a getTile or a getMap request*/
- geocache_request_type type = GEOCACHE_REQUEST_GET_TILE;
- for (key = apr_strtok(layers, sep, &last); key != NULL;
- key = apr_strtok(NULL, sep, &last)) {
- geocache_tileset *tileset = geocache_configuration_get_tileset(config,key);
- if(!tileset) {
- errcode = 404;
- errmsg = apr_psprintf(ctx->pool,"received wms request with invalid layer %s", key);
- goto proxies;
- int i;
- geocache_grid_link *grid_link = NULL;
- for(i=0;i<tileset->grid_links->nelts;i++){
- geocache_grid_link *sgrid = APR_ARRAY_IDX(tileset->grid_links,i,geocache_grid_link*);
- /* look for a grid with a matching srs */
- if(strcasecmp(sgrid->grid->srs,srs)) {
- /* look if the grid has some srs aliases */
- int s;
- for(s=0;s<sgrid->grid->srs_aliases->nelts;s++) {
- char *srsalias = APR_ARRAY_IDX(sgrid->grid->srs_aliases,s,char*);
- if(!strcasecmp(srsalias,srs)) break;
- if(s==sgrid->grid->srs_aliases->nelts)
- continue; /* no srs alias matches the requested srs */
+ for(i=0;i<main_tileset->grid_links->nelts;i++){
+ geocache_grid_link *sgrid = APR_ARRAY_IDX(main_tileset->grid_links,i,geocache_grid_link*);
+ /* look for a grid with a matching srs */
+ if(strcasecmp(sgrid->grid->srs,srs)) {
+ /* look if the grid has some srs aliases */
+ int s;
+ for(s=0;s<sgrid->grid->srs_aliases->nelts;s++) {
+ char *srsalias = APR_ARRAY_IDX(sgrid->grid->srs_aliases,s,char*);
+ if(!strcasecmp(srsalias,srs)) break;
- grid_link = sgrid;
- break;
+ if(s==sgrid->grid->srs_aliases->nelts)
+ continue; /* no srs alias matches the requested srs */
- if(!grid_link) {
- errcode = 400;
- "received unsuitable wms request: no <grid> with suitable srs found for layer %s",tileset->name);
- goto proxies;
+ main_grid_link = sgrid;
+ break;
+ if(!main_grid_link) {
+ errcode = 400;
+ "received unsuitable wms request: no <grid> with suitable srs found for layer %s",main_tileset->name);
+ goto proxies;
- /* verify we align on the tileset's grid */
- int tmpx,tmpy,tmpz;
- if(grid_link->grid->tile_sx != width || grid_link->grid->tile_sy != height ||
- geocache_grid_get_cell(ctx, grid_link->grid, bbox, &tmpx,&tmpy,&tmpz) != GEOCACHE_SUCCESS) {
- type = GEOCACHE_REQUEST_GET_MAP;
+ /* verify we align on the tileset's grid */
+ if(main_grid_link->grid->tile_sx != width || main_grid_link->grid->tile_sy != height ||
+ geocache_grid_get_cell(ctx, main_grid_link->grid, bbox, &x,&y,&z) != GEOCACHE_SUCCESS) {
+ /* we have the correct srs, but the request does not align on the grid */
+ type = GEOCACHE_REQUEST_GET_MAP;
if(type == GEOCACHE_REQUEST_GET_TILE) {
tile_req = apr_pcalloc(ctx->pool, sizeof(geocache_request_get_tile));
@@ -463,40 +474,47 @@
*request = (geocache_request*)map_req;
+ * loop through all the layers to verify that they reference the requested grid,
+ * and to extract any dimensions if configured
+ if(count>1)
+ layers = apr_pstrdup(ctx->pool,str); /* apr_strtok modifies its input string */
- int i;
- grid_link = APR_ARRAY_IDX(tileset->grid_links,i,geocache_grid_link*);
- if(strcasecmp(grid_link->grid->srs,srs)) {
- int s;
- for(s=0;s<grid_link->grid->srs_aliases->nelts;s++) {
- char *srsalias = APR_ARRAY_IDX(grid_link->grid->srs_aliases,s,char*);
+ for (layeridx=0,key = ((count==1)?str:apr_strtok(layers, sep, &last)); key != NULL;
+ key = ((count==1)?NULL:apr_strtok(NULL, sep, &last)),layeridx++) {
+ geocache_tileset *tileset = main_tileset;
+ geocache_grid_link *grid_link = main_grid_link;
+ apr_table_t *dimtable = NULL;
+ if(layeridx) {
+ * if we have multiple requested layers, check that they reference the requested grid
+ * this step is not done for the first tileset as we have already performed it
+ tileset = geocache_configuration_get_tileset(config,key);
+ int i;
+ grid_link = NULL;
+ for(i=0;i<tileset->grid_links->nelts;i++){
+ grid_link = APR_ARRAY_IDX(tileset->grid_links,i,geocache_grid_link*);
+ if(grid_link->grid == main_grid_link->grid) {
+ break;
- if(s==grid_link->grid->srs_aliases->nelts)
- break;
+ if(i==tileset->grid_links->nelts) {
+ /* the tileset does not reference the grid of the first tileset */
+ errcode = 400;
+ "tileset %s does not reference grid %s (referenced by tileset %s",
+ tileset->name, grid_link->grid->name,main_tileset->name);
+ goto proxies;
- apr_table_t *dimtable = NULL;
geocache_tile *tile = geocache_tileset_tile_create(ctx->pool, tileset, grid_link);
-#ifndef DEBUG
- geocache_grid_get_cell(ctx, grid_link->grid, bbox, &tile->x, &tile->y, &tile->z);
-#else
- int ret = geocache_grid_get_cell(ctx, grid_link->grid, bbox, &tile->x, &tile->y, &tile->z);
- if(ret != GEOCACHE_SUCCESS) {
- errcode = 500;
- errmsg = "###BUG###: grid_get_cell returned failure";
- goto proxies;
-#endif
+ tile->x = x;
+ tile->y = y;
+ tile->z = z;
geocache_tileset_tile_validate(ctx,tile);
if(GC_HAS_ERROR(ctx)) {
/* don't bail out just yet, in case multiple tiles have been requested */
More information about the mapserver-commits
