[mapserver-commits] r12436 - in trunk/mapserver/mapcache: . include
src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:25:56 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:25:56 -0700 (Fri, 26 Aug 2011)
New Revision: 12436
trunk/mapserver/mapcache/geocache.xml
trunk/mapserver/mapcache/include/geocache.h
trunk/mapserver/mapcache/src/core.c
trunk/mapserver/mapcache/src/service_wms.c
be more verbose on sqlite failed setup
thomas.bonfort | 2011-08-17 13:29:03 +0200 (Wed, 17 Aug 2011)
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:25:33 UTC (rev 12435)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:25:56 UTC (rev 12436)
@@ -665,7 +665,7 @@
<abstract>see http://mapserver-utils.googlecode.com</abstract>
</metadata>
<source>osm</source>
- <cache>memcache</cache>
+ <cache>disk</cache>
<format>PNG</format>
<grid>FXX</grid>
<grid>MILLER</grid>
@@ -710,14 +710,12 @@
tilesets, and can optionally forward all the rest to (an)other server(s)
TODO: this needs way more documenting
<forwarding_rule name="foo rule">
<append_pathinfo>true</append_pathinfo>
<http>
<url>http://localhost/</url>
</http>
</forwarding_rule>
</service>
<service type="wmts" enabled="true"/>
<service type="tms" enabled="true"/>
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:25:33 UTC (rev 12435)
+++ trunk/mapserver/mapcache/include/geocache.h 2011-08-26 11:25:56 UTC (rev 12436)
@@ -496,12 +496,14 @@
geocache_request request;
geocache_http *http;
apr_table_t *params;
+ char *pathinfo;
struct geocache_forwarding_rule {
char *name;
apr_array_header_t *match_params; /* actually those are geocache_dimensions */
+ int append_pathinfo;
Modified: trunk/mapserver/mapcache/src/core.c
--- trunk/mapserver/mapcache/src/core.c 2011-08-26 11:25:33 UTC (rev 12435)
+++ trunk/mapserver/mapcache/src/core.c 2011-08-26 11:25:56 UTC (rev 12436)
@@ -132,7 +132,12 @@
response->data = geocache_buffer_create(30000,ctx->pool);
response->headers = apr_table_make(ctx->pool,1);
- geocache_http_do_request_with_params(ctx,req_proxy->http,req_proxy->params,response->data,response->headers);
+ geocache_http *http = req_proxy->http;
+ if(req_proxy->pathinfo) {
+ http = geocache_http_clone(ctx,http);
+ http->url = apr_pstrcat(ctx->pool,http->url,req_proxy->pathinfo,NULL);
+ geocache_http_do_request_with_params(ctx,http,req_proxy->params,response->data,response->headers);
return response;
Modified: trunk/mapserver/mapcache/src/service_wms.c
--- trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:25:33 UTC (rev 12435)
+++ trunk/mapserver/mapcache/src/service_wms.c 2011-08-26 11:25:56 UTC (rev 12436)
@@ -713,6 +713,11 @@
(*request)->type = GEOCACHE_REQUEST_PROXY;
req_proxy->http = rule->http;
req_proxy->params = params;
+ if(rule->append_pathinfo) {
+ req_proxy->pathinfo = pathinfo;
+ } else {
+ req_proxy->pathinfo = NULL;
return;
@@ -727,9 +732,10 @@
return;
#ifdef DEBUG
- if((*request)->type != GEOCACHE_REQUEST_GET_TILE && (*request)->type != GEOCACHE_REQUEST_GET_MAP &&
- (*request)->type != GEOCACHE_REQUEST_GET_CAPABILITIES &&
- (*request)->type != GEOCACHE_REQUEST_GET_FEATUREINFO ) {
+ if((*request)->type != GEOCACHE_REQUEST_GET_TILE &&
+ (*request)->type != GEOCACHE_REQUEST_GET_MAP &&
+ (*request)->type != GEOCACHE_REQUEST_GET_FEATUREINFO &&
+ (*request)->type != GEOCACHE_REQUEST_GET_CAPABILITIES) {
ctx->set_error(ctx,500,"BUG: request not gettile or getmap");
return;
@@ -747,6 +753,12 @@
rule->name = apr_pstrdup(ctx->pool,name);
rule->match_params = apr_array_make(ctx->pool,1,sizeof(geocache_dimension*));
+ ezxml_t pathinfo_node = ezxml_child(rule_node,"append_pathinfo");
+ if(pathinfo_node && !strcasecmp(pathinfo_node->txt,"true")) {
+ rule->append_pathinfo = 1;
+ } else {
+ rule->append_pathinfo = 0;
ezxml_t http_node = ezxml_child(rule_node,"http");
if(!http_node) {
ctx->set_error(ctx,500,"rule \"%s\" does not contain an <http> block",name);
More information about the mapserver-commits
