[mapserver-commits] r12437 - trunk/mapserver/mapcache/src
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:26:00 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:26:00 -0700 (Fri, 26 Aug 2011)
New Revision: 12437
trunk/mapserver/mapcache/src/configuration.c
<source> is now optional when configuring a tileset (typically for mbtiles support)
fix some segfaults in capabilities when no format was configured
thomas.bonfort | 2011-08-18 15:26:00 +0200 (Thu, 18 Aug 2011)
Modified: trunk/mapserver/mapcache/src/configuration.c
--- trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:25:56 UTC (rev 12436)
+++ trunk/mapserver/mapcache/src/configuration.c 2011-08-26 11:26:00 UTC (rev 12437)
@@ -747,13 +747,11 @@
ctx->set_error(ctx,400, "watermark config entry empty");
return;
- apr_pool_t *tmppool;
- apr_pool_create(&tmppool,ctx->pool);
apr_file_t *f;
apr_finfo_t finfo;
int rv;
if(apr_file_open(&f, cur_node->txt, APR_FOPEN_READ|APR_FOPEN_BUFFERED|APR_FOPEN_BINARY,
- APR_OS_DEFAULT, tmppool) != APR_SUCCESS) {
+ APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
ctx->set_error(ctx,500, "failed to open watermark image %s",cur_node->txt);
return;
@@ -763,19 +761,18 @@
return;
- geocache_buffer *watermarkdata = geocache_buffer_create(finfo.size,tmppool);
+ geocache_buffer *watermarkdata = geocache_buffer_create(finfo.size,ctx->pool);
//manually add the data to our buffer
apr_size_t size;
apr_file_read(f,(void*)watermarkdata->buf,&size);
watermarkdata->size = size;
- apr_file_close(f);
if(size != finfo.size) {
ctx->set_error(ctx, 500, "failed to copy watermark image data, got %d of %d bytes",(int)size, (int)finfo.size);
return;
+ apr_file_close(f);
tileset->watermark = geocache_imageio_decode(ctx,watermarkdata);
GC_CHECK_ERROR(ctx);
- apr_pool_destroy(tmppool);
More information about the mapserver-commits
