[mapserver-commits] r12428 - trunk/mapserver/mapcache/src
Fri Aug 26 07:24:57 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:24:56 -0700 (Fri, 26 Aug 2011)
New Revision: 12428
   trunk/mapserver/mapcache/src/tileset.c
check for sqlite >= 3.5.0 (with v2 api)
thomas.bonfort | 2011-08-15 14:54:50 +0200 (Mon, 15 Aug 2011)
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:24:50 UTC (rev 12427)
+++ trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:24:56 UTC (rev 12428)
@@ -154,13 +154,18 @@
    cairo_translate (cr, dstminx,dstminy);
    cairo_scale  (cr, hf, vf);
    cairo_set_source_surface (cr, srcsurface, 0, 0);
-   switch(ctx->config->resample_mode) {
-      case GEOCACHE_RESAMPLE_BILINEAR:
-         cairo_pattern_set_filter (cairo_get_source (cr), CAIRO_FILTER_BILINEAR);
-         break;
-      default:
-         cairo_pattern_set_filter (cairo_get_source (cr), CAIRO_FILTER_NEAREST);
-         break;
+   if(fabs(hf-1)<0.0001 && fabs(vf-1)<0.0001) {
+      //use nearest resampling if we are at the resolution of the tiles
+      cairo_pattern_set_filter (cairo_get_source (cr), CAIRO_FILTER_NEAREST);
+   } else {
+      switch(ctx->config->resample_mode) {
+         case GEOCACHE_RESAMPLE_BILINEAR:
+            cairo_pattern_set_filter (cairo_get_source (cr), CAIRO_FILTER_BILINEAR);
+            break;
+         default:
+            break;
    cairo_paint (cr);
    cairo_surface_destroy(srcsurface);
