[mapserver-commits] r12430 - in trunk/mapserver/mapcache: . include src
Fri Aug 26 07:25:09 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:25:09 -0700 (Fri, 26 Aug 2011)
New Revision: 12430
   trunk/mapserver/mapcache/geocache.xml
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/cache_memcache.c
   trunk/mapserver/mapcache/src/configuration.c
   trunk/mapserver/mapcache/src/mod_geocache.c
   trunk/mapserver/mapcache/src/tileset.c
make the xml parser be more lenient when extracting arrays: accept more separators (tabs, commas, newlines, ..)
thomas.bonfort | 2011-08-15 18:21:10 +0200 (Mon, 15 Aug 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:25:03 UTC (rev 12429)
+++ trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:25:09 UTC (rev 12430)
@@ -342,14 +342,12 @@
    <!-- memcache cache
         entry accepts multiple <server> entries
    <cache name="memcache" type="memcache">
       <server>
          <host>localhost</host>
          <port>11211</port>
       </server>
    </cache>
    <!-- format
@@ -468,7 +466,7 @@
          <params>
             <FORMAT>image/png</FORMAT>
             <LAYERS>default</LAYERS>
-            <MAP>/Users/tbonfort/dev/mapserver-utils/osm.map</MAP>
+            <MAP>/gro1/mapserver-utils/osm.map</MAP>
          </params>
       </getmap>
    </source>
@@ -588,8 +586,19 @@
       <!-- expires
          optional expiration value in seconds for a tile. this is expressed in a number of seconds
          after the creation date of the tile
+         This is the value that will be set in the HTTP Expires and Cache-Control headers, and has
+         no effect on the actual expiration of tiles on the caches. See <auto_expire> for that.
       <expires>3600</expires>
+      <!-- auto_expire
+         automatically re-request tiles and update the cache once they are older than the given number
+         of seconds after their creation.
+         Note that this will only delete tiles form the cache when they are accessed, you cannot
+         use this configuration to limit the size of the created cache.
+         Note that if set, this value overrides the value given by <expires>
+      <auto_expire>86400</auto_expire>
       <!-- dimensions
          optional dimensions that should be cached
@@ -656,7 +665,7 @@
          <abstract>see http://mapserver-utils.googlecode.com</abstract>
       </metadata>
       <source>osm</source>
-      <cache>disk</cache>
+      <cache>memcache</cache>
       <format>PNG</format>
       <grid>FXX</grid>
       <grid>MILLER</grid>
@@ -664,6 +673,7 @@
       <grid>g</grid>
       <metatile>5 5</metatile>
       <expires>10000</expires>
       <metabuffer>10</metabuffer>
    </tileset>
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:25:03 UTC (rev 12429)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:25:09 UTC (rev 12430)
@@ -978,8 +978,18 @@
      * number of seconds that should be returned to the client in an Expires: header
+     * \sa auto_expire
     int expires;
+     * number of seconds after which a tile will be regenerated from the source
+     * will take precedence over the #expires parameter.
+     * \sa expires
+    int auto_expire;
      * the cache in which the tiles should be stored
Modified: trunk/mapserver/mapcache/src/cache_memcache.c
--- trunk/mapserver/mapcache/src/cache_memcache.c	2011-08-26 11:25:03 UTC (rev 12429)
+++ trunk/mapserver/mapcache/src/cache_memcache.c	2011-08-26 11:25:09 UTC (rev 12430)
@@ -85,9 +85,8 @@
    _geocache_cache_memcache_tile_key(ctx, tile, &key);
    GC_CHECK_ERROR(ctx);
    rv = apr_memcache_delete(cache->memcache,key,0);
-   if(rv != APR_SUCCESS) {
+   if(rv != APR_SUCCESS && rv!= APR_NOTFOUND) {
       int code = 500;
-      if(rv == APR_NOTFOUND) code=404;
       ctx->set_error(ctx,code,"memcache: failed to delete key %s: %s", key, apr_strerror(rv,errmsg,120));
@@ -116,7 +115,14 @@
       ctx->set_error(ctx,500,"memcache cache returned 0-length data for tile %d %d %d\n",tile->x,tile->y,tile->z);
       return GEOCACHE_FAILURE;
+   /* extract the tile modification time from the end of the data returned */
+   memcpy(
+         &tile->mtime,
+         &(tile->data->buf[tile->data->size-sizeof(apr_time_t)]),
+         sizeof(apr_time_t));
+   tile->data->buf[tile->data->size+sizeof(apr_time_t)]='\0';
    tile->data->avail = tile->data->size;
+   tile->data->size -= sizeof(apr_time_t);
    return GEOCACHE_SUCCESS;
@@ -132,12 +138,23 @@
 static void _geocache_cache_memcache_set(geocache_context *ctx, geocache_tile *tile) {
    char *key;
    int rv;
-   int expires = tile->tileset->expires?tile->tileset->expires:3600;
+   /* set expiration to one day if not configured */
+   int expires = 86400;
+   if(tile->tileset->auto_expire)
+      expires = tile->tileset->auto_expire;
    geocache_cache_memcache *cache = (geocache_cache_memcache*)tile->tileset->cache;
+   /* concatenate the current time to the end of the memcache data so we can extract it out
+    * when we re-get the tile */
+   char *data = calloc(1,tile->data->size+sizeof(apr_time_t));
+   apr_time_t now = apr_time_now();
+   apr_pool_cleanup_register(ctx->pool, data, (void*)free, apr_pool_cleanup_null);
+   memcpy(data,tile->data->buf,tile->data->size);
+   memcpy(&(data[tile->data->size]),&now,sizeof(apr_time_t));
-   rv = apr_memcache_set(cache->memcache,key,(char*)tile->data->buf,tile->data->size,expires,0);
+   rv = apr_memcache_set(cache->memcache,key,data,tile->data->size+sizeof(apr_time_t),expires,0);
       ctx->set_error(ctx,500,"failed to store tile %d %d %d to memcache cache %s",
             tile->x,tile->y,tile->z,cache->cache.name);
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:25:03 UTC (rev 12429)
+++ trunk/mapserver/mapcache/src/configuration.c	2011-08-26 11:25:09 UTC (rev 12430)
@@ -788,6 +788,17 @@
             return;
+   if ((cur_node = ezxml_child(node,"auto_expire")) != NULL) {
+      char *endptr;
+      tileset->auto_expire = (int)strtol(cur_node->txt,&endptr,10);
+      if(*endptr != 0) {
+         ctx->set_error(ctx, 400, "failed to parse auto_expire %s."
+               "(expecting an  integer, "
+               "eg <auto_expire>3600</auto_expire>",
+               cur_node->txt);
+         return;
    if ((cur_node = ezxml_child(node,"metabuffer")) != NULL) {
          char *endptr;
Modified: trunk/mapserver/mapcache/src/mod_geocache.c
--- trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:25:03 UTC (rev 12429)
+++ trunk/mapserver/mapcache/src/mod_geocache.c	2011-08-26 11:25:09 UTC (rev 12430)
@@ -197,6 +197,7 @@
 static int geocache_write_tile(geocache_context_apache_request *ctx, geocache_tile *tile) {
    int rc;
+   char *timestr;
    request_rec *r = ctx->request;
    if(tile->expires) {
@@ -204,15 +205,20 @@
       apr_time_t additional = apr_time_from_sec(tile->expires);
       apr_time_t expires = now + additional;
       apr_table_set(r->headers_out, "Cache-Control",apr_psprintf(r->pool, "max-age=%d", tile->expires));
-      char *timestr = apr_palloc(r->pool, APR_RFC822_DATE_LEN);
+      timestr = apr_palloc(r->pool, APR_RFC822_DATE_LEN);
       apr_rfc822_date(timestr, expires);
-      apr_table_set(r->headers_out, "Expires", timestr);
+      apr_table_setn(r->headers_out, "Expires", timestr);
-   ap_set_last_modified(r);
-   ap_update_mtime(r, tile->mtime);
-   if((rc = ap_meets_conditions(r)) != OK) {
-      return rc;
+   if(tile->mtime) {
+      ap_update_mtime(r, tile->mtime);
+      if((rc = ap_meets_conditions(r)) != OK) {
+         return rc;
+      apr_rfc822_date(timestr, tile->mtime);
+      apr_table_setn(r->headers_out, "Last-Modified", timestr);
    return geocache_write_image_buffer(ctx, tile->data, tile->tileset->format);
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:25:03 UTC (rev 12429)
+++ trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:25:09 UTC (rev 12430)
@@ -271,6 +271,7 @@
    tileset->metasize_x = tileset->metasize_y = 1;
    tileset->metabuffer = 0;
    tileset->expires = 0;
+   tileset->auto_expire = 0;
    tileset->metadata = apr_table_make(ctx->pool,3);
    tileset->dimensions = NULL;
    tileset->format = NULL;
@@ -359,6 +360,18 @@
    ret = tile->tileset->cache->tile_get(ctx, tile);
+   if(ret == GEOCACHE_SUCCESS && tile->tileset->auto_expire && tile->mtime) {
+      /* the cache is in auto-expire mode, and can return the tile modification date
+       * so we check to see if it is stale */
+      apr_time_t stale = tile->mtime + apr_time_from_sec(tile->tileset->auto_expire);
+      if(stale<now) {
+         geocache_tileset_tile_delete(ctx,tile);
+         GC_CHECK_ERROR(ctx);
+         ret = GEOCACHE_CACHE_MISS;
    if(ret == GEOCACHE_CACHE_MISS) {
       /* the tile does not exist, we must take action before re-asking for it */
@@ -419,6 +432,13 @@
             ctx->set_error(ctx, 500, "tileset %s: failed to re-get tile %d %d %d from cache after set", tile->tileset->name,tile->x,tile->y,tile->z);
+      /* update the tile expiration time */
+      if(tile->tileset->auto_expire && tile->mtime) {
+         apr_time_t expire_time = tile->mtime + apr_time_from_sec(tile->tileset->auto_expire);
+         tile->expires = apr_time_sec(expire_time-now);
