[mapserver-commits] r12453 - trunk/mapserver/mapcache
svn at osgeo.org
svn at osgeo.org
Fri Aug 26 07:27:45 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:27:45 -0700 (Fri, 26 Aug 2011)
New Revision: 12453
trunk/mapserver/mapcache/geocache.xml
Modified: trunk/mapserver/mapcache/geocache.xml
--- trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:27:40 UTC (rev 12452)
+++ trunk/mapserver/mapcache/geocache.xml 2011-08-26 11:27:45 UTC (rev 12453)
@@ -339,6 +339,28 @@
</cache>
<cache name="tmpl" type="disk">
+ <!-- template
+ string template that will be used to map a tile (by tileset, grid name, dimension,
+ format, x, y, and z) to a filename on the filesystem.
+ the following replacements are performed:
+ - {tileset} : the tileset name
+ - {grid} : the grid name
+ - {dim} : a string that concatenates the tile's dimension
+ - {ext} : the filename extension for the tile's image format
+ - {x},{y},{z} : the tile x,y,z values
+ - {inv_x}, {inv_y}, {inv_z} : inverted x,y,z values (inv_x = level->maxx - x - 1). This
+ is mainly used to support grids where one axis is inverted (e.g. the google schema)
+ and you want to create on offline cache.
+ * note that this type of cache does not support blank-tile detection and symlinking.
+ * warning: it is up to you to make sure that the template you chose creates a unique
+ filename for your given tilesets. e.g. do not ommit the {grid} parameter if your
+ tilesets reference multiple grids. Failure to do so will result in filename
+ collisions !
<template>/tmp/template-test/{tileset}#{grid}#{dim}/{z}/{x}/{y}.{ext}</template>
</cache>
More information about the mapserver-commits
