[mapserver-commits] r12452 - in trunk/mapserver/mapcache: . include src
Fri Aug 26 07:27:40 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:27:40 -0700 (Fri, 26 Aug 2011)
New Revision: 12452
   trunk/mapserver/mapcache/geocache.xml
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/cache_disk.c
   trunk/mapserver/mapcache/src/configuration_xml.c
   trunk/mapserver/mapcache/src/util.c
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:27:35 UTC (rev 12451)
+++ trunk/mapserver/mapcache/geocache.xml	2011-08-26 11:27:40 UTC (rev 12452)
@@ -337,12 +337,9 @@
       <symlink_blank/>
    </cache>
-        a cache is where tiles are stored once they have been rendered
-   <cache name="tmpl" type="template">
-      <template>/tmp/tmpl/{{tileset}}/{{grid}}/{{z}}-{{x}}-{{inv_y}}.{{ext}}</template>
+   <cache name="tmpl" type="disk">
+      <template>/tmp/template-test/{tileset}#{grid}#{dim}/{z}/{x}/{y}.{ext}</template>
    </cache>
    <!-- memcache cache
@@ -674,7 +671,7 @@
    </tileset>
    <tileset name="test2">
       <source>nexrad</source>
-      <cache>tmpl</cache>
+      <cache>disk</cache>
       <format>mixed</format>
       <grid>WGS84</grid>
    </tileset>
@@ -692,7 +689,7 @@
          <abstract>see http://mapserver-utils.googlecode.com</abstract>
       </metadata>
       <source>osm</source>
-      <cache>sqlite</cache>
+      <cache>tmpl</cache>
       <format>PNG</format>
       <grid>FXX</grid>
       <grid>MILLER</grid>
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:27:35 UTC (rev 12451)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:27:40 UTC (rev 12452)
@@ -87,9 +87,7 @@
 #if 0
 typedef struct geocache_source_gdal geocache_source_gdal;
 #endif
-typedef struct geocache_cache_filesystem geocache_cache_filesystem;
 typedef struct geocache_cache_disk geocache_cache_disk;
-typedef struct geocache_cache_disk_template geocache_cache_disk_template;
 typedef struct geocache_http geocache_http;
 typedef struct geocache_request geocache_request;
 typedef struct geocache_request_proxy geocache_request_proxy;
@@ -320,8 +318,7 @@
 typedef enum {
-    GEOCACHE_CACHE_DISK,
-    GEOCACHE_CACHE_DISK_TEMPLATE
+    GEOCACHE_CACHE_DISK
 #ifdef USE_MEMCACHE
        ,GEOCACHE_CACHE_MEMCACHE
 #endif
@@ -367,36 +364,18 @@
     void (*configuration_post_config)(geocache_context *ctx, geocache_cache * cache, geocache_cfg *config);
-/**\class geocache_cache_filesystem
+/**\class geocache_cache_disk
  * \brief a geocache_cache on a filesytem
  * \implements geocache_cache
-struct geocache_cache_filesystem {
+struct geocache_cache_disk {
     geocache_cache cache;
-    void (*tile_key)(geocache_context *ctx, geocache_tile *tile, const char **path);
-    void (*blank_key)(geocache_context *ctx, geocache_tile *tile, unsigned char *color, char **path);
+    char *base_directory;
+    char *filename_template;
     int symlink_blank;
-/**\class geocache_cache_disk
- * \brief a geocache_cache
- * \implements geocache_cache
-struct geocache_cache_disk {
-    geocache_cache_filesystem cache;
-    char *base_directory;
- * \brief a geocache_cache on a filesytem
-struct geocache_cache_disk_template {
-    char *template;
 #ifdef USE_SQLITE
 /**\class geocache_cache_sqlite
@@ -934,7 +913,6 @@
  * \memberof geocache_cache_disk
 geocache_cache* geocache_cache_disk_create(geocache_context *ctx);
-geocache_cache* geocache_cache_disk_template_create(geocache_context *ctx);
 /** \defgroup tileset Tilesets*/
@@ -1242,7 +1220,7 @@
         int *numbers_count);
 int geocache_util_extract_double_list(geocache_context *ctx, const char* args, const char sep, double **numbers,
-const char *geocache_util_str_replace(apr_pool_t *pool, const char *string, const char *substr,
+char *geocache_util_str_replace(apr_pool_t *pool, const char *string, const char *substr,
       const char *replacement );
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c	2011-08-26 11:27:35 UTC (rev 12451)
+++ trunk/mapserver/mapcache/src/cache_disk.c	2011-08-26 11:27:40 UTC (rev 12452)
@@ -26,6 +26,7 @@
 #endif
 static void _geocache_cache_disk_blank_tile_key(geocache_context *ctx, geocache_tile *tile, unsigned char *color, char **path) {
+   /* not implemented for template caches, as symlink_blank will never be set */
    *path = apr_psprintf(ctx->pool,"%s/%s/%s/blanks/%02X%02X%02X%02X.%s",
          ((geocache_cache_disk*)tile->tileset->cache)->base_directory,
          tile->tileset->name,
@@ -47,68 +48,98 @@
  * \param r
  * \private \memberof geocache_cache_disk
-static void _geocache_cache_disk_tile_key(geocache_context *ctx, geocache_tile *tile, const char **path) {
-   char *start;
-   start = apr_pstrcat(ctx->pool,
-         ((geocache_cache_disk*)tile->tileset->cache)->base_directory,"/",
-         tile->tileset->name,"/",
-         tile->grid_link->grid->name,
-         NULL);
-   if(tile->dimensions) {
-      const apr_array_header_t *elts = apr_table_elts(tile->dimensions);
-      int i = elts->nelts;
-      while(i--) {
-         apr_table_entry_t *entry = &(APR_ARRAY_IDX(elts,i,apr_table_entry_t));
-         char *dimval = apr_pstrdup(ctx->pool,entry->val);
-         char *iter = dimval;
-         while(*iter) {
-            /* replace dangerous characters by '#' */
-            if(*iter == '.' || *iter == '/') {
-               *iter = '#';
+static void _geocache_cache_disk_tile_key(geocache_context *ctx, geocache_tile *tile, char **path) {
+   geocache_cache_disk *dcache = (geocache_cache_disk*)tile->tileset->cache;
+   if(dcache->base_directory) {
+      char *start;
+      start = apr_pstrcat(ctx->pool,
+            dcache->base_directory,"/",
+            tile->tileset->name,"/",
+            tile->grid_link->grid->name,
+            NULL);
+      if(tile->dimensions) {
+         const apr_array_header_t *elts = apr_table_elts(tile->dimensions);
+         int i = elts->nelts;
+         while(i--) {
+            apr_table_entry_t *entry = &(APR_ARRAY_IDX(elts,i,apr_table_entry_t));
+            char *dimval = apr_pstrdup(ctx->pool,entry->val);
+            char *iter = dimval;
+            while(*iter) {
+               /* replace dangerous characters by '#' */
+               if(*iter == '.' || *iter == '/') {
+                  *iter = '#';
+               iter++;
-            iter++;
+            start = apr_pstrcat(ctx->pool,start,"/",entry->key,"/",dimval,NULL);
-         start = apr_pstrcat(ctx->pool,start,"/",entry->key,"/",dimval,NULL);
+      *path = apr_psprintf(ctx->pool,"%s/%02d/%03d/%03d/%03d/%03d/%03d/%03d.%s",
+            start,
+            tile->z,
+            tile->x / 1000000,
+            (tile->x / 1000) % 1000,
+            tile->x % 1000,
+            tile->y / 1000000,
+            (tile->y / 1000) % 1000,
+            tile->y % 1000,
+            tile->tileset->format?tile->tileset->format->extension:"png");
+   } else {
+      *path = dcache->filename_template;
+      *path = geocache_util_str_replace(ctx->pool,*path, "{tileset}", tile->tileset->name);
+      *path = geocache_util_str_replace(ctx->pool,*path, "{grid}", tile->grid_link->grid->name);
+      *path = geocache_util_str_replace(ctx->pool,*path, "{ext}",
+      if(strstr(*path,"{x}"))
+         *path = geocache_util_str_replace(ctx->pool,*path, "{x}",
+               apr_psprintf(ctx->pool,"%d",tile->x));
+      else
+         *path = geocache_util_str_replace(ctx->pool,*path, "{inv_x}",
+                  tile->grid_link->grid->levels[tile->z]->maxx - tile->x - 1));
+      if(strstr(*path,"{y}"))
+         *path = geocache_util_str_replace(ctx->pool,*path, "{y}",
+               apr_psprintf(ctx->pool,"%d",tile->y));
+      else
+         *path = geocache_util_str_replace(ctx->pool,*path, "{inv_y}",
+                  tile->grid_link->grid->levels[tile->z]->maxy - tile->y - 1));
+      if(strstr(*path,"{z}"))
+         *path = geocache_util_str_replace(ctx->pool,*path, "{z}",
+               apr_psprintf(ctx->pool,"%d",tile->z));
+      else
+         *path = geocache_util_str_replace(ctx->pool,*path, "{inv_z}",
+                  tile->grid_link->grid->nlevels - tile->z - 1));
+         char *dimstring="";
+         while(i--) {
+            while(*iter) {
+                  *iter = '#';
+               iter++;
+            dimstring = apr_pstrcat(ctx->pool,dimstring,"#",entry->key,"#",dimval,NULL);
+         *path = geocache_util_str_replace(ctx->pool,*path, "{dim}", dimstring);
-   *path = apr_psprintf(ctx->pool,"%s/%02d/%03d/%03d/%03d/%03d/%03d/%03d.%s",
-         start,
-         tile->z,
-         tile->x / 1000000,
-         (tile->x / 1000) % 1000,
-         tile->x % 1000,
-         tile->y / 1000000,
-         (tile->y / 1000) % 1000,
-         tile->y % 1000,
-         tile->tileset->format?tile->tileset->format->extension:"png");
    if(!*path) {
       ctx->set_error(ctx,500, "failed to allocate tile key");
-static void _geocache_cache_template_tile_key(geocache_context *ctx, geocache_tile *tile, const char **path) {
-   geocache_cache_disk_template *tcache = (geocache_cache_disk_template*)tile->tileset->cache;
-   *path = tcache->template;
-   *path = geocache_util_str_replace(ctx->pool,*path, "{{tileset}}", tile->tileset->name);
-   *path = geocache_util_str_replace(ctx->pool,*path, "{{grid}}", tile->grid_link->grid->name);
-   *path = geocache_util_str_replace(ctx->pool,*path, "{{ext}}", tile->tileset->format?tile->tileset->format->extension:"png");
-   *path = geocache_util_str_replace(ctx->pool,*path, "{{x}}",apr_psprintf(ctx->pool,"%d",tile->x));
-   *path = geocache_util_str_replace(ctx->pool,*path, "{{y}}",apr_psprintf(ctx->pool,"%d",tile->y));
-   *path = geocache_util_str_replace(ctx->pool,*path, "{{z}}",apr_psprintf(ctx->pool,"%d",tile->z));
-   *path = geocache_util_str_replace(ctx->pool,*path, "{{inv_x}}",apr_psprintf(ctx->pool,"%d",tile->grid_link->grid->levels[tile->z]->maxx - tile->x - 1));
-   *path = geocache_util_str_replace(ctx->pool,*path, "{{inv_y}}",apr_psprintf(ctx->pool,"%d",tile->grid_link->grid->levels[tile->z]->maxy - tile->y - 1));
-   *path = geocache_util_str_replace(ctx->pool,*path, "{{inv_z}}",apr_psprintf(ctx->pool,"%d",tile->grid_link->grid->nlevels - tile->z - 1));
-   ctx->log(ctx,GEOCACHE_WARNING, "key is %s", *path);
-static int _geocache_cache_filesystem_has_tile(geocache_context *ctx, geocache_tile *tile) {
-   geocache_cache_filesystem *fcache = (geocache_cache_filesystem*)tile->tileset->cache;
-   const char *filename;
+static int _geocache_cache_disk_has_tile(geocache_context *ctx, geocache_tile *tile) {
+   char *filename;
    apr_file_t *f;
-   fcache->tile_key(ctx, tile, &filename);
+   _geocache_cache_disk_tile_key(ctx, tile, &filename);
    if(GC_HAS_ERROR(ctx)) {
       return GEOCACHE_FALSE;
@@ -120,13 +151,12 @@
-static void _geocache_cache_filesystem_delete(geocache_context *ctx, geocache_tile *tile) {
+static void _geocache_cache_disk_delete(geocache_context *ctx, geocache_tile *tile) {
    apr_status_t ret;
    char errmsg[120];
+   char *filename;
    apr_file_t *f;
    GC_CHECK_ERROR(ctx);
    /* delete the tile file if it already exists */
@@ -155,14 +185,13 @@
  * \sa geocache_cache::tile_get()
-static int _geocache_cache_filesystem_get(geocache_context *ctx, geocache_tile *tile) {
+static int _geocache_cache_disk_get(geocache_context *ctx, geocache_tile *tile) {
+   char *filename;
    apr_file_t *f;
    apr_finfo_t finfo;
    apr_status_t rv;
    apr_size_t size;
       return GEOCACHE_FAILURE;
@@ -215,14 +244,12 @@
  * \sa geocache_cache::tile_set()
-static void _geocache_cache_filesystem_set(geocache_context *ctx, geocache_tile *tile) {
+static void _geocache_cache_disk_set(geocache_context *ctx, geocache_tile *tile) {
    apr_size_t bytes;
    apr_file_t *f;
    apr_status_t ret;
    char errmsg[120];
-   const char *filename, *hackptr1;
-   char *hackptr2=NULL;
+   char *filename, *hackptr1, *hackptr2=NULL;
 #ifdef DEBUG
    /* all this should be checked at a higher level */
    if(!tile->data || !tile->data->size) {
@@ -230,14 +257,14 @@
       return;
 #endif
    /* find the location of the last '/' in the string */
    hackptr1 = filename;
    while(*hackptr1) {
       if(*hackptr1 == '/')
-         hackptr2 = (char*)hackptr1;
+         hackptr2 = hackptr1;
       hackptr1++;
    *hackptr2 = '\0';
@@ -266,12 +293,12 @@
 #ifdef HAVE_SYMLINK
-   if(fcache->symlink_blank) {
+   if(((geocache_cache_disk*)tile->tileset->cache)->symlink_blank) {
       geocache_image *image = geocache_imageio_decode(ctx, tile->data);
       if(geocache_image_blank_color(image) != GEOCACHE_FALSE) {
          char *blankname;
-         fcache->blank_key(ctx,tile,image->data,&blankname);
+         _geocache_cache_disk_blank_tile_key(ctx,tile,image->data,&blankname);
          ctx->global_lock_aquire(ctx);
@@ -361,45 +388,30 @@
-static void _geocache_cache_template_configuration_parse_xml(geocache_context *ctx, ezxml_t node, geocache_cache *cache) {
-   ezxml_t cur_node;
-   geocache_cache_disk_template *dcache = (geocache_cache_disk_template*)cache;
-   if ((cur_node = ezxml_child(node,"template")) != NULL) {
-      dcache->template = apr_pstrdup(ctx->pool,cur_node->txt);
- * \private \memberof geocache_cache_disk
 static void _geocache_cache_disk_configuration_parse_xml(geocache_context *ctx, ezxml_t node, geocache_cache *cache) {
    ezxml_t cur_node;
    geocache_cache_disk *dcache = (geocache_cache_disk*)cache;
    if ((cur_node = ezxml_child(node,"base")) != NULL) {
       dcache->base_directory = apr_pstrdup(ctx->pool,cur_node->txt);
-   if ((cur_node = ezxml_child(node,"symlink_blank")) != NULL) {
-      if(strcasecmp(cur_node->txt,"false")){
+      /* we don't check for symlinking in the case where we are using a "template" cache type */
+      if ((cur_node = ezxml_child(node,"symlink_blank")) != NULL) {
+         if(strcasecmp(cur_node->txt,"false")){
 #ifdef HAVE_SYMLINK
-         dcache->cache.symlink_blank = 1;
+            dcache->symlink_blank = 1;
 #else
-         ctx->set_error(ctx,400,"cache %s: host system does not support file symbolic linking",cache->name);
-         return;
+            ctx->set_error(ctx,400,"cache %s: host system does not support file symbolic linking",cache->name);
+            return;
 #endif
+   } else {
+      if ((cur_node = ezxml_child(node,"template")) != NULL) {
+         dcache->filename_template = apr_pstrdup(ctx->pool,cur_node->txt);
-static void _geocache_cache_template_configuration_post_config(geocache_context *ctx, geocache_cache *cache,
-      geocache_cfg *cfg) {
-   if(!dcache->template || !strlen(dcache->template)) {
-      ctx->set_error(ctx, 400, "disk cache %s has no base directory",cache->name);
-      return;
@@ -407,72 +419,33 @@
    /* check all required parameters are configured */
-   if(!dcache->base_directory || !strlen(dcache->base_directory)) {
-      ctx->set_error(ctx, 400, "disk cache %s has no base directory",dcache->cache.cache.name);
+   if((!dcache->base_directory || !strlen(dcache->base_directory)) &&
+         (!dcache->filename_template || !strlen(dcache->filename_template))) {
+      ctx->set_error(ctx, 400, "disk cache %s has no base directory or template",dcache->cache.name);
       return;
-   apr_dir_t *basedir;
-   apr_status_t rv;
-   rv = apr_dir_open(&basedir,dcache->base_directory,ctx->pool);
-   char errmsg[120];
-   if(rv != APR_SUCCESS) {
-      ctx->log(ctx,GEOCACHE_WARNING, "failed to open base directory %s for cache %s: %s."\
-            " This might lead to problems later on if the apache user does not have the rights to create this directory",
-            dcache->base_directory,cache->name,apr_strerror(rv,errmsg,120));
-   return;
  * \brief creates and initializes a geocache_disk_cache
 geocache_cache* geocache_cache_disk_create(geocache_context *ctx) {
-   geocache_cache_disk *dcache = apr_pcalloc(ctx->pool,sizeof(geocache_cache_disk));
-   geocache_cache_filesystem *fcache = (geocache_cache_filesystem*)dcache;
-   geocache_cache *cache = (geocache_cache*)dcache;
+   geocache_cache_disk *cache = apr_pcalloc(ctx->pool,sizeof(geocache_cache_disk));
    if(!cache) {
       ctx->set_error(ctx, 500, "failed to allocate disk cache");
       return NULL;
-   fcache->symlink_blank = 0;
-   fcache->tile_key = _geocache_cache_disk_tile_key;
-   fcache->blank_key = _geocache_cache_disk_blank_tile_key;
-   cache->metadata = apr_table_make(ctx->pool,3);
-   cache->type = GEOCACHE_CACHE_DISK;
-   cache->tile_delete = _geocache_cache_filesystem_delete;
-   cache->tile_get = _geocache_cache_filesystem_get;
-   cache->tile_exists = _geocache_cache_filesystem_has_tile;
-   cache->tile_set = _geocache_cache_filesystem_set;
-   cache->configuration_post_config = _geocache_cache_disk_configuration_post_config;
-   cache->configuration_parse_xml = _geocache_cache_disk_configuration_parse_xml;
+   cache->symlink_blank = 0;
+   cache->cache.metadata = apr_table_make(ctx->pool,3);
+   cache->cache.type = GEOCACHE_CACHE_DISK;
+   cache->cache.tile_delete = _geocache_cache_disk_delete;
+   cache->cache.tile_get = _geocache_cache_disk_get;
+   cache->cache.tile_exists = _geocache_cache_disk_has_tile;
+   cache->cache.tile_set = _geocache_cache_disk_set;
+   cache->cache.configuration_post_config = _geocache_cache_disk_configuration_post_config;
+   cache->cache.configuration_parse_xml = _geocache_cache_disk_configuration_parse_xml;
    return (geocache_cache*)cache;
- * \brief creates and initializes a geocache_cache_disk_template
-geocache_cache* geocache_cache_disk_template_create(geocache_context *ctx) {
-   geocache_cache_disk_template *dcache = apr_pcalloc(ctx->pool,sizeof(geocache_cache_disk_template));
-   if(!cache) {
-      ctx->set_error(ctx, 500, "failed to allocate disk template cache");
-      return NULL;
-   fcache->tile_key = _geocache_cache_template_tile_key;
-   cache->type = GEOCACHE_CACHE_DISK_TEMPLATE;
-   cache->configuration_post_config = _geocache_cache_template_configuration_post_config;
-   cache->configuration_parse_xml = _geocache_cache_template_configuration_parse_xml;
-   return (geocache_cache*)cache;
 /* vim: ai ts=3 sts=3 et sw=3
Modified: trunk/mapserver/mapcache/src/configuration_xml.c
--- trunk/mapserver/mapcache/src/configuration_xml.c	2011-08-26 11:27:35 UTC (rev 12451)
+++ trunk/mapserver/mapcache/src/configuration_xml.c	2011-08-26 11:27:40 UTC (rev 12452)
@@ -578,8 +578,6 @@
    if(!strcmp(type,"disk")) {
       cache = geocache_cache_disk_create(ctx);
-   } else if(!strcmp(type,"template")) {
-      cache = geocache_cache_disk_template_create(ctx);
    } else if(!strcmp(type,"sqlite3")) {
 #ifdef USE_SQLITE
       cache = geocache_cache_sqlite_create(ctx);
Modified: trunk/mapserver/mapcache/src/util.c
--- trunk/mapserver/mapcache/src/util.c	2011-08-26 11:27:35 UTC (rev 12451)
+++ trunk/mapserver/mapcache/src/util.c	2011-08-26 11:27:40 UTC (rev 12452)
@@ -75,6 +75,20 @@
    return GEOCACHE_SUCCESS;
+char *geocache_util_str_replace(apr_pool_t *pool, const char *string, const char *substr, const char *replacement ){
+   char *tok = NULL;
+   char *newstr = NULL;
+   tok = strstr( string, substr );
+   if( tok == NULL ) return apr_pstrdup( pool, string );
+   newstr = apr_pcalloc(pool, strlen( string ) - strlen( substr ) + strlen( replacement ) + 1 );
+   memcpy( newstr, string, tok - string );
+   memcpy( newstr + (tok - string), replacement, strlen( replacement ) );
+   memcpy( newstr + (tok - string) + strlen( replacement ), tok + strlen( substr ), strlen( string ) - strlen( substr ) - ( tok - string ) );
+   memset( newstr + strlen( string ) - strlen( substr ) + strlen( replacement ), 0, 1 );
+   return newstr;
 #if APR_MAJOR_VERSION < 1 || (APR_MAJOR_VERSION < 2 && APR_MINOR_VERSION < 3)
 APR_DECLARE(apr_table_t *) apr_table_clone(apr_pool_t *p, const apr_table_t *t)
@@ -130,19 +144,5 @@
     ctx->clear_errors = _geocache_context_clear_error_default;
-const char *geocache_util_str_replace(apr_pool_t *pool, const char *string, const char *substr, const char *replacement ){
-   char *tok = NULL;
-   char *newstr = NULL;
-   tok = strstr( string, substr );
-   if( tok == NULL ) return apr_pstrdup( pool, string );
-   newstr = apr_pcalloc(pool, strlen( string ) - strlen( substr ) + strlen( replacement ) + 1 );
-   memcpy( newstr, string, tok - string );
-   memcpy( newstr + (tok - string), replacement, strlen( replacement ) );
-   memcpy( newstr + (tok - string) + strlen( replacement ), tok + strlen( substr ), strlen( string ) - strlen( substr ) - ( tok - string ) );
-   memset( newstr + strlen( string ) - strlen( substr ) + strlen( replacement ), 0, 1 );
-   return newstr;
