[mapserver-commits] r12429 - in trunk/mapserver/mapcache: include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:25:03 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:25:03 -0700 (Fri, 26 Aug 2011)
New Revision: 12429
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/image.c
trunk/mapserver/mapcache/src/imageio.c
trunk/mapserver/mapcache/src/imageio_jpeg.c
trunk/mapserver/mapcache/src/imageio_png.c
trunk/mapserver/mapcache/src/tileset.c
be a bit less verbose in sqlite3 detection
thomas.bonfort | 2011-08-15 15:03:04 +0200 (Mon, 15 Aug 2011)
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:24:56 UTC (rev 12428)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:25:03 UTC (rev 12429)
@@ -1249,7 +1249,15 @@
geocache_image* _geocache_imageio_png_decode(geocache_context *ctx, geocache_buffer *buffer);
+ * @param r
+ * @param buffer
+ * @return
+void _geocache_imageio_png_decode_to_image(geocache_context *ctx, geocache_buffer *buffer,
+ geocache_image *image);
* \brief create a format capable of creating RGBA png
* \memberof geocache_image_format_png
@@ -1295,6 +1303,14 @@
geocache_image* _geocache_imageio_jpeg_decode(geocache_context *ctx, geocache_buffer *buffer);
+ * @param r
+ * @param buffer
+ * @return
+void _geocache_imageio_jpeg_decode_to_image(geocache_context *ctx, geocache_buffer *buffer,
@@ -1313,7 +1329,12 @@
geocache_image* geocache_imageio_decode(geocache_context *ctx, geocache_buffer *buffer);
+ * decodes given buffer to an allocated image
+void geocache_imageio_decode_to_image(geocache_context *ctx, geocache_buffer *buffer, geocache_image *image);
typedef struct {
Modified: trunk/mapserver/mapcache/src/image.c
--- trunk/mapserver/mapcache/src/image.c 2011-08-26 11:24:56 UTC (rev 12428)
+++ trunk/mapserver/mapcache/src/image.c 2011-08-26 11:25:03 UTC (rev 12429)
@@ -19,6 +19,7 @@
geocache_image* geocache_image_create(geocache_context *ctx) {
geocache_image *img = (geocache_image*)apr_pcalloc(ctx->pool,sizeof(geocache_image));
img->w= img->h= 0;
+ img->data=NULL;
return img;
Modified: trunk/mapserver/mapcache/src/imageio.c
--- trunk/mapserver/mapcache/src/imageio.c 2011-08-26 11:24:56 UTC (rev 12428)
+++ trunk/mapserver/mapcache/src/imageio.c 2011-08-26 11:25:03 UTC (rev 12429)
@@ -57,6 +57,19 @@
+ geocache_image *image) {
+ geocache_image_format_type type = geocache_imageio_header_sniff(ctx,buffer);
+ if(type == GC_PNG) {
+ _geocache_imageio_png_decode_to_image(ctx,buffer,image);
+ } else if(type == GC_JPEG) {
+ _geocache_imageio_jpeg_decode_to_image(ctx,buffer,image);
+ } else {
+ ctx->set_error(ctx, 500, "geocache_imageio_decode: unrecognized image format");
+ return;
/* vim: ai ts=3 sts=3 et sw=3
Modified: trunk/mapserver/mapcache/src/imageio_jpeg.c
--- trunk/mapserver/mapcache/src/imageio_jpeg.c 2011-08-26 11:24:56 UTC (rev 12428)
+++ trunk/mapserver/mapcache/src/imageio_jpeg.c 2011-08-26 11:25:03 UTC (rev 12429)
@@ -192,14 +192,15 @@
return buffer;
-geocache_image* _geocache_imageio_jpeg_decode(geocache_context *r, geocache_buffer *buffer) {
+void _geocache_imageio_jpeg_decode_to_image(geocache_context *r, geocache_buffer *buffer,
+ geocache_image *img) {
struct jpeg_decompress_struct cinfo = {NULL};
struct jpeg_error_mgr jerr;
jpeg_create_decompress(&cinfo);
cinfo.err = jpeg_std_error(&jerr);
- geocache_image *img = geocache_image_create(r);
if (_geocache_imageio_jpeg_mem_src(&cinfo,buffer->buf, buffer->size) != GEOCACHE_SUCCESS){
- return NULL;
+ r->set_error(r,500,"failed to allocate jpeg decoding struct");
+ return;
jpeg_read_header(&cinfo, TRUE);
@@ -207,8 +208,11 @@
img->w = cinfo.output_width;
img->h = cinfo.output_height;
int s = cinfo.output_components;
- img->data = apr_pcalloc(r->pool,img->w*img->h*4*sizeof(unsigned char));
- img->stride = img->w * 4;
+ if(!img->data) {
+ img->data = calloc(1,img->w*img->h*4*sizeof(unsigned char));
+ apr_pool_cleanup_register(r->pool, img->data, (void*)free, apr_pool_cleanup_null) ;
+ img->stride = img->w * 4;
unsigned char *temp = apr_pcalloc(r->pool,img->w*s);
while ((int)cinfo.output_scanline < img->h)
@@ -242,11 +246,19 @@
r->set_error(r, 500, "unsupported jpeg format");
jpeg_destroy_decompress(&cinfo);
- return NULL;
+ return;
jpeg_finish_decompress(&cinfo);
+geocache_image* _geocache_imageio_jpeg_decode(geocache_context *r, geocache_buffer *buffer) {
+ geocache_image *img = geocache_image_create(r);
+ _geocache_imageio_jpeg_decode_to_image(r, buffer,img);
+ if(GC_HAS_ERROR(r)) {
+ return NULL;
return img;
Modified: trunk/mapserver/mapcache/src/imageio_png.c
--- trunk/mapserver/mapcache/src/imageio_png.c 2011-08-26 11:24:56 UTC (rev 12428)
+++ trunk/mapserver/mapcache/src/imageio_png.c 2011-08-26 11:25:03 UTC (rev 12429)
@@ -41,8 +41,8 @@
// do nothing
-geocache_image* _geocache_imageio_png_decode(geocache_context *ctx, geocache_buffer *buffer) {
- geocache_image *img;
int bit_depth,color_type,i;
unsigned char **row_pointers;
png_structp png_ptr = NULL;
@@ -77,7 +77,6 @@
png_set_read_fn(png_ptr,&b,_geocache_imageio_png_read_func);
png_read_info(png_ptr,info_ptr);
- img = geocache_image_create(ctx);
if(!png_get_IHDR(png_ptr, info_ptr, &width, &height,&bit_depth, &color_type,NULL,NULL,NULL)) {
ctx->set_error(ctx, 500, "failed to read png header");
return NULL;
@@ -85,8 +84,11 @@
img->w = width;
img->h = height;
- img->data = apr_pcalloc(ctx->pool,img->w*img->h*4*sizeof(unsigned char));
+ if(!img->data) {
+ apr_pool_cleanup_register(ctx->pool, img->data, (void*)free, apr_pool_cleanup_null) ;
row_pointers = apr_pcalloc(ctx->pool,img->h * sizeof(unsigned char*));
unsigned char *rowptr = img->data;
@@ -117,6 +119,15 @@
return img;
+geocache_image* _geocache_imageio_png_decode(geocache_context *ctx, geocache_buffer *buffer) {
+ geocache_image *img = geocache_image_create(ctx);
+ _geocache_imageio_png_decode_to_image(ctx,buffer,img);
+ if(GC_HAS_ERROR(ctx))
+ return NULL;
+ return img;
* \brief encode an image to RGB(A) PNG format
* \private \memberof geocache_image_format_png
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:24:56 UTC (rev 12428)
+++ trunk/mapserver/mapcache/src/tileset.c 2011-08-26 11:25:03 UTC (rev 12429)
@@ -96,7 +96,8 @@
image->w = width;
image->h = height;
image->stride = width*4;
- image->data = apr_pcalloc(ctx->pool,width*height*4*sizeof(unsigned char));
+ image->data = calloc(1,width*height*4*sizeof(unsigned char));
+ apr_pool_cleanup_register(ctx->pool, image->data, (void*)free, apr_pool_cleanup_null) ;
if(ntiles == 0) {
return image;
@@ -117,7 +118,8 @@
srcimage->w = (Mx-mx+1)*tiles[0]->grid_link->grid->tile_sx;
srcimage->h = (My-my+1)*tiles[0]->grid_link->grid->tile_sy;
srcimage->stride = srcimage->w*4;
- srcimage->data = apr_pcalloc(ctx->pool,srcimage->w*srcimage->h*4*sizeof(unsigned char));
+ srcimage->data = calloc(1,srcimage->w*srcimage->h*4*sizeof(unsigned char));
+ apr_pool_cleanup_register(ctx->pool, srcimage->data, (void*)free, apr_pool_cleanup_null) ;
cairo_surface_t* srcsurface= cairo_image_surface_create_for_data(srcimage->data, CAIRO_FORMAT_ARGB32,
srcimage->w, srcimage->h,srcimage->stride);
@@ -130,13 +132,10 @@
int ox,oy; /* the offset from the start of the src image to the start of the tile */
ox = (tile->x - mx) * tile->grid_link->grid->tile_sx;
oy = (My - tile->y) * tile->grid_link->grid->tile_sy;
- int row;
- geocache_image *im = geocache_imageio_decode(ctx,tile->data);
- for(row=0;row<tile->grid_link->grid->tile_sy;row++) {
- unsigned char* dstrow = &(srcimage->data[(oy+row)*srcimage->stride+ox*4]);
- unsigned char* srcrow = &(im->data[row*im->stride]);
- memcpy(dstrow,srcrow,im->stride);
+ geocache_image fakeimg;
+ fakeimg.stride = srcimage->stride;
+ fakeimg.data = &(srcimage->data[oy*srcimage->stride+ox*4]);
+ geocache_imageio_decode_to_image(ctx,tile->data,&fakeimg);
assert(toplefttile);
More information about the mapserver-commits
