[mapserver-commits] r12454 - in trunk/mapserver/mapcache: . include src
Fri Aug 26 07:27:51 EDT 2011
Author: tbonfort
Date: 2011-08-26 04:27:51 -0700 (Fri, 26 Aug 2011)
New Revision: 12454
   trunk/mapserver/mapcache/INSTALL
   trunk/mapserver/mapcache/Makefile.inc.in
   trunk/mapserver/mapcache/configure.in
   trunk/mapserver/mapcache/include/geocache.h
   trunk/mapserver/mapcache/src/configuration_xml.c
   trunk/mapserver/mapcache/src/core.c
   trunk/mapserver/mapcache/src/image.c
   trunk/mapserver/mapcache/src/tileset.c
Modified: trunk/mapserver/mapcache/INSTALL
--- trunk/mapserver/mapcache/INSTALL	2011-08-26 11:27:45 UTC (rev 12453)
+++ trunk/mapserver/mapcache/INSTALL	2011-08-26 11:27:51 UTC (rev 12454)
@@ -87,19 +87,6 @@
 this is the path where the libjpeg headers and libs can be located.
 the configure script will be looking for [path]/include/jpeg.h and [path]/lib/libjpeg.so
-cairo (optional)
---with-pkg-config=/path/to/pkg-config
---with-cairo=/path/to/cairo.pc
-cairo support is required if you want to enable full wms getmap support, i.e. reconstructing a full getmap request
-by assembling tiles next to one another.
-cairo configuration step requires the pkg-config utility.
-if your cairo libs and headers aren't in a default location, there's a chance they won't be picked up by the default
-pkg-config utility. In that case, you can use the --with-cairo=/path/to/cairo.pc to explicitely tell pkg-config
-where to find the configuration options for your version of cairo.
 gdal (from 0.4 onwards) (optional)
Modified: trunk/mapserver/mapcache/Makefile.inc.in
--- trunk/mapserver/mapcache/Makefile.inc.in	2011-08-26 11:27:45 UTC (rev 12453)
+++ trunk/mapserver/mapcache/Makefile.inc.in	2011-08-26 11:27:51 UTC (rev 12454)
@@ -44,18 +44,14 @@
 GEOS_LIB=@GEOS_LIB@
 GEOS_ENABLED=@GEOS_ENABLED@
-CAIRO_INC=@CAIRO_INC@
-CAIRO_LIB=@CAIRO_LIB@
-CAIRO_ENABLED=@CAIRO_ENABLED@
 SQLITE_INC=@SQLITE_INC@
 SQLITE_LIB=@SQLITE_LIB@
 SQLITE_ENABLED=@SQLITE_ENABLED@
 MISC_ENABLED=@MISC_ENABLED@ -DTHREADED_MPM=$(shell $(HTTPD) -V | grep "Server MPM" | grep -q "Prefork"; echo $$?)
-INCLUDES=-I../include $(MISC_ENABLED) $(CAIRO_ENABLED) $(CAIRO_INC) $(CURL_CFLAGS) $(PNG_INC) $(JPEG_INC) $(GDAL_INC) $(GEOS_INC) $(APR_INC) $(APU_INC) $(MEMCACHE_ENABLED) $(PCRE_CFLAGS) $(PCRE_ENABLED) $(OGR_ENABLED) $(GEOS_ENABLED) $(SQLITE_ENABLED)
-LIBS=$(CURL_LIBS) $(CAIRO_LIB) $(PNG_LIB) $(JPEG_LIB) $(APR_LIBS) $(APU_LIBS) $(PCRE_LIBS) $(SQLITE_LIB)
+INCLUDES=-I../include $(MISC_ENABLED) $(CURL_CFLAGS) $(PNG_INC) $(JPEG_INC) $(GDAL_INC) $(GEOS_INC) $(APR_INC) $(APU_INC) $(MEMCACHE_ENABLED) $(PCRE_CFLAGS) $(PCRE_ENABLED) $(OGR_ENABLED) $(GEOS_ENABLED) $(SQLITE_ENABLED)
+LIBS=$(CURL_LIBS) $(PNG_LIB) $(JPEG_LIB) $(APR_LIBS) $(APU_LIBS) $(PCRE_LIBS) $(SQLITE_LIB)
 SEEDER_EXTRALIBS=$(GDAL_LIB) $(GEOS_LIB)
Modified: trunk/mapserver/mapcache/configure.in
--- trunk/mapserver/mapcache/configure.in	2011-08-26 11:27:45 UTC (rev 12453)
+++ trunk/mapserver/mapcache/configure.in	2011-08-26 11:27:51 UTC (rev 12454)
@@ -711,7 +711,7 @@
 APU_CHECK
 SQLITE_CHECK
 PKGCONFIG_CHECK
-CAIRO_CHECK
+# CAIRO_CHECK
 PNG_CHECK
 JPEG_CHECK
Modified: trunk/mapserver/mapcache/include/geocache.h
--- trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:27:45 UTC (rev 12453)
+++ trunk/mapserver/mapcache/include/geocache.h	2011-08-26 11:27:51 UTC (rev 12454)
@@ -742,6 +742,12 @@
 geocache_tile* geocache_image_merge_tiles(geocache_context *ctx, geocache_image_format *format, geocache_tile **tiles, int ntiles);
+void geocache_image_copy_resampled_nearest(geocache_context *ctx, geocache_image *src, geocache_image *dst,
+      double off_x, double off_y, double scale_x, double scale_y);
+void geocache_image_copy_resampled_bilinear(geocache_context *ctx, geocache_image *src, geocache_image *dst,
  * \brief merge two images
  * \param base the imae to merge onto
@@ -1075,13 +1081,11 @@
       int *ntiles,
       geocache_tile ***tiles);
-#ifdef USE_CAIRO
 geocache_image* geocache_tileset_assemble_map_tiles(geocache_context *ctx, geocache_tileset *tileset,
       geocache_grid_link *grid_link,
       double *bbox, int width, int height,
       int ntiles,
       geocache_tile **tiles);
-#endif
  * compute x,y,z value given a bbox.
Modified: trunk/mapserver/mapcache/src/configuration_xml.c
--- trunk/mapserver/mapcache/src/configuration_xml.c	2011-08-26 11:27:45 UTC (rev 12453)
+++ trunk/mapserver/mapcache/src/configuration_xml.c	2011-08-26 11:27:51 UTC (rev 12454)
@@ -1094,11 +1094,7 @@
    config->getmap_strategy = GEOCACHE_GETMAP_ERROR;
    if ((node = ezxml_child(doc,"full_wms")) != NULL) {
       if(!strcmp(node->txt,"assemble")) {
-#ifdef USE_CAIRO
          config->getmap_strategy = GEOCACHE_GETMAP_ASSEMBLE;
-#else
-         ctx->set_error(ctx,400, "\"assemble\" <full_wms> not supported with current build. reconfigure with --enable-cairo");
-#endif
       } else if(!strcmp(node->txt,"forward")) {
          config->getmap_strategy = GEOCACHE_GETMAP_FORWARD;
       } else if(*node->txt && strcmp(node->txt,"error")) {
Modified: trunk/mapserver/mapcache/src/core.c
--- trunk/mapserver/mapcache/src/core.c	2011-08-26 11:27:45 UTC (rev 12453)
+++ trunk/mapserver/mapcache/src/core.c	2011-08-26 11:27:51 UTC (rev 12454)
@@ -46,7 +46,6 @@
    return rettile;
-#ifdef USE_CAIRO
 geocache_image* _core_get_single_map(geocache_context *ctx, geocache_map *map) {
    geocache_tile **maptiles;
@@ -75,7 +74,6 @@
          nmaptiles, maptiles);
    return getmapim;
-#endif
 geocache_map *geocache_core_get_map(geocache_context *ctx, geocache_request_get_map *req_map) {
 #ifdef DEBUG
@@ -89,7 +87,6 @@
       ctx->set_error(ctx, 404, "full wms support disabled");
       return NULL;
    } else if(ctx->config->getmap_strategy == GEOCACHE_GETMAP_ASSEMBLE) {
-#ifdef USE_CAIRO
       int i;
       geocache_map *basemap = req_map->maps[0];
       geocache_image *baseim = _core_get_single_map(ctx,basemap);
@@ -107,10 +104,6 @@
       basemap->data = basemap->tileset->format->write(ctx,baseim,basemap->tileset->format);
       return basemap;
-#else
-      ctx->set_error(ctx,501,"cairo not enabled: wms getmap handling by assembling tiles not configured in this build");
-      return NULL;
-#endif
    } else /*if(ctx->config->getmap_strategy == GEOCACHE_GETMAP_FORWARD)*/ {
       int i;
Modified: trunk/mapserver/mapcache/src/image.c
--- trunk/mapserver/mapcache/src/image.c	2011-08-26 11:27:45 UTC (rev 12453)
+++ trunk/mapserver/mapcache/src/image.c	2011-08-26 11:27:51 UTC (rev 12454)
@@ -81,6 +81,79 @@
+#include <math.h>
+      double off_x, double off_y, double scale_x, double scale_y) {
+   int dstx,dsty;
+   unsigned char *dstrowptr = dst->data;
+   for(dsty=0; dsty<dst->h; dsty++) {
+      int *dstptr = (int*)dstrowptr;
+      int srcy = round((dsty-off_y)/scale_y);
+      if(srcy >= 0 && srcy < src->h) {
+         for(dstx=0; dstx<dst->w;dstx++) {
+            int srcx = round((dstx-off_x)/scale_x);
+            if(srcx >= 0 && srcx < src->w) {
+               *dstptr = *((int*)&(src->data[srcy*src->stride+srcx*4]));
+            dstptr ++;
+      dstrowptr += dst->stride;
+static inline void bilinear_pixel(geocache_image *img, double x, double y, unsigned char *dst) {
+   int px,py;
+   px = (int)x;
+   py = (int)y;
+   int px1 = (px==(img->w-1))?(px):(px+1);
+   int py1 = (py==(img->h-1))?(py):(py+1);
+   unsigned char *p1 = &img->data[py*img->stride+px*4];
+   unsigned char *p2 = &img->data[py*img->stride+px1*4];
+   unsigned char *p3 = &img->data[py1*img->stride+px*4];
+   unsigned char *p4 = &img->data[py1*img->stride+px1*4];
+   // Calculate the weights for each pixel
+   float fx = x - px;
+   float fy = y - py;
+   float fx1 = 1.0f - fx;
+   float fy1 = 1.0f - fy;
+   int w1 = fx1 * fy1 * 256.0f;
+   int w2 = fx  * fy1 * 256.0f;
+   int w3 = fx1 * fy  * 256.0f;
+   int w4 = fx  * fy  * 256.0f;
+   // Calculate the weighted sum of pixels (for each color channel)
+   dst[0] = (p1[0] * w1 + p2[0] * w2 + p3[0] * w3 + p4[0] * w4) >> 8;
+   dst[1] = (p1[1] * w1 + p2[1] * w2 + p3[1] * w3 + p4[1] * w4) >> 8;
+   dst[2] = (p1[2] * w1 + p2[2] * w2 + p3[2] * w3 + p4[2] * w4) >> 8;
+   dst[3] = (p1[3] * w1 + p2[3] * w2 + p3[3] * w3 + p4[3] * w4) >> 8;
+   int dstx,dsty;
+      unsigned char *dstptr = dstrowptr;
+      double srcy = (dsty-off_y)/scale_y;
+            double srcx = (dstx-off_x)/scale_x;
+               bilinear_pixel(src,srcx,srcy,dstptr);
+            dstptr += 4;
 geocache_tile* geocache_image_merge_tiles(geocache_context *ctx, geocache_image_format *format, geocache_tile **tiles, int ntiles) {
    geocache_image *base,*overlay;
    int i;
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:27:45 UTC (rev 12453)
+++ trunk/mapserver/mapcache/src/tileset.c	2011-08-26 11:27:51 UTC (rev 12454)
@@ -76,11 +76,6 @@
    *ntiles = i;
-#ifdef USE_CAIRO
-#include <cairo/cairo.h>
-#include <math.h>
@@ -101,9 +96,6 @@
    if(ntiles == 0) {
       return image;
-   cairo_surface_t* dstsurface= cairo_image_surface_create_for_data(image->data, CAIRO_FORMAT_ARGB32,
-         width, height,image->stride);
-   cairo_t *cr = cr = cairo_create (dstsurface);
    /* compute the number of tiles horizontally and vertically */
    for(i=0;i<ntiles;i++) {
@@ -120,8 +112,6 @@
    srcimage->stride = srcimage->w*4;
    srcimage->data = calloc(1,srcimage->w*srcimage->h*4*sizeof(unsigned char));
    apr_pool_cleanup_register(ctx->pool, srcimage->data, (void*)free, apr_pool_cleanup_null) ;
-   cairo_surface_t* srcsurface= cairo_image_surface_create_for_data(srcimage->data, CAIRO_FORMAT_ARGB32,
-         srcimage->w, srcimage->h,srcimage->stride);
    /* copy the tiles data into the src image */
@@ -150,31 +140,22 @@
    double dstminy = (bbox[3]-tilebbox[3])/vresolution;
    double hf = tileresolution/hresolution;
    double vf = tileresolution/vresolution;
-   cairo_translate (cr, dstminx,dstminy);
-   cairo_scale  (cr, hf, vf);
-   cairo_set_source_surface (cr, srcsurface, 0, 0);
    if(fabs(hf-1)<0.0001 && fabs(vf-1)<0.0001) {
       //use nearest resampling if we are at the resolution of the tiles
-      cairo_pattern_set_filter (cairo_get_source (cr), CAIRO_FILTER_NEAREST);
+      geocache_image_copy_resampled_nearest(ctx,srcimage,image,dstminx,dstminy,hf,vf);
    } else {
       switch(ctx->config->resample_mode) {
          case GEOCACHE_RESAMPLE_BILINEAR:
-            cairo_pattern_set_filter (cairo_get_source (cr), CAIRO_FILTER_BILINEAR);
+            geocache_image_copy_resampled_bilinear(ctx,srcimage,image,dstminx,dstminy,hf,vf);
             break;
          default:
             break;
-   cairo_paint (cr);
-   cairo_surface_destroy(srcsurface);
-   cairo_surface_destroy(dstsurface);
-   cairo_destroy(cr);
    return image;
-#endif
  * compute the metatile that should be rendered for the given tile
