[mapserver-commits] r10964 - trunk/mapserver/mapscript/php
svn at osgeo.org
svn at osgeo.org
Mon Feb 7 12:26:59 EST 2011
Author: aboudreault
Date: 2011-02-07 09:26:59 -0800 (Mon, 07 Feb 2011)
New Revision: 10964
trunk/mapserver/mapscript/php/Makefile.in
trunk/mapserver/mapscript/php/Makefile.vc
trunk/mapserver/mapscript/php/layer.c
trunk/mapserver/mapscript/php/map.c
trunk/mapserver/mapscript/php/mapscript_i.c
trunk/mapserver/mapscript/php/php_mapscript.c
trunk/mapserver/mapscript/php/php_mapscript.h
trunk/mapserver/mapscript/php/php_mapscript_util.c
Fixed PHP/MapScript for RFC 65 changes (#3647)
Modified: trunk/mapserver/mapscript/php/Makefile.in
--- trunk/mapserver/mapscript/php/Makefile.in 2011-02-07 17:05:57 UTC (rev 10963)
+++ trunk/mapserver/mapscript/php/Makefile.in 2011-02-07 17:26:59 UTC (rev 10964)
@@ -79,7 +79,7 @@
all: php_mapscript.so
-PHPMS_CLASS_OBJS = mapscript_error.o color.o rect.o hashtable.o web.o grid.o error.o referencemap.o querymap.o outputformat.o scalebar.o label.o legend.o symbol.o style.o image.o class.o projection.o line.o shape.o shapefile.o point.o labelcache.o labelcachemember.o resultcachemember.o owsrequest.o layer.o map.o
+PHPMS_CLASS_OBJS = mapscript_error.o color.o rect.o hashtable.o web.o grid.o error.o referencemap.o querymap.o outputformat.o scalebar.o label.o legend.o symbol.o style.o image.o class.o projection.o line.o shape.o shapefile.o point.o labelcache.o labelcachemember.o result.o owsrequest.o layer.o map.o
PHPMS_OBJS = php_mapscript_util.o $(PHPMS_CLASS_OBJS) php_mapscript.o mapscript_i.o $(PHP_REGEX_OBJ)
PHPPROJ_OBJS = php_mapscript_util.o php_proj.o $(PHP_REGEX_OBJ)
Modified: trunk/mapserver/mapscript/php/Makefile.vc
--- trunk/mapserver/mapscript/php/Makefile.vc 2011-02-07 17:05:57 UTC (rev 10963)
+++ trunk/mapserver/mapscript/php/Makefile.vc 2011-02-07 17:26:59 UTC (rev 10964)
@@ -52,7 +52,7 @@
# The rest of the file should not have to be edited...
-PHPMS_CLASS_OBJS = mapscript_error.obj color.obj rect.obj hashtable.obj web.obj grid.obj error.obj referencemap.obj querymap.obj outputformat.obj scalebar.obj label.obj legend.obj symbol.obj style.obj image.obj class.obj projection.obj line.obj shape.obj shapefile.obj point.obj labelcache.obj labelcachemember.obj resultcachemember.obj owsrequest.obj layer.obj map.obj
+PHPMS_CLASS_OBJS = mapscript_error.obj color.obj rect.obj hashtable.obj web.obj grid.obj error.obj referencemap.obj querymap.obj outputformat.obj scalebar.obj label.obj legend.obj symbol.obj style.obj image.obj class.obj projection.obj line.obj shape.obj shapefile.obj point.obj labelcache.obj labelcachemember.obj result.obj owsrequest.obj layer.obj map.obj
PHPMS_OBJS = php_mapscript_util.obj $(PHPMS_CLASS_OBJS) php_mapscript.obj mapscript_i.obj
Modified: trunk/mapserver/mapscript/php/layer.c
--- trunk/mapserver/mapscript/php/layer.c 2011-02-07 17:05:57 UTC (rev 10963)
+++ trunk/mapserver/mapscript/php/layer.c 2011-02-07 17:26:59 UTC (rev 10964)
@@ -174,9 +174,8 @@
ZEND_ARG_INFO(0, mode)
ZEND_END_ARG_INFO()
-ZEND_BEGIN_ARG_INFO_EX(layer_resultsGetShape_args, 0, 0, 1)
- ZEND_ARG_INFO(0, shapeindex)
- ZEND_ARG_INFO(0, tileindex)
+ZEND_BEGIN_ARG_INFO_EX(layer_getShape_args, 0, 0, 1)
+ ZEND_ARG_OBJ_INFO(0, record, resultObj, 0)
ZEND_END_ARG_INFO()
/* {{{ proto void __construct(mapObj map [, layerObj layer])
@@ -935,12 +934,12 @@
/* {{{ proto int layer.getResult(int i)
- Returns a resultCacheMemberObj by index from a layer object.*/
+ Returns a resultObj by index from a layer object.*/
PHP_METHOD(layerObj, getResult)
zval *zobj = getThis();
long index;
- resultCacheMemberObj *resultcachemember = NULL;
+ resultObj *result = NULL;
php_layer_object *php_layer;
PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
@@ -953,16 +952,16 @@
php_layer = (php_layer_object *) zend_object_store_get_object(zobj TSRMLS_CC);
- if ((resultcachemember = layerObj_getResult(php_layer->layer, index)) == NULL)
+ if ((result = layerObj_getResult(php_layer->layer, index)) == NULL)
mapscript_throw_exception("Invalid result index." TSRMLS_CC);
return;
- /* Return resultcachemember object */
+ /* Return result object */
MAPSCRIPT_MAKE_PARENT(zobj, NULL);
- mapscript_create_resultcachemember(&(php_layer->layer->resultcache->results[index]),
- parent, return_value TSRMLS_CC);
+ mapscript_create_result(&(php_layer->layer->resultcache->results[index]),
+ parent, return_value TSRMLS_CC);
@@ -1868,26 +1867,27 @@
-/* {{{ proto shapeObj layer.resultsGetShape(shapeindex, [tileindex])
+/* {{{ proto shapeObj layer.getShape(record)
Retrieve shapeObj from a resultset by index. */
-PHP_METHOD(layerObj, resultsGetShape)
+PHP_METHOD(layerObj, getShape)
- long shapeindex, tileindex = -1;
+ zval *zresult;
shapeObj *shape = NULL;
+ php_result_object *php_result;
- if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "l|l",
- &shapeindex, &tileindex) == FAILURE) {
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "O",
+ &zresult, mapscript_ce_result) == FAILURE) {
PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
return;
+ php_result = (php_result_object *) zend_object_store_get_object(zresult TSRMLS_CC);
/* Create a new shapeObj to hold the result
* Note that the type used to create the shape (MS_NULL) does not matter
* at this point since it will be set by SHPReadShape().
@@ -1898,7 +1898,7 @@
return;
- if (msLayerResultsGetShape(php_layer->layer, shape, tileindex, shapeindex) != MS_SUCCESS)
+ if (msLayerGetShape(php_layer->layer, shape, php_result->result) != MS_SUCCESS)
shapeObj_destroy(shape);
mapscript_throw_mapserver_exception("" TSRMLS_CC);
@@ -1983,7 +1983,7 @@
PHP_ME(layerObj, isVisible, NULL, ZEND_ACC_PUBLIC)
PHP_ME(layerObj, setConnectionType, layer_setConnectionType_args, ZEND_ACC_PUBLIC)
PHP_ME(layerObj, getGridIntersectionCoordinates, NULL, ZEND_ACC_PUBLIC)
- PHP_ME(layerObj, resultsGetShape, layer_resultsGetShape_args, ZEND_ACC_PUBLIC)
+ PHP_ME(layerObj, getShape, layer_getShape_args, ZEND_ACC_PUBLIC)
PHP_ME(layerObj, free, NULL, ZEND_ACC_PUBLIC)
{NULL, NULL, NULL}
Modified: trunk/mapserver/mapscript/php/map.c
--- trunk/mapserver/mapscript/php/map.c 2011-02-07 17:05:57 UTC (rev 10963)
+++ trunk/mapserver/mapscript/php/map.c 2011-02-07 17:26:59 UTC (rev 10964)
@@ -317,7 +317,7 @@
php_map = (php_map_object *)zend_object_store_get_object(zobj TSRMLS_CC);
map = mapObj_new(filename, path);
if (map == NULL)
Modified: trunk/mapserver/mapscript/php/mapscript_i.c
--- trunk/mapserver/mapscript/php/mapscript_i.c 2011-02-07 17:05:57 UTC (rev 10963)
+++ trunk/mapserver/mapscript/php/mapscript_i.c 2011-02-07 17:26:59 UTC (rev 10964)
@@ -46,9 +46,9 @@
mapObj *mapObj_new(char *filename, char *new_path) {
if(filename && strlen(filename))
- return msLoadMap(filename, new_path);
+ return msLoadMap(filename, new_path);
else { /* create an empty map, no layers etc... */
- return msNewMapObj();
+ return msNewMapObj();
@@ -482,12 +482,7 @@
msLayerClose(self);
-int layerObj_getShape(layerObj *self, shapeObj *shape,
- int tileindex, int shapeindex) {
- return msLayerGetShape(self, shape, tileindex, shapeindex);
-resultCacheMemberObj *layerObj_getResult(layerObj *self, int i) {
+resultObj *layerObj_getResult(layerObj *self, int i) {
if(!self->resultcache) return NULL;
if(i >= 0 && i < self->resultcache->numresults)
Modified: trunk/mapserver/mapscript/php/php_mapscript.c
--- trunk/mapserver/mapscript/php/php_mapscript.c 2011-02-07 17:05:57 UTC (rev 10963)
+++ trunk/mapserver/mapscript/php/php_mapscript.c 2011-02-07 17:26:59 UTC (rev 10964)
@@ -1208,7 +1208,7 @@
PHP_MINIT(projection)(INIT_FUNC_ARGS_PASSTHRU);
PHP_MINIT(labelcachemember)(INIT_FUNC_ARGS_PASSTHRU);
PHP_MINIT(labelcache)(INIT_FUNC_ARGS_PASSTHRU);
- PHP_MINIT(resultcachemember)(INIT_FUNC_ARGS_PASSTHRU);
+ PHP_MINIT(result)(INIT_FUNC_ARGS_PASSTHRU);
PHP_MINIT(scalebar)(INIT_FUNC_ARGS_PASSTHRU);
PHP_MINIT(owsrequest)(INIT_FUNC_ARGS_PASSTHRU);
PHP_MINIT(point)(INIT_FUNC_ARGS_PASSTHRU);
Modified: trunk/mapserver/mapscript/php/php_mapscript.h
--- trunk/mapserver/mapscript/php/php_mapscript.h 2011-02-07 17:05:57 UTC (rev 10963)
+++ trunk/mapserver/mapscript/php/php_mapscript.h 2011-02-07 17:26:59 UTC (rev 10964)
@@ -275,11 +275,11 @@
labelCacheMemberObj *labelcachemember;
} php_labelcachemember_object;
-typedef struct _php_resultcachemember_object {
+typedef struct _php_result_object {
zend_object std;
parent_object parent;
- resultCacheMemberObj *resultcachemember;
-} php_resultcachemember_object;
+ resultObj *result;
+} php_result_object;
typedef struct _php_scalebar_object {
zend_object std;
@@ -348,7 +348,7 @@
PHP_MINIT_FUNCTION(projection);
PHP_MINIT_FUNCTION(labelcachemember);
PHP_MINIT_FUNCTION(labelcache);
-PHP_MINIT_FUNCTION(resultcachemember);
+PHP_MINIT_FUNCTION(result);
PHP_MINIT_FUNCTION(scalebar);
PHP_MINIT_FUNCTION(owsrequest);
PHP_MINIT_FUNCTION(point);
@@ -418,7 +418,7 @@
extern zend_class_entry *mapscript_ce_shapefile;
extern zend_class_entry *mapscript_ce_labelcachemember;
extern zend_class_entry *mapscript_ce_labelcache;
-extern zend_class_entry *mapscript_ce_resultcachemember;
+extern zend_class_entry *mapscript_ce_result;
extern zend_class_entry *mapscript_ce_scalebar;
extern zend_class_entry *mapscript_ce_owsrequest;
extern zend_class_entry *mapscript_ce_layer;
@@ -444,8 +444,8 @@
parent_object parent, zval *return_value TSRMLS_DC);
extern void mapscript_create_labelcache(labelCacheObj *labelcache,
-extern void mapscript_create_resultcachemember(resultCacheMemberObj *resultcachemember,
- parent_object parent, zval *return_value TSRMLS_DC);
+extern void mapscript_create_result(resultObj *result,
+ parent_object parent, zval *return_value TSRMLS_DC);
extern void mapscript_create_scalebar(scalebarObj *scalebar, parent_object parent, zval *return_value TSRMLS_DC);
extern void mapscript_create_owsrequest(cgiRequestObj *cgirequest, zval *return_value TSRMLS_DC);
extern void mapscript_create_image(imageObj *image, zval *return_value TSRMLS_DC);
@@ -506,7 +506,7 @@
int mapObj_queryByIndex(mapObj *self, int qlayer,
int tileindex, int shapeindex,
int bAddToQuery);
-int mapObj_saveQuery(mapObj *self, char *filename);
+int mapObj_saveQuery(mapObj *self, char *filename, int results);
int mapObj_loadQuery(mapObj *self, char *filename);
int mapObj_setWKTProjection(mapObj *self, char *string);
@@ -563,7 +563,7 @@
void layerObj_close(layerObj *self);
int tileindex, int shapeindex);
-resultCacheMemberObj *layerObj_getResult(layerObj *self, int i);
+resultObj *layerObj_getResult(layerObj *self, int i);
classObj *layerObj_getClass(layerObj *self, int i);
int layerObj_getClassIndex(layerObj *self, shapeObj *shape, double scaledenom, int *classgroup, int numclasses);
int layerObj_draw(layerObj *self, mapObj *map, imageObj *img);
Modified: trunk/mapserver/mapscript/php/php_mapscript_util.c
--- trunk/mapserver/mapscript/php/php_mapscript_util.c 2011-02-07 17:05:57 UTC (rev 10963)
+++ trunk/mapserver/mapscript/php/php_mapscript_util.c 2011-02-07 17:26:59 UTC (rev 10964)
@@ -124,8 +124,8 @@
mapscript_create_labelcachemember((labelCacheMemberObj*)internal_object, p, *php_object_storage TSRMLS_CC);
else if (ce == mapscript_ce_labelcache)
mapscript_create_labelcache((labelCacheObj*)internal_object, p, *php_object_storage TSRMLS_CC);
- else if (ce == mapscript_ce_resultcachemember)
- mapscript_create_resultcachemember((resultCacheMemberObj*)internal_object, p, *php_object_storage TSRMLS_CC);
+ else if (ce == mapscript_ce_result)
+ mapscript_create_result((resultObj*)internal_object, p, *php_object_storage TSRMLS_CC);
else if (ce == mapscript_ce_scalebar)
mapscript_create_scalebar((scalebarObj*)internal_object, p, *php_object_storage TSRMLS_CC);
else if (ce == mapscript_ce_web)
More information about the mapserver-commits
